CAD.50
CAD.50
    TAOGLASLIMITED
    EVAL FOR CA.50
CAD.50 数据手册
Part No: CA.50 Description: 5150-5900 MHz Ceramic Chip Monopole Wi-Fi Antenna Features: Dimensions: 3.2mm *1.6mm * 0.5mm Low profile Peak gain 3.4 dBi Compact Size RoHS & Reach Compliant SPE-12-8-109-D 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing – Antenna 10 6. Mechanical Drawing – Evaluation Board 11 7. Antenna Integration Guide 12 8. Soldering Conditions 13 9. Packaging 14 Changelog 15 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-12-8-109-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Taoglas´ 5150-5900 MHz ceramic chip antenna is specifically designed for Wi-Fi/ WHDMI/ High Bandwidth 5GHz Wi-Fi band applications. It is a high efficiency miniature SMD edge mounted ceramic monopole antenna with small footprint requirement. This ceramic chip antenna uses the main PCB as its ground plane, thereby increasing antenna efficiency. It is tuned for different PCB sizes by simply changing the value of the matching circuit. The CA.50’s electrical properties are symmetrical therefore the antenna can be soldered to the board from either side. At 3.2mm*1.6mm*0.5mm, it is one of the smallest antennas available worldwide. This antenna is delivered on tape and reel. Introduction Introduction Typical Applications Include: - USB Dongles - High Bandwidth Video Transmission - WHDMI PCMCIA Cards - Wearables - Smart Healthcare Introduction Introduction Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. SPE-12-8-109-D www.taoglas.com 3 For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. This antenna can be mounted with no performance degradation in either orientation as long as the antenna is soldered correctly via Surface mounting. Please see the integration instructions section for further detail regarding the optimum way to integrate this antenna into your device For further information on how to integrate this product, please contact your regional Taoglas customer support team. SPE-12-8-109-D www.taoglas.com 4 2. Specifications 3. Antenna Characteristics2. LTE Antenna Specifications Frequency (MHz) 3. 5000 5100 5400 5500 5600 5700 5800 5900 69.7 80 72.4 65.6 74.5 55.9 Antenna Radiation -1.75Patterns3. -1.8 -1 Antenna -1.8 -1.6 -1 -1.4 -1.8 -1.3 -2.5 3.4 3.1 2.8 3.6 2.6 Antenna Characteristics 40 x 40 mm Ground Plane 66.8 65.8 5200 5300 Efficiency (%) 78.9 65.6 Average Gain (dB) 4. 40 x 40 mm Ground Plane Characteristics2. 40 x 40 mm Ground Plane Peak Gain (dBi) Specifications 2.7 2 3.2 2.3 2.8 VSWR 3. 3. 2 max. Antenna Impedance (Ω)Characteristics2. Specifications 50Ω Polarization Linear Radiation Pattern Omni Input Power(W) Antenna Characteristics 50 Mechanical Dimensions (mm) 4. 3.2 x 1.6 x 0.5 Ground plane (mm) Antenna Radiation Patterns3.Antenna 40 x 40 Material Characteristics 4. AS 6 Mechanical Temperature Range -40°C to 85°C Temperature Coefficient of Frequency (ppm/°C) 0±20 max. (@-40°C to 85°C) Antenna Radiation Patterns Humidity Moisture Sensitivity Level 4. Non-condensing 65°C 95% RH 3 (168 Hours) Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-12-8-109-D Specifications www.taoglas.com 5 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-12-8-109-D www.taoglas.com 6 3.2 Smith Chart 3.3 Efficiency SPE-12-8-109-D www.taoglas.com 7 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup – 40 x 40 mm Ground Plane 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Y X 4. Antenna Radiation Patterns Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4.2 5150MHz Radiation Patterns XY Plane SPE-12-8-109-D XY Plane Flipped XZ Plane www.taoglas.com 8 4.3 5350MHz Radiation Patterns XY Plane 4.4 XY Plane Flipped XZ Plane XY Plane Flipped XZ Plane XY Plane Flipped XZ Plane 5700MHz Radiation Patterns XY Plane 4.5 5850MHz Radiation Patterns XY Plane SPE-12-8-109-D www.taoglas.com 9 5. Mechanical Drawing – Antenna 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-109-D Mechanical Drawing www.taoglas.com 10 6. Mechanical Drawing – Evaluation Board 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-109-D Mechanical Drawing www.taoglas.com 11 7. Antenna Integration Guide 7.1 Solder Land Pattern 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging 7.2 Mechanical Drawing Matching Circuit (Center frequency is 5500MHz at 40x40mm ground plane) 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-109-D Mechanical Drawing www.taoglas.com 12 8. Soldering Conditions Typical Soldering profile for lead-free process: 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-109-D Mechanical Drawing www.taoglas.com 13 9. Packaging Quantity: 6000pcs per reel 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-12-8-109-D Mechanical Drawing www.taoglas.com 14 Changelog for the datasheet SPE-17-8-042 – CA.50 Revision: D (Current Version) Date: Changes: Changes Made by: 2021-09-02 Updated MSL and Template (font) Erik Landi Previous Revisions Revision: C (Current Version) Date: Changes: Changes Made by: 2020-06-02 Updated Packaging and Template Jack Conroy Revision: B Date: Changes: Changes Made by: 2015-08-21 Amended Intro Aine Doyle Revision: A (Original First Release) Date: 2012-08-14 Notes: Initial Release Author: Wayne Yang SPE-12-8-109-D www.taoglas.com 15 www.taoglas.com SPE-12-8-109-D © Taoglas 16 www.taoglas.com
CAD.50 价格&库存
很抱歉,暂时无法提供与“CAD.50”相匹配的价格&库存,您可以联系我们找货
