AAE001
AAE001
    ZENTRI
    MARLIN BRD W/O AMW004-A01 HORNET
AAE001 数据手册
AAE001 (Marlin) Evaluation board provides a quick and easy way to evaluate and develop for the AMW004-A01 Hornet through-hole version of the AMW004 Wallaby module. T he AAE001 ‘Marlin’ evaluation board provides a quick and easy way to evaluate and develop using WiConnect on the through-hole versions of ACKme modules. Using the throughhole variants is a breeze with Marlin, simply plug the board into a computer using a standard USB cable, connect with a PC terminal application and start typing. In the case of Wi-Fi, the WiConnect application running on the Hornet module adapter provides basic ASCII commands to read the state of the buttons and turn the LEDs on and off. For a more compelling demo, connect the board to your Wi-Fi access point, signup at goHACK.me and control the board from across the room, or from the other side of the planet! The AAE001 comes in two configurations: AAE001 Bare bones, does not come with a radio module adapter fitted AMW004-E02 Comes complete with the AMW004-A01 Hornet module adapter (Wi-Fi) FEATURES Pluggable footprint compatible with ACKme Hornet module adapter USB-UART interface for a direct serial connection to the AMW004 Wi-Fi module Separate LEDs indicate data on UART transmit/receive Sensor interface including two buttons and two LEDs Manual reset switch Breakout headers and ground hooks for easy prototyping Powered by USB interface Adapter footprint 20-pin adapter compatible with ACKme through-hole modules USB UART Up to 3 Mbit/s with hardware flow control (optional) Sensor interface 2 x push buttons, 2 x LEDs Breakout header 2x10-pin header (connects to every pin on the Hornet adapter) Power supply +5V from USB (500mA max.) Operating Temperature 0 – 70°C © 2014 ACKme, Inc. | All rights reserved
AAE001 价格&库存
很抱歉,暂时无法提供与“AAE001”相匹配的价格&库存,您可以联系我们找货
