XK8-DMSB0
XK8-DMSB0
    DIGIINTERNATIONAL
    SMD
    KIT DEV XBEE 865/868 LOW PWR SMT
XK8-DMSB0 数据手册
ERRATA SHEET # 150320 Date: March 20, 2015 Product: XBee Development Kits Summary: This errata sheet documents a resolution for a known issue with the USB port use on XBee® development board kits shipped prior to 2/23/15. Issue: Some Digi XBee® development board kits were confirmed to exhibit a failure when powered through the USB port. The cause was found to be a variation on the voltage regulator that caused some USB circuits to not function properly. Specifically, the boards cause the FTDI chip to not enumerate when the power supply doesn’t come up properly to 3.3v. Determining the failure: If the board is able to consistently connect through the USB, it is considered ok and not prone to this issue. Because the issue is intermittent, we suggest the user verifies port connectivity three times in succession. To verify if your board may be faulty, perform the following test: 1) Plug in the USB port to your PC 2) Open up “Device Manager” from your windows PC to make sure all USB units do not have errors. A faulty connection will show up as a USB icon with an exclamation mark. Below in image 1 is a screen shot highlighting a faulty USB connection Image 1: Page 1 of 3 Resolution: To resolve the issue, the barrel jack must be supplied with between 6v to 20v of power, prior to connecting the USB port. If the barrel jack is supplied with between 6v to 20v prior to the USB connection, the board will always function properly. However, the barrel jack must be connected first, followed by the USB to guarantee correct operation. Most of the development kits include one or more 12V power supplies to power one or more boards. If your kit did not have a power supply and you need one, or would like to return your development board for a new fully functional unit, please see the “customer resolution” information and tables below. Customer Resolution: If you need a replacement power supply or wish to exchange any affected product, you may request an RMA from the Customer Service team. Please send your request to DigiRMAs@digi.com or contact us by phone at 800-344-4273 Option 4. Please reference the Errata Sheet # along with Part Number and Quantity of the affected part(s). If you have technical related concerns or questions about this notice please contact our technical support department via telephone at 801-765-9885 or submit a request online at http://www.digi.com/support/eservice/. Please reference the Errata Sheet # along with Part Number and Quantity of the affected part(s). Product Management Digi International 11001 Bren Road East Minnetonka, MN 55343 Table 1: Affected Board Part Numbers with old / new revisions and descriptions Part Number Revision Description XBIB-U-DEV D XBee, Dev Interface Board USB XBIB-U-SS D XBee USB Interface Board - SMT Socket Image 2: example board (P/N: XBIB-U-DEV) Image 3: Notation of Revision Level on Label Page 2 of 3 Table 2: Affected Kits without power supplies to resolve, and replacement items if needed ITEM DESCRIPTION BOARD / REPLACEMENT BOARD XB24-DKS XBee Starter Development Kit XBIB-U-DEV (QTY 2) XB24-DKS-INT XBee Starter Development Kit XBIB-U-DEV (QTY 2) XB24-DKSJ XB 2.4,S1 Starter Kit,Jpn XBIB-U-DEV (QTY 2) XB24-DMDK XBee DigiMesh 2.4 Dev Kit XBIB-U-DEV (QTY 4) XB24-DMDK-WJ XBee DigiMesh 2.4 Dev Kit Jpn XBIB-U-DEV (QTY 4) XB24-PDK XBee Professional Developer's XBIB-U-DEV (QTY 5) XB24-PDK-INT XBee Professional Developer's XBIB-U-DEV (QTY 5) XB24-PDKJ XBee 802.15.4 Dev Kit Jpn XBIB-U-DEV (QTY 5) XBP08-DK XBee-PRO 868 Development Kit XBIB-U-DEV (QTY 2) XBP09-DMDK XBee-PRO DigiMesh 900 Dev Kit XBIB-U-DEV (QTY 4) XBP24-DKS XBee-PRO Starter Development K XBIB-U-DEV (QTY 2) XBP24-DKS-INT XBee-PRO Starter Development K XBIB-U-DEV (QTY 2) XBP24-DKSJ XBeePRO Starter Dev Kit Japan XBP24BZ7B-DK XBP24BZ7B-DK-W XBP24BZ7B-DK-WJ XK-Z11-M XBP,ZB Programmable Dev Kit XBIB-U-DEV (QTY 2) XBP,ZB Int Programmable Dev Kit XBIB-U-DEV (QTY 2) XBP,ZB Jpn Programmable Dev KitXBIB-U-DEV (QTY 2) ZigBee, RF Module Dev Kit XBIB-U-DEV (QTY 4) XK-Z11-M-W ZigBee, RF Module Dev Kit-Int XK-Z11-M-WA ZigBee, RF Module Dev Kit - Australia XBIB-U-DEV (QTY 4) XK-Z11-T iDigi Tank ZB US Kit XBIB-U-DEV (QTY 1) XK-Z11-T-W iDigi Tank ZB Kit Int XBIB-U-DEV (QTY 1) XK2B-WFT-0 XBee, S6B Wi-Fi Development Kit XBIB-U-DEV (QTY 1); XBIB-U-SS (QTY 1) XK9-XCT-0 XBee-PRO, XSC S3B Dev Kit XBIB-U-DEV (QTY 2) XK9-XCT-2 XBee-PRO, XSC S3B 920 MHz 9.6K XBIB-U-DEV Dev Kit (QTY 2) XKP9-DM-0 XBee-PRO 900HP S3B Dev Kit (Domestic) XBIB-U-DEV (QTY 3) XKP9-DM-1 XBee-PRO 900HP S3B 920MHz (Brazil) XBIB-U-DEV (QTY 3) XKP9-DM-2 XBee-PRO 900HP S3B 920MHz (Aus) XBIB-U-DEV (QTY 3) XKP9-DM-4 XBee-PRO 900HP S3B 920MHz (Singapore) XBIB-U-DEV (QTY 3) XKP9-DMB0 XBP, PROG 900HP S3B DEV KIT XBIB-U-DEV (QTY 3) XK-Z11-S ZigBee SMT RF Module Dev Kit XBIB-U-SS (QTY 4) XK-Z11-S-W ZigBee SMT RF Module Dev Kit-IntXBIB-U-SS (QTY 4) XK-Z11-S-WA ZigBee SMT RF Module Dev Kit - Australia XBIB-U-SS (QTY 4) XK2-Z7SB0 XK2-Z7SBE0 XK2-Z7SBJ0 XBP, ZB SMT 32K Prog Dev Kit US XBIB-U-SS (QTY 2) XBP, ZB SMT 32K Prog Dev Kit EMEA XBIB-U-SS (QTY 2) XBP, ZB SMT 32K Prog Dev Kit JPNXBIB-U-SS (QTY 2) XBIB-U-DEV (QTY 1); XBee, S6B Wi-Fi Development Kit XBIB-U-SS (QTY 1) XK2B-WFT-0 XBIB-U-DEV (QTY 2) XBIB-U-DEV (QTY 4) XK8-DMS-0 XBee, 865/868LP Dev Kit XBIB-U-SS (QTY 3) XK8-DMSB0 XBee, 865/868LP Programmable Dev XBIB-U-SS Kit. (QTY 3) POWER SUPPLY (INCLUDED) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 1) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 1) No power supply on BOM JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply) (QTY 1) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 3) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 3) No power supply on BOM JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply) (QTY 3) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 1) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 1) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 1) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 1) No power supply on BOM JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply) (QTY 1) No power supply on BOM No power supply on BOM No power supply on BOM 24000056 (PS,12VDC 100-240V 18W 1.5A)(QTY2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000077 (PS,12V OUT 100/240 LOCK, ISOL RTN)(QTY 1) 24000077 (PS,12V OUT 100/240 LOCK, ISOL RTN)(QTY 1) No power supply on BOM JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply)(QTY 1) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 1) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 1) JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply)(QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) JP5P2-9V11-6F (9V 1.1A 10 Watt Power Supply)(QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A)(QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) No power supply on BOM No power supply on BOM No power supply on BOM No power supply on BOM 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) 24000056 (PS,12VDC 100-240V 18W 1.5A) (QTY 2) 18000291 (CONN,AC Plug Kit EU,UK,AUST) (QTY 2) Page 3 of 3 Replacement Power Supply 76000738 (PS,12VDC 100-240V 18W 1.5A)
XK8-DMSB0 价格&库存
很抱歉,暂时无法提供与“XK8-DMSB0”相匹配的价格&库存,您可以联系我们找货
