PCSD.07.A
PCSD.07.A
    TAOGLASLIMITED
    LOW PRO CELL SMD DILCTRC ANTNA
PCSD.07.A 数据手册
Part No: PCS.07.A Description: Low Profile Cellular SMD Dielectric Antenna 824~960MHz/1710~2170MHz Features: High Efficiency Multi-Band SMD antenna Low profile 35mm * 7mm * 3mm CE Certified RoHS & Reach Compliant SPE-13-8-028-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing 10 6. Evaluation Board Drawing 11 7. Footprint 12 8. Matching Circuit 13 9. Solder Reflow Recommendations 14 10. Packaging 15 11. Application Note 17 Changelog 20 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-13-8-028-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction is a low profile SMT cellular antenna designed for direct SMT mount on the device PCB. It provides 1.The PCS.07.A Introduction highest efficiency in very small factor 35*7*3mm. It is more resistant to detuning compared to other antenna integrations. If tuning is required it can be tuned for the device environment, while there is no need for new tooling. Its rectangular shape and very small size makes it very easy to integrate – can be mounted directly on the edge of the PCB board. 1. Introduction The PCS.07 antenna is suitable for lower cost cellular applications and is especially suitable for telematics and automotive sector. If higher efficiency or improved radiated spurious emissions are required, especially on smaller ground-planes, please use our PA series antennas, PA.26 or PA.710. For further information, please contact your regional Taoglas customer support team. 1. Introduction 1. Introduction SPE-13-8-028-E www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Frequency (MHz) 824~896 Specifications Cellular 880~960 1710~1880 1850~1990 1920~2170 2.90 2.83 2.57 -2.50 -2.68 -2.42 45.14 52.82 50.11 < -5 < -7 < -6 Peak Gain (dBi) 3. Antenna Characteristics On EVB -1.96 -1.77 Average Gain (dB) On EVB 4. -4.68 -4.44 Efficiency (%) Antenna Radiation Patterns3. Antenna On EVB Characteristics2. On EVB 32.02 31.06 Specifications Return Loss (dB) < -3 < -4 Impedance 3. 50Ω Antenna Polarization Characteristics2. Specifications Linear Radiation Pattern Omni Mechanical 3. 4. Antenna Characteristics Antenna Dimensions 35mm x 7mm x 3mm Material Polymer Soldering Type SMT through Reflow Antenna Radiation Patterns3. Antenna Environmental Temperature Range -40°C to 85°C Moisture Sensitivity Level (MSL) 3 (168 Hours) Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-13-8-028-E Specifications www.taoglas.com 4 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 – 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 77 3300 to 4200 78 3300 to 3800 79 4400 to 5000 SPE-13-8-028-E Covered ✓ ✓ ✓ ✓ ✓  ✓ ✓      ✓ ✓ ✓   ✓  ✓ ✓ ✓      ✓  ✓      ✓      www.taoglas.com 5 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -2 -4 -6 4. Antenna Radiation Patterns (dB) -8 4. -10 -12 Antenna Radiation Patterns3.Antenna -14 Characteristics -16 Return Loss -18 -20 Antenna Patterns3. 800 Radiation 1000 1200 1400 Antenna 1600 4. 1800 2000 2200 (MHz) Characteristics 3.2 Efficiency 100 4. Antenna Radiation Patterns 4. 4. Efficiency (%) 80 Antenna Radiation Patterns 60 40 Antenna Radiation Patterns 20 4. Antenna Radiation Patterns3.Antenna Efficiency Characteristics 0 500 4. 1000 1500 Antenna Radiation Patterns3.Antenna SPE-13-8-028-E 2000 2500(MHz) www.taoglas.com 6 3.3 Average Gain 0 Average Gain (dB) -2 -4 -6 -8 -10 Average Gain -12 500 3.4 1000 1500 2000 2500 (MHz) Peak Gain 6 Maximum Gain (dBi) 4 2 0 -2 -4 -6 Maximum Gain -8 -10 500 SPE-13-8-028-E 1000 1500 2000 2500 (MHz) www.taoglas.com 7 4. Radiation Patterns 4. 4. 4. 4.1 Antenna Radiation Patterns Test Setup on Evaluation Board Antenna Radiation Patterns Y 4. Antenna Radiation Patterns X Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-13-8-028-E www.taoglas.com 8 4.2 2D Radiation Patterns 824-960MHz XZ Plane YZ Plane XY Plane 1710-2170MHz XY Plane SPE-13-8-028-E XZ Plane YZ Plane www.taoglas.com 9 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-028-E Mechanical Drawing www.taoglas.com 10 6. Evaluation Board Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-028-E Mechanical Drawing www.taoglas.com 11 7. Footprint 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-028-E www.taoglas.com 12 8. Matching Circuit 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-028-E www.taoglas.com 13 9. Solder Reflow Recommendations The PCS.07.A can be assembled by following the recommended soldering temperatures are as follows: 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging Mechanical Drawing *Temperatures listed within a tolerance of +/- 10º C is not limited to the number of passes through the reflow process. Smaller components 7.The PCS.07.A Application Note6. Packaging are typically mounted on the first pass, however, we do advise mounting the PCS.07.A when placing larger components on the board during subsequent reflows. 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-028-E Mechanical Drawing www.taoglas.com 14 8. Packaging 10. 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-028-E Mechanical Drawing www.taoglas.com 15 SPE-13-8-028-E www.taoglas.com 16 11. Application Note Investigations of PCS.07.A antenna performance on different lengths of ground plane were conducted, the results are shown below. 4. Antenna Radiation Patterns3.Antenna 11.1 Return Loss Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 11.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-028-E www.taoglas.com 17 11.3 Peak Gain 11.4 Average Gain SPE-13-8-028-E www.taoglas.com 18 Changelog for the datasheet SPE-13-8-042 – PCS.07.A Revision: F (Current Version) Date: Changes: Changes Made by: 2021-09-09 Solder Reflow Recommendations Amended. Gary West Previous Revisions Revision: E Date: Changes: Changes Made by: 2021-09-09 Added MSL rating, updated font. Erik Landi Revision: D Date: Changes: Changes Made by: 2020-12-01 Updated Format and Drawing Jack Conroy Revision: C Date: Changes: Changes Made by: 2018-10-23 Updated Drawing David Connolly Revision: B Date: Changes: Changes Made by: 2013-08-11 Drawing Updated Aine Doyle Revision: A (Original First Release) Date: Notes: 2013-04-11 Author: Wayne Yang SPE-13-8-028-E www.taoglas.com 19 www.taoglas.com SPE-13-8-028-E © Taoglas 20 www.taoglas.com
PCSD.07.A 价格&库存
很抱歉,暂时无法提供与“PCSD.07.A”相匹配的价格&库存,您可以联系我们找货
