CGGBP.25.4.A.02
Part No:
CGGBP.25.4.A.02
Description:
Embedded 25mm GPS/GLONASS/Galileo/BeiDou Patch Antenna,
1561/1575/1602MHz
Features:
25*25*4mm Ceramic patch
High Gain (up to 3.5dBi)
Excellent stability on the three GNSS systems
Optimized radiation patterns
Pin Mount
RoHS and REACH Compliant
SPE-14-8-071-E
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
9
5.
Mechanical Drawing
11
6.
Footprint
13
7.
Packaging
14
Changelog
15
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-14-8-071-E
www.taoglas.com
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
square embedded ceramic GPS/GLONASS/Galileo/BeiDou patch antenna's wide band of operation
1.This 25mm
Introduction
leads to excellent gain and radiation pattern stability on all four common commercial GNSS systems worldwide.
Compared to using a smaller antenna, this will translate into the GNSS system having much higher location
accuracy, improved reliability of lock in urban areas, better signal reception, with more satellites acquired and a
quicker time to first fix.
1.
Introduction
The patch is mounted via pin and double-sided adhesive. This patch can be tuned subject to NRE and MOQ, for
further information please contact your regional Taoglas customer support team.
1.
Introduction
1.
Introduction
SPE-14-8-071-E
www.taoglas.com
2.
Specifications
GNSS Frequency Bands Covered
L1
L2
L5
L6
3.GPS/QZSS
Antenna
Characteristics2.
Specifications
1575.42MHz
1227.6MHz
1176.45MHz
1278.75MHz
GLONASS
3.
L5R
1176.45MHz
L3PT
1201.5MHz
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
E4
1215MHz
E3
1256MHz
E6
1278.75MHz
E2
1561MHz
E1
1575.42MHz
Antenna
Characteristics
Galileo
4.
E5a
1176.45MHz
Antenna
Radiation
Patterns3.
Antenna
BeiDou
B1
1561MHz
Characteristics2.
Compass
3.
SBAS
E5b
1201.5MHz
E5B(B2)/ E6(B3)
1268.56MHz
B2
1207.14MHz
B3
1268.52MHz
Specifications
E2(B1)
1561MHz
Antenna
Characteristics2.
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
Specifications
3.
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
GNSS Bands and Constellations
Characteristics2.
SPE-14-8-071-E
Specifications
www.taoglas.com
GNSS Electrical
Frequency (MHz)
1561
1575
1602
VSWR (max.)
2.5
2.2
2.1
Efficiency (%)
82.15
85.45
79.76
Peak Gain
4.96
4.99
5.48
Average Gain
-0.85
-0.68
-0.38
Centre Frequency
Impedance
Mechanical
Height
4 mm
Planner Dimension
25 x 25 mm
Casing
Ceramic
Pin Diameter
0.9 mm
Pin Length
2.4 mm
Environmental
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-14-8-071-E
www.taoglas.com
3.
4.
3.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-14-8-071-E
www.taoglas.com
3.3
Efficiency
3.4
Peak Gain
SPE-14-8-071-E
www.taoglas.com
3.5
Average Gain
3.6
Axial Ratio
SPE-14-8-071-E
www.taoglas.com
4.
Radiation Patterns
4.
4.
4.1
Test Setup
4.
4.
4.
4.
4.
4.
SPE-14-8-071-E
Z
www.taoglas.com
4.2
842MHz 3D and 2D Radiation Patterns
XY Plane
XZ Plane
YZ Plane
SPE-14-8-071-E
www.taoglas.com
5.
Mechanical Drawing (Units: mm)
Patch Drawings Mechanical Drawing
6.5.1 Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-071-E
Mechanical Drawing
www.taoglas.com
5.2
Adhesive Thickness
5.2
Adhesive Thickness
SPE-14-8-071-E
www.taoglas.com
6.
Footprint
Dimensions
4.6.1 Antenna
Characteristics
4.
4.
Characteristics
Patch onRadiation
70*70mm Ground
Plane Antenna
4.6.2 Antenna
Patterns3.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-14-8-071-E
www.taoglas.com
7.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-071-E
Mechanical Drawing
www.taoglas.com
Changelog for the datasheet
SPE-14-8-071 – CGGBP.25.4.A.02
Revision: E (Current Version)
Date:
Changes:
Changes Made by:
2022-02-18
Updated Datasheet Template
Updated Packaging Graphic
Paul Doyle
Previous Revisions
Revision: C
Date:
Changes:
Changes Made by:
2017-03-08
Packaging Details Updated
Made by Andy Mahoney
Revision: B
Date:
Changes:
Changes Made by:
2017-08-17
Andy Mahoney
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-14-8-071-E
2017-08-10
Your Name Here
www.taoglas.com
Previous Revisions (Continued)
SPE-14-8-071-E
www.taoglas.com
SPE-14-8-071-E
© Taoglas
www.taoglas.com
很抱歉,暂时无法提供与“CGGBPD.25.A”相匹配的价格&库存,您可以联系我们找货
