169 MHz VHF Polymer Substrate Chip Monopole
Part No:
Antenna
CA.69
Description:
25.2*5.1*0.8mm CA.69 169MHz 7dBi Polymer Substrate Chip Antenna
Features:
169 MHz VHF Polymer Substrate Chip Monopole Antenna
Peak Gain – approx. -7 dBi (on evaluation board)
Efficiency 10~15% (on evaluation board)
Low Profile
Dimensions: 25.2*5.1*0.8mm
RoHS & REACH Compliant
SPE-13-8-077-B
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Patterns
7
5.
Mechanical Drawing
9
6.
Layout Guide
11
7.
Soldering Conditions
12
8.
Packaging
13
9.
Changelog
14
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-13-8-077-B
www.taoglas.com
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
The CA.69 Polymer Substrate Chip Antenna from Taoglas, 169 MHz is specifically designed for VHF 169MHz
band applications. It is a high efficiency miniature SMD edge mounted antenna with small footprint
requirement. This chip antenna uses the main PCB as its ground plane, thereby increasing antenna efficiency.
It is tuned for different PCB sizes by simply changing the value of the matching circuit. CA.69 antenna
electrical properties are symmetrical therefore the antenna can be soldered to the board from either side.
Introduction
Introduction
This antenna is delivered on tape and reel. Small low frequency antennas such as CA.69 need to be carefully
tuned and integrated into devices to perform optimally given the narrow band tuning required, so contact
your regional Taoglas sales office for support on gerber review of your layout, advice on ground-plane layout
and transmission line design. Taoglas also recommends we test your final device prototype with CA.69 on
board and provide final matching values.
Introduction
Taoglas has tested the CA.69 mounted in realistic conditions in metal or semi metal meter housings with the
latest high power modules from Telit and achieved read ranges of more than one hundred metres.
Introduction
Applications:
VHF Band Applications
SPE-13-8-077-B
www.taoglas.com
2.
Specifications
3.
Antenna Characteristics2.
Specifications
Antenna
Frequency (MHz)
3.
4.
Bandwidth (MHz)
Antenna
Characteristics
8 (under -10dB Return Loss)
VSWR
2 max.
Impedance (Ω)
50Ω
Antenna
Polarization Radiation Patterns3.Antenna Linear
Radiation Pattern
Characteristics2.
3.
169 MHz
Omni
Specifications
Mechanical
Dimensions (mm)
25.2 x 5.1 x 0.8
Ground plane (mm)
110 x 55 (Recommended)
Antenna
Characteristics2.
Material
Specifications
Polymer Substrate
Mechanical
Temperature Range
3.
-40°C to 85°C
Antenna
Humidity Characteristics
Moisture Sensitivity Level (MSL)
4.
20% to 70% RH
3 (168 Hours)
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-13-8-077-B
Specifications
www.taoglas.com
3.
3.1
4.
Return Loss
Characteristics
4.
4.
Characteristics
*The antenna tuning depends on different antenna ground plane application. Taoglas provides
and CAD.B.69 evaluation boards to show performance when antenna is parallel mounted to
4.CAD.A.69
Antenna
the ground plane or when it is orthogonally mounted to the ground-plane.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-13-8-077-B
www.taoglas.com
3.2
Efficiency
3.3
Peak Gain
SPE-13-8-077-B
www.taoglas.com
4.
4.
Radiation Patterns
4.1
Test Setup – Antenna on Evaluation Board
Antenna Radiation PatternsCAD.A.69
4.
4.
4.
4.
Antenna Radiation PatternsCAD.B.69
4.
4.
SPE-13-8-077-B
www.taoglas.com
4.2
169 MHz Radiation Patterns
XY Plane
XY Plane Flipped
XZ Plane
Z
Z
X
Y
SPE-13-8-077-B
X
Y
www.taoglas.com
5.
Mechanical Drawing
5.1
Antenna Main Body
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical
Drawing
5.2
CAD.A.69 Application
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-077-B
Mechanical Drawing
www.taoglas.com
5.2
CAD.B.69 Application
SPE-13-8-077-B
www.taoglas.com
6.
Layout Guide
6.1
Solder Land Pattern
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
6.
Packaging
7.
6.2
6.3
Mechanical Drawing
Matching circuit CAD.A.69
Matching circuit CAD.B.69
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-077-B
Mechanical Drawing
www.taoglas.com
7.
Typical Soldering profile for lead-free process:
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-077-B
Mechanical Drawing
www.taoglas.com
9.
Packaging
Quantity: 4000pcs/ Reel
6.
Packaging5.
6.
Packaging
Mechanical Drawing
7.Tape Dimensions
Application
Note6. Packaging5.
(unit: mm)
Feature
Specification
Drawing
W
44.00
P
E
F
P2
D
D1
Po
10Po
6.
6.
8.00
1.75
20.20
2.00
1.50
2.00
4.00
40.00
Packaging5.
1.
2.
3.
4.
5.
6.
Tolerance
±0.30
±0.10
±0.10
±0.10
±0.10
+0.10 / -0.00
±0.10
±0.10
±0.20
Mechanical
Pocket Dimensions (unit: mm)
Feature
Ao
Bo
Ko
t
Mechanical Drawing
Specification
5.3
25.45
1.50
0.30
Tolerance
+0.10
-0.10
±0.05
±0.05
Cumulative tolerance of 10 pocket hole pitch: ±0.20mm
Packaging
Carrier camber not to exceed 1mm in 250mm
Ao and Bo measured on a plane above the inside bottom of the pocket
Ko measured from a plane on the inside bottom of the pocket to the top surface of the carrier
All dimensions meet EIA-481-B requirements
Material – Clear non Anti-Static Polystyrene, Black Conductive Polystyrene
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-13-8-077-B
Mechanical Drawing
www.taoglas.com
Changelog for the datasheet
SPE-13-8-077– CA.69
Revision: B (Current Version)
Date:
Changes:
Changes Made by:
2021-10-05
Format Change, MSL
Erik Landi
Previous Revisions
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-13-8-077-B
2017-10-11
Initial Release
STAFF
www.taoglas.com
SPE-13-8-077-B
© Taoglas
www.taoglas.com
很抱歉,暂时无法提供与“CAD.B.69”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+340.826511+44.11060
