SDWAD.01
SDWAD.01
    TAOGLASLIMITED
    KIT EVAL FOR SDWA.01
SDWAD.01 数据手册
Part No: SDWA.01 Description: 2.4/5-7.125GHz Wi-Fi (Including Wi-Fi 6) Ceramic SMD Antenna Features: High Efficiency/ High Peak Gain 2400-2500MHz, 5150-5825MHz, 5925-7125MHz Wi-Fi coverage Covers newly established Wi-Fi 6 spectrum for future proof design Small Footprint Low Profile Dimensions: 10*4*1.5mm RoHS & Reach Compliant SPE-11-8-129-L 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 8 5. Mechanical Drawing 10 6. Evaluation Board Drawing 11 7. Matching Circuit 12 8. Recommended Soldering Conditions 13 9. Packaging 14 Changelog 15 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-11-8-129-L www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. The SDWA.01 SMD ceramic antenna is an embedded, high efficiency, high peak gain solution for Wi-Fi applications which require high-speed data rates and wide coverage areas. Designed for the 2.4 GHz, 5.8 GHz and 7.125GHz bands. The antenna covers the newly established Wi-Fi 6 spectrum for future proof design. It is designed to perform optimally mounted in the corner of a device PCB. Two SDWA.01 antennas can be used for MIMO applications. The antenna's low profile, at only 1.5mm, allows for use on extremely thin devices while still maintaining excellent performance characteristics. This antenna is delivered on Tape and Reel for SMD application. Introduction Introduction Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free space can degrade by at least 1 or 2dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Introduction Introduction Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2dBi peak gain, but you don’t need to select an embedded antenna that has a peak gain of less than 2dBi in free space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. For further information, please contact your regional Taoglas customer support team. SPE-11-8-129-L www.taoglas.com 2. Specifications 3. Antenna Characteristics2.Wi-Fi Electrical Specifications 3. 4. Band Frequency (MHz) Efficiency (%) Average Gain (dB) Peak Gain (dBi) 2.4GHz Wi-Fi 2400~2500 55.7 -2.5 3 5.8GHz Wi-Fi 5150~5850 66.2 -1.9 5.9 7.1GHz Wi-Fi 6 5925~7125 44.7 -3.6 4.9 Antenna Characteristics Impedance Polarization 50 Ω Linear Radiation Pattern Omni-Directional Antenna Radiation Patterns3.Antenna Characteristics2. Specifications Mechanical Height 3. 1.5 mm Planner Dimension Antenna Characteristics2. 10 x 4 mm Specifications Material 3. Ceramic Evaluation Board Dimensions Antenna Characteristics 100mm*50mm Weight 4. 1g Environmental Antenna Radiation Patterns3.Antenna-40°C to +85°C Operation Temperature Characteristics Storage Temperature 4. 4. -40°C to +105°C Temperature Coefficient (τf) 0 ± 20 ppm @-20ºC to +80ºC Humidity Non-condensing 65°C 95% RH Recommended Reel Storage Conditions 5°C to 40°C Relative Humidity 20% to 70% Moisture Sensitivity Level (MSL) 3 (168 Hours) Antenna Radiation Patterns Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-11-8-129-L Specifications www.taoglas.com 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna 0 Characteristics -1 -2 -3 4. 4. Return Loss (dB) -4 Antenna Radiation Patterns -5 -6 -7 -8 -9 Antenna Radiation Patterns3.Antenna -10 -11 Characteristics -12 S11 (SDWA.01) -13 -14 4. -15 2200 2700 3200 3700 4200 4700 5200 Antenna Radiation Patterns3. Antenna Frequency (MHz) 5700 6200 6700 7200 5700 6200 6700 7200 Characteristics 3.2 VSWR 10 4. Antenna Radiation Patterns 9 8 7 Antenna Radiation Patterns 6 VSWR 4. 4. 5 4 Antenna Radiation Patterns 3 2 VSWR… 4. 1 Antenna Radiation Patterns3.Antenna 0 2200 2700 Characteristics 4. 3200 3700 4200 4700 5200 Frequency (MHz) Antenna Radiation Patterns3.Antenna SPE-11-8-129-L www.taoglas.com 3.3 Efficiency 100 90 80 Efficiency (%) Efficiency (%) 70 60 50 40 30 20 10 0 2200 2700 3200 3700 4200 4700 5200 5700 6200 6700 7200 5700 6200 6700 7200 Frequency (MHz) 3.4 Peak Gain 10 9 8 7 Peak Gain (dBi) 6 Peak Gain (dBi) 5 4 3 2 1 0 -1 -2 -3 -4 -5 2200 2700 3200 3700 4200 4700 5200 Frequency (MHz) SPE-11-8-129-L www.taoglas.com 3.5 Average Gain 0 -1 -2 Average Gain (dB) Average Gain (dB) -3 -4 -5 -6 -7 -8 -9 -10 2200 2700 3200 3700 4200 4700 5200 5700 6200 6700 7200 Frequency (MHz) SPE-11-8-129-L www.taoglas.com 4. 2D Radiation Patterns 4. 4. 4. 4.1 Antenna Radiation Patterns Test Setup – On Eval Board Antenna Radiation Patterns Z 4. Antenna Radiation Patterns Y 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-11-8-129-L X www.taoglas.com 4.2 2D Radiation Patterns 2400-2500MHz XY Plane XZ Plane X YZ Plane Z Z 5 0 -5 -10 -15 -20 -25 -30 Y 5 0 -5 -10 -15 -20 -25 -30 X 5 0 -5 -10 -15 -20 -25 -30 Y 2400 MHz 2400 MHz 2400 MHz 2450 MHz 2450 MHz 2450 MHz 2500 MHz 2500 MHz 2500 MHz 5000-7000MHz XY Plane XZ Plane X 5 0 -5 -10 -15 -20 -25 -30 Y 5000 MHz 5500 MHz 6000 MHz 6500 MHz 7000 MHz SPE-11-8-129-L 5 0 -5 -10 -15 -20 -25 -30 YZ Plane Z Z X 5000 MHz 5500 MHz 6000 MHz 6500 MHz 7000 MHz 5 0 -5 -10 -15 -20 -25 -30 Y 5000 MHz 5500 MHz 6000 MHz 6500 MHz 7000 MHz www.taoglas.com 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-11-8-129-L Mechanical Drawing www.taoglas.com 6. Evaluation Board Drawing 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-11-8-129-L www.taoglas.com 7. Matching Circuit Like all antennas, surrounding components, enclosures, and changes to the GND plane dimensions can alter 4. Antenna Radiation Patterns3.Antenna performance. A pi-matching network like the one shown below is required in case adjustments need to be made. Make S1 a zero ohm resistor and leave S2 and S3 unpopulated when building first prototypes. These components Characteristics will likely need to be adjusted upon integration to provide the best match between the antenna and transmission line. The additional zero ohm resistor in the diagram is needed for the ability to solder down a coax pigtail to make with a vector network analyzer. 4.measurements Antenna Radiation Patterns Antenna 4. Antenna Radiation Patterns3.Antenna Characteristics 0 Ohm Resistor S1 Transmission Line S3 Antenna Radiation Patterns3.Antenna S2 4. Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-11-8-129-L www.taoglas.com 8. Recommended Soldering Conditions 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4.1. 2. 3. Time shown in the above figures is measured from the point when chip surface Antenna Radiation Patterns3. Antenna reaches temperature. Temperature difference in high temperature part should be within 110°C. After soldering, do not force cool, allow the parts to cool gradually. Characteristics *General attention to soldering: ● High soldering temperatures and long soldering times can cause leaching of the termination, decrease in adherence strength, and the change of characteristic may occur. ● for soldering, please refer to the soldering curves above. However, please Keep exposure to temperatures exceeding 200°C to under 50 seconds. ● please use a mild flux (containing less than 0.2wt% Cl). Also, if the flux is water soluble, be sure to wash thoroughly to remove any residue from the underside of components that could affect resistance. 4. Antenna Radiation Patterns Cleaning: using ultrasonic cleaning, the boardPatterns may resonate if the output power is too high. 4.When Antenna Radiation Since this vibration can cause cracking or a decrease in the adherence of the termination, we recommend that you use the conditions below. Frequency: 40 kHz max. Output power: 20W/Iiter Cleaning time: 5minutes max. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 8. Packaging 4. 6. Antenna Radiation Patterns3.Antenna Packaging5. Mechanical Drawing SPE-11-8-129-L www.taoglas.com 6. 6. Packaging 1000pcs SDWA.01 per Tape & Reel Packaging5. Mechanical Drawing Ø330mm 9. Packaging 28.4mm SDWA.01 per carton Note6. Packaging5. 7. 1000pcs Application Mechanical Dimensions - 350*340*47mm Drawing 6. Packaging5. 47mm Mechanical Drawing 350mm 6. 340mm Packaging 5000pcs SDWA.01 per carton Dimensions - 370*370*300mm 7. Application Note6. Packaging 300mm 7. Application Note 370mm 7. Application Note6. Packaging 7. Application Note6. Packaging5. 370mm Mechanical Drawing 6. Packaging5. SPE-11-8-129-L Mechanical Drawing www.taoglas.com Changelog for the datasheet SPE-11-8-129 – SDWA.01 Revision: L (Current Version) Date: Changes: Changes Made by: 2022-05-13 Updated Packaging Jack Conroy Previous Revisions Revision: K (Current Version) Date: Changes: Changes Made by: 20208-09-03 Added Wi-Fi 6 test data Jack Conroy Revision: J Revision: F Date: Changes: Changes Made by: 2016-03-08 Amended SPQ Aine Doyle Revision: E Date: Changes: Changes Made by: 2019-06-11 Evaluation Board Drawing Updated Jack Conroy Revision: I Date: Changes: Changes Made by: 2015-08-20 Packaging Details Updated Aine Doyle Revision: D Date: Changes: 2019-08-26 EC-19-8-071 Date: Changes: Changes Made by: Jack Conroy Changes Made by: Revision: H 2015-03-02 Amended Drawing Aine Doyle Revision: C Date: Changes: Changes Made by: 2018-03-08 Packaging Details Updated Made by Andy Mahoney Revision: G Date: Changes: Changes Made by: 2013-11-08 Amended Reel Quantity Aine Doyle Revision: B Date: Changes: Changes Made by: SPE-11-8-129-L 2017-03-08 Packaging Details Updated Aine Doyle Date: Changes: Changes Made by: 2013-08-19 Packaging Details Updated Aine Doyle www.taoglas.com Revision: A (Original First Release) Date: 2017-10-27 Notes: Author: SPE-11-8-129-L Technical Writer www.taoglas.com SPE-11-8-129-L © Taoglas www.taoglas.com
SDWAD.01 价格&库存
很抱歉,暂时无法提供与“SDWAD.01”相匹配的价格&库存,您可以联系我们找货
SDWAD.01
    • 1+838.41480
    • 200+334.54080
