GPS/GLONASS/BeiDou Patch
Part No:
CGGBP.35.6.A.02
Description:
GPS/GLONASS/Galileo/BeiDou Embedded Patch Antenna
Features:
Dielectric Ceramic
BeiDou 1561MHz / GPS-Galileo 1575MHz / GLONASS 1602MHz
Pin Mount
Dimensions: 35mm*35mm*6.5mm
RoHS & Reach Compliant
SPE-14-8-018-G
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
2D Radiation Patterns
9
5.
Mechanical Drawing
12
6.
Evaluation Board Drawing
13
7.
Footprint
14
8.
Packaging
15
Changelog
17
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
© Taoglas
SPE-14-8-018-G
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
Introduction
The Taoglas CGGBP.35.6.A.02 is a Circularly Polarized embedded GNSS patch designed for use across the full
single band GNSS spectrum.
This 35mm square ceramic GPS/GLONASS/Galileo/BeiDou patch antenna's wide band of operation leads to
excellent gain and radiation pattern stability on all GNSS system bands.
Introduction
1.
Typical applications include:
- Agriculture
- Asset tracking systems
- Navigation
1.
Compared to using a smaller antenna, this will translate into the GNSS system having much higher location
accuracy, improved reliability of lock in urban areas, better signal reception, with more satellites acquired
and a quicker time to first fix.
Introduction
Introduction
The patch is mounted via pin and double-sided adhesive and can be custom tuned to a device subject to NRE,
for further information please contact your regional Taoglas customer support team.
SPE-14-8-018-G
www.taoglas.com
3
2.
Specifications
GNSS Frequency Bands Covered
L1
L2
L5
L6
3. GPS/QZSS
Antenna
Characteristics2.
1575.42MHz
1227.6MHz
1176.45MHzSpecifications
1278.75MHz
GLONASS
3.
L5R
1176.45MHz
L3PT
1201.5MHz
L2PT
1246MHz
L1CR
1575.42MHz
L1PT
1602MHz
E4
1215MHz
E3
1256MHz
E6
1278.75MHz
E2
1561MHz
L1
1575.42MHz
Antenna□ Characteristics
Galileo
E5a
1176.45MHz
E5b
1201.5MHz
Antenna□ Radiation
Patterns3.Antenna
4.
BeiDou
B1
1561MHz
B2
1207.14MHz
E5B(B2)/ E6(B3)
1268.56MHz
E2(B1)
1561MHz
Characteristics2.
Compass
B3
1268.52MHz
Specifications
Antenna□ Characteristics2.
3.
SBAS
Omnistar
1542.5MHz
WAAS/EGN OS
1575.42MHz
Specifications
3.
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-14-8-018-G
Specifications
www.taoglas.com
4
GNSS Electrical
Frequency (MHz)
1561
1575.42
1602
Average Gain (dB)
-0.2
-0.3
-0.2
Efficiency (%)
97
94
95
Peak Gain (dBi)
5.8
5.5
5.6
Axial Ratio (dB)
13
9
3
Polarization
RHCP
Impedance
50Ω
Mechanical
Dimensions
35 x 35 x 6.5mm
Material
Ceramic
Pin Diameter
0.9mm
Pin Length
2.4mm
Weight
29g
Environmental
Temperature Range
SPE-14-8-018-G
-40°C to 85°C
www.taoglas.com
5
3.
3.1
4.
Return Loss
Characteristics
4.
Return Loss [dB]
-5
-10
-15
-20
Characteristics
-25
1500
1525
1550
1575
1600
1625
1650
1675
1700
Frequency [MHz]
4.
Characteristics
3.2
Efficiency
100
4.
90
Antenna
Radiation Patterns
80
4.
4.
Efficiency [%]
70
60
Antenna
Radiation Patterns
50
40
30
Antenna
Radiation Patterns
4.
Antenna
1300 1350Radiation
1400 1450Patterns3.Antenna
1500 1550 1600 1650
Characteristics
4.
1750
1800
1850
1900
Frequency [MHz]
SPE-14-8-018-G
1700
www.taoglas.com
6
3.3
Average Gain
Aver Gain [dB]
-2
-3
-4
-5
-6
-7
-8
1300
1350
1400
1450
1500
1550
1600
1650
1700
1750
1700
1750
1800
1850
1900
Frequency [MHz]
3.4
Peak Gain
7
6
5
Gain [dBi]
4
3
2
1
-2
1300
1350
1400
1450
1500
1550
1600
1650
1800
1850
1900
Frequency [MHz]
SPE-14-8-018-G
www.taoglas.com
7
3.5
VSWR
11
VSWR
9
7
5
3
1
1500
1550
1600
1650
1700
Frequency [MHz]
3.6
Axial Ratio
SPE-14-8-018-G
www.taoglas.com
8
4.
4.
4.
4.1
Test Setup
4.
4.
4.
4.
4.
4.
Y
X
Z
On Evaluation Board
SPE-14-8-018-G
www.taoglas.com
9
XY Plane
XZ Plane
SPE-14-8-018-G
www.taoglas.com
10
YZ Plane
SPE-14-8-018-G
www.taoglas.com
11
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-018-G
Mechanical Drawing
www.taoglas.com
12
6.
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-14-8-018-G
www.taoglas.com
13
7.
Footprint
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-14-8-018-G
www.taoglas.com
14
8.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
12 pieces per tray
6 Trays per Inside Box = 72
7.4 InsideApplication
Packaging
Boxes per OuterNote6.
Carton -Outer
Carton contains 288 pieces
7.
Mechanical
Drawing
6.
Packaging5.
SPE-14-8-018-G
Mechanical Drawing
www.taoglas.com
15
SPE-14-8-018-G
www.taoglas.com
16
Changelog for the datasheet
SPE-14-8-018 – CGGBP.35.6.A.02
Revision: G (Current Version)
Date:
Changes:
Changes Made by:
2021-06-08
Pin Length changed to 2.4mm
Drawing updated
Dan Cantwell
Previous Revisions
Revision: F
Revision: A (Original First Release)
Date:
Changes:
Changes Made by:
2020-01-27
Installation Guide Amended
Jack Conroy
Date:
Notes:
2014-03-04
Author:
Aine Doyle
Revision: E
Date:
Changes:
Changes Made by:
2018-03-27
Jack Conroy
Revision: D
Date:
Changes:
Changes Made by:
2017-06-27
David Connolly
Revision: C
Date:
Changes:
Changes Made by:
2015-01-06
PCB Footprint
Made by Andy Mahoney
Revision: B
Date:
Changes:
Changes Made by:
SPE-14-8-018-G
2014-11-17
Evaluation Board Added
Aine Doyle
www.taoglas.com
17
www.taoglas.com
© Taoglas
SPE-14-8-018-G
www.taoglas.com
18
很抱歉,暂时无法提供与“CGGBPD.35.A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+838.41480
- 200+334.54080
- 国内价格 香港价格
- 1+340.309511+44.11060
