A10194-U1
A10194-U1
    ANTENOVA(安诺亚)
    EVAL BOARD ANT MIXTUS
A10194-U1 数据手册
Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 gigaNOVA® Product Specification 1 Features • • • • • • Designed for 2.4 – 2.5 GHz and 4.9 – 5.9 GHz applications: 802.11a/b/g/j/n, Wi-Fi® Easy to integrate High efficiency Light weight Intended for SMD mounting Supplied in tape on reel 2 Description Mixtus is intended for use with all dual-band Wi-Fi applications, including 802.11n MIMO. The antenna requires a ground plane, i.e. your device acts as an active part of the antenna and thus demands careful consideration concerning its placement. 3 Applications • • • • • • • • • Mobile phones PDAs Portable Media Players (PMPs) Headsets PC-Cards Game Consoles Access Points Set-top-box Networked Digital TVs Antennas for Wireless M2M Applications 1 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 4 Part No. Mixtus: A10194 5 General data Product name Mixtus W i-Fi Part No. A10194 Frequency 2.4 – 2.5 GHz and 4.9 – 5.9 GHz Polarization Linear Operating temperature -40 ºC to +85 ºC Impedance with matching 50 Ω Weight 0.2 g Antenna type SMD Dimensions 10 x 10 x 0.9 [mm] 6 Electrical characteristics Typical performance Peak gain 1.8 dBi Average gain -0.5 dBi Average efficiency >75% Maximum Return Loss -15 dB Maximum VSWR Data given for the 2.4 – 2.5 GHz frequency range All data measured on Antenova’s reference board part number A10194-U1 1.4:1 Peak gain 4.1 dBi Average gain -2.3 dBi Average efficiency >60% Maximum Return Loss -11 dB Maximum VSWR Conditions Data given for the 4.9 – 5.9 GHz frequency range All data measured on Antenova’s reference board part number A10194-U1 1.8:1 Integrated Antenna and RF Solutions 2 Product Specification 06MD-0010-3-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 7 Electrical performance 7-1 Return Loss 5 [dB] mtool5 0 -5 3 -10 4 ∇ ∇ 1 -15 ∇ 2 ∇ -20 -25 -30 -35 -40 -45 -50 2000 [MHz] 2500 3000 3500 4000 4500 5000 5500 6000 7-2 VSWR mtool5 10 9 8 7 6 5 4 3 2 3 4 ∇ 1 ∇2 ∇ ∇ 1 2000 2500 [MHz] 3000 3500 4000 4500 5000 5500 6000 Antennas for Wireless M2M Applications 3 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 7-3 Antenna patterns 2400 MHz – 2500 MHz 7.3.1. Z θ φ X 0° E5511 Radial Scale: dBi 270° -35 -25 -15 180° XY plane -5 5 90° Y 0° E5511 Radial Scale: dBi 0° E5511 Radial Scale: dBi Plane XY Plane YZ Plane XZ Pol. Total Pol. Total Pol. Total 2400 2400 2400 2450 2450 2450 2500 2500 2500 270° -35 -25 -15 -5 5 90° 180° YZ plane 270° -35 -25 -15 -5 5 90° 180° XZ plane Patterns show combined polarisations measured on reference board A10194-U1 Antennas for Wireless M2M Applications 4 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 4900 MHz – 5900 MHz 7.3.2. Z θ φ X 0° E5512 Radial Scale: dBi 270° -35 -25 180° XY plane -15 -5 5 90° Y 0° E5512 Radial Scale: dBi 0° E5512 Radial Scale: dBi Plane XY Plane YZ Plane XZ Pol. Total Pol. Total Pol. Total 4900 4900 4900 5400 5400 5400 5900 5900 5900 270° -35 -25 -15 -5 5 90° -35 270° -15 -5 5 90° 180° 180° ZY plane -25 XZ plane Patterns show combined polarisations measured on reference board A10194-U1 Antennas for Wireless M2M Applications 5 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 8 Antenna dimensions Mixtus L W H Length Width Height 10.4 ± 0.2 10.4 ± 0.2 0.8 ± 0.15 Dimensions in mm 9 Antenna footprint Mixtus (Part No: A10194) CAD files of the antenna footprint are available to download at www.antenova-m2m.com I S K J M O H R L 1.5 ± 0.1 1.5 ± 0.1 2.0 ± 0.1 0.5 ± 0.1 1.2 ± 0.1 7.0 ± 0.1 1.9 ± 0.1 3.1 ± 0.1 0.8 ± 0.1 Dimensions in mm Antennas for Wireless M2M Applications 6 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 10 Electrical interface 10-1 Transmission lines • All transmission lines should be designed to have a characteristic impedance of 50 Ω • The length of the transmission lines should be kept to a minimum. • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the track so the characteristic impedance of the coplanar transmission line is 50 Ω . 10-2 Matching circuit The antenna requires a matching circuit that must be optimized for each customer’s product. The matching circuit will require up to three components and the following pad layout should be designed into the device so the correct circuit can be installed: The antenna feed pad and the antenna ground pad are indicated in the drawing above. Additional pads are for mechanical attachment only and should not be grounded. Antennas for Wireless M2M Applications 7 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 In addition to the matching circuit, a separate DC blocking capacitor will also be required between the radio and the antenna matching circuit. Note: The component values for the matching circuit will vary depending on the size of the PCB and surrounding components. The impedance of the antenna should be measured before selecting suitable matching components. Antenova M2M offers this service on request. Contact sales@antenova-m2m.com for further information. 10-3 Antenna placement Antenova M2M strongly recommends placing the antenna near the edge of the board. Maximum antenna performance is achieved by placing the antenna towards one of the corners of the PCB and with the feed point of the antenna as close to the same corner of the PCB as possible. Additional ground and components near the antenna should be at a distance of at least 5 mm from the left hand side and 18 mm or more from the right hand side as shown in the drawing above. Antennas for Wireless M2M Applications 8 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 10-4 Reference boards The reference boards have been designed for evaluation purposes of Mixtus dual-band Wi-Fi SMD antenna and they include a SMA female connector Mixtus Dimensions in mm To order a reference board contact sales@antenova-m2m.com. Antennas for Wireless M2M Applications 9 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 11 Soldering This antenna is suitable for lead free soldering. The reflow profile should be adjusted to suit the PCBA, oven and solder paste, while observing the following conditions: 12 Hazardous material regulation conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. Antennas for Wireless M2M Applications 10 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 13 Packaging 13-1 Optimal storage conditions for packaged reels Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf Life 18 Months Storage place Away from corrosive gas and direct sunlight Packaging Reels should be stored in unopened sealed manufacturer’s plastic packaging. Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on antennas. If short term storage is necessary, then it is highly recommended that the bag containing the antenna reel is re-sealed and stored in like storage conditions as in above table. 13-2 Tape characteristics Mixtus [Part Number: A10194] W F E P0 P1 P2 B0 K0 T D0 D1 24 ± 0.2 10.7 ± 0.1 1.75 ± 0.1 4.0 ± 0.1 16.0 ± 0.1 2.0 ± 0.1 10.7 ± 0.1 1.1 ± 0.1 0.3 ± 0.05 Min 1.55 ± 0.1 Min 2.0± 0.2 Dimensions in mm Quantity Leading Space Trailing Space 2000 pcs / reel 50 blank antenna holders 50 blank antenna holders Antennas for Wireless M2M Applications 11 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 13-3 Reel dimensions Width (W) Reel Diameter (D) Hub Diameter (H) Shaft Diameter (C) 57.5 mm 330 mm ± 2.0 80 mm (2”) 13.0 mm ± 0.5 13-4 Box dimensions Width (W) Breadth (B) Thickness (H) 338 mm 335 mm 45 mm 13-5 Bag properties Reels are supplied in protective plastic packaging Antennas for Wireless M2M Applications 12 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 13-6 Reel label information Mixtus Dimensions in mm Antennas for Wireless M2M Applications 13 Product Specification 06MD-0010-5-PS Mixtus Dual-band Wi-Fi SMD Antenna Part No. A10194 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Ltd. nd 2 Floor, Titan Court 3 Bishop Square Hatfield AL10 9NA Antenova Ltd. 100 Brush Creek Road, Suite 103 Santa Rosa California, 95404 USA Antenova Asia Ltd. 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +44 1223 810600 Email: sales@antenova-m2m.com Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com ® ® ® ® Copyright Antenova Ltd. All Rights Reserved. Antenova , Antenova M2M , gigaNOVA , the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of print. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within these information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications 14 Product Specification 06MD-0010-5-PS Revised 5 November 2015
A10194-U1 价格&库存
很抱歉,暂时无法提供与“A10194-U1”相匹配的价格&库存,您可以联系我们找货
A10194-U1
  • 10+288.0016510+37.30629
