SPECIFICATION
Part No.
CGGBP.18.4.A.02
Product Name
18mm*18mm*4mm
GPS/GLONASS/Galleo/BeiDou
Embedded Patch Antenna
GPS-Galileo 1575MHz / BeiDou 1561MHz /
GLONASS 1602MHz
Feature
Dielectric Ceramic
Pin Mount
RoHS Compliant
SPE-14-8-071/E/SS Page 1 of 15
1. Introduction
This 18mm*18mm square ceramic GPS/GLONASS/GALILEO/BEIDOU patch antenna's
wide band of operation leads to excellent gain and radiation pattern stability on all
three GNSS system bands.
Compared to using a smaller antenna, this will translate into the GNSS system having
much higher location accuracy, improved reliability of lock in urban areas, better
signal reception, with more satellites acquired and a quicker time to first fix.
The patch is mounted via pin and double-sided adhesive.
SPE-14-8-071/E/SS Page 2 of 15
2.
Specification
ELECTRICAL
BeiDou
Frequency
1561.098MHz ±
2.046MHz
GPS
GLONASS
1575.42 ± 1.023MHz
1602 ± 5MHz
VSWR
3.97 max.
1.97 max.
2.42 max.
Efficiency
55%
83.7%
87.6%
Peak Gain (dBi)
3.4 dBi typ.
4.9 dBi typ.
5.4 dBi typ.
Average Gain (dB)
-2.58 dB
-0.77 dB
-0.57 dB
Centre Frequency
1583MHz ± 3MHz
Impedance
50
MECHANICAL
Dimensions
18*18*4mm
Material
Ceramic
Pin Diameter
0.9mm
Pin Length
2.4mm
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 105°C
Humidity
Non-condensing 65°C 95% RH
*measured on a 70*70mm Ground Plane
SPE-14-8-071/E/SS Page 3 of 15
3. Antenna Characteristics
3.1. Test Setup
SPE-14-8-071/E/SS Page 4 of 15
3.2. Return Loss
3.3. VSWR
SPE-14-8-071/E/SS Page 5 of 15
3.4. Efficiency
3.5. Peak Gain
SPE-14-8-071/E/SS Page 6 of 15
3.6. Average Gain
3.7. Axial Ratio
SPE-14-8-071/E/SS Page 7 of 15
4. 2D Antenna Radiation
4.1. Test Setup
SPE-14-8-071/E/SS Page 8 of 15
4.2. Radiation Pattern
XY Plane
XZ Plane
YZ Plane
SPE-14-8-071/E/SS Page 9 of 15
5. Mechanical Drawing
SPE-14-8-071/E/SS Page 10 of 15
5.1. Adhesive Thickness
Red Line shows the adhesive without Liner – thickness 0.08~0.1mm
SPE-14-8-071/E/SS Page 11 of 15
5.2. CGGBPD.18.A EVB
SPE-14-8-071/E/SS Page 12 of 15
CGGBP.18.4.A.02 Patch on 70*70mm Ground Plane
5.3. PCB Footprint Recommendation
SPE-14-8-071/E/SS Page 13 of 15
6. Packaging
6.1. Inner Tray
Per Tray: 25 pieces
25
pieces
per Tray
8 Tray’s
per
carton
SPE-14-8-071/E/SS Page 14 of 15
6.2. Carton
Per Carton (Inside Box) – 8 Trays = 200 pieces
Outer Carton (Outside Box)– 4 Cartons = 800 pieces
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice. Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-071/E/SS Page 15 of 15
很抱歉,暂时无法提供与“CGGBPD.18.A”相匹配的价格&库存,您可以联系我们找货
