NL-AB-PMOD
NL-AB-PMOD
    NIMBELINK
    DEV ADAPTER KIT RENESAS RL78
NL-AB-PMOD 数据手册
Skywire​®​​ ​RL78/Kurumi​ ​Adapter User​ ​Manual NimbeLink​ ​Corp Updated:​ ​October​ ​2017 PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 1 Table​ ​of​ ​Contents Table​ ​of​ ​Contents 2 Introduction Product​ ​Overview Orderable​ ​Part​ ​Numbers Additional​ ​Resources Device​ ​Overview 3 3 3 3 4 Technical​ ​Specifications Electrical​ ​Specifications Operating​ ​Parameters Power Connection​ ​Descriptions 5 5 5 5 6 Operating​ ​Modes RL78/G13​ ​Demonstration​ ​Kit​ ​PMOD​ ​Adapter About Block​ ​Diagram Switch​ ​Configuration Connections SPI​ ​to​ ​UART​ ​Chip​ ​Configurations Board​ ​Orientation Renesas​ ​Kurumi​ ​Adapter About Block​ ​Diagram Switch​ ​Configuration Connections Board​ ​Orientation PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 7 7 7 7 8 8 8 9 9 9 10 10 11 11 2 1. Introduction 1.1 Product​ ​Overview This​ ​document​ ​is​ ​the​ ​Hardware​ ​Reference​ ​Manual​ ​for​ ​the​ ​Skywire®​ ​RL78/Kurumi Adapter.​ ​The​ ​Skywire​ ​RL78/Kurumi​ ​Adapter​ ​is​ ​designed​ ​to​ ​provide​ ​robust​ ​cellular connectivity​ ​for​ ​the​ ​Renesas​ ​RL78/G13​ ​Demonstration​ ​Kit​ ​and​ ​the​ ​Renesas​ ​Kurumi. The Skywire Cellular Modem at the heart of this adapter connects your M2M device to the Internet of things without the costs, delays, and hassles of federal and​ ​carrier​ ​certifications. The NimbeLink Skywire modem is available with bundled data plans from leading cellular​ ​carriers. 1.2 Orderable​ ​Part​ ​Numbers Orderable​ ​Device NL-AB-RL78 Description Skywire​ ​RL78/Kurumi​ ​Adapter​ ​Board NL-SW-1xRTT-V Skywire​ ​1xRTT​ ​Cellular​ ​Modem​ ​without​ ​data​ ​plan. 2G​ ​Modem. TG.30.8113 Primary​ ​&​ ​Diversity​ ​Cellular​ ​Antenna NL-SW-EVDO-V Skywire​ ​EVDO​ ​Cellular​ ​Modem​ ​without​ ​Data​ ​plan. 3G​ ​Modem. MA.301.A.AB.001 3G​ ​Primary​ ​Antenna.​ ​GPS/GLONASS​ ​Antenna​ ​for Skywire​ ​EVDO* Manufacturer Carrier NimbeLink NimbeLink Verizon CDMA 1xRTT Verizon CDMA 1xRTT Taoglas NimbeLink Taoglas 1.3 Additional​ ​Resources ● ● ● ● NimbeLink's​ ​Skywire2G​ ​1xRTT​ ​Product​ ​Page NimbeLink's​ ​Skywire​ ​3G​ ​CDMA/EVDO​ ​Product​ ​Page Telit’s​ ​CE910​ ​Hardware​ ​User​ ​Guide Telit’s​ ​DE910​ ​Hardware​ ​User​ ​Guide PN​ ​30018​ ​rev​ ​2 Networ k​ ​Type ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 3 1.4 Device​ ​Overview Top​ ​Side Bottom​ ​Side PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 4 2. Technical​ ​Specifications 2.1 Electrical​ ​Specifications 2.1.1 Operating​ ​Parameters Parameter Value Unit 115200 bps 1.65-5.5 V Skywire​ ​Power​ ​Consumption,​ ​Active​ ​Cell 750 mA Normal 29 mA Power​ ​Saving 1.1 mA Skywire​ ​Input​ ​Voltage 4 V 5 V PMOD​ ​Input​ ​Voltage 3.3 V 3.3 V Kurumi​ ​Input​ ​Voltage Temperature​ ​Range 4 -40​ ​to​ ​+85​o​C Skywire​ ​UART​ ​Baud​ ​Rate Skywire​ ​I/O​ ​Voltage J1​ ​Input​ ​Voltage PMOD​ ​I/O​ ​Voltage Dimensions 47​ ​x​ ​82​ ​x​ ​25 V C o​ mm 2.2 Power The Skywire RL78/Kurumi Adapter requires 5V and 3.3V inputs. Connector J1 accepts 5V input voltage and is used to supply power to the Skywire 4V Power Supply. The acceptable input Voltage range for J1 is 4.8-5.2V. Do not exceed 5.5V. The Skywire Cellular Modem will regularly consume high amounts of current (~750 mA) from the adapters power supply. It is recommended to have 1A of available​ ​source​ ​current​ ​available​ ​for​ ​the​ ​adapter​ ​board. PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 5 2.3 Connection​ ​Descriptions Designator SW1 J1 J2 J3 J4 J5 J6 J7 J8 J9 U4 PN​ ​30018​ ​rev​ ​2 Description Mode​ ​Selection​ ​Switch 5V​ ​Power​ ​IN,​ ​Barrel​ ​Jack Skywire​ ​Breakout​ ​Header Skywire​ ​Breakout​ ​Header PMOD​ ​Connector Current​ ​Test​ ​Point Skywire​ ​Breakout​ ​Header Renesas​ ​Kurumi​ ​Breakout​ ​Header Renesas​ ​Kurumi​ ​Breakout​ ​Header Renesas​ ​Kurumi​ ​Programming​ ​Header Renesas​ ​Kurumi​ ​Socket ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 6 3. Operating​ ​Modes 3.1 RL78/G13​ ​Demonstration​ ​Kit​ ​PMOD​ ​Adapter 3.1.1 About The PMOD interface on the Skywire RL78-Kurumi Adapter adheres to the Digilent PMOD specifications for Type 2A (Expanded SPI) PMOD Interface with a​ ​standard​ ​twelve-pin​ ​connector. The PMOD interface connects to the Renesas Demonstration Kit for the RL78/G13 (YRDKRL78G13) through the PMOD2 connector. The adapter’s onboard SPI to UART converter provides protocol translation allowing for the demonstrations kits Type 2A (Expanded SPI) PMOD Interface to communicate with​ ​the​ ​Skywire​ ​module. 3.1.2 Block​ ​Diagram PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 7 3.1.3 Switch​ ​Configuration SW1 is used to control the configuration mode of the adapter. To configure the adapter​ ​for​ ​use​ ​with​ ​the​ ​PMOD​ ​connection​ ​do​ ​the​ ​following: 1.​ ​Remove​ ​power​ ​from​ ​J1​ ​and​ ​the​ ​PMOD​ ​connection. 2.​ ​Place​ ​SW1.1-SW1.5​ ​in​ ​the​ ​on​ ​position. 3.​ ​Place​ ​SW1.6​ ​in​ ​the​ ​off​ ​position. 4.​ ​Configuration​ ​complete. 3.1.4 Connections The Skywire RL78-Kurumi Adapter connects to the RL78/G13 through a Type 2A (Expanded​ ​SPI)​ ​PMOD​ ​Interface.​ ​The​ ​table​ ​below​ ​describes​ ​the​ ​connections. PIN Signal Description 1 SS MOSI MISO SCK GND VCC Slave​ ​Select.​ ​Active​ ​low​ ​to​ ​enable​ ​slave​ ​device 2 3 4 5 6 7 8 9 10 Master​ ​Out​ ​Slave​ ​In.​ ​Data​ ​from​ ​master​ ​to​ ​slave Master​ ​In​ ​Slave​ ​Out.​ ​Data​ ​from​ ​slave​ ​to​ ​master Serial​ ​clock.​ ​Master​ ​provides​ ​the​ ​clock​ ​to​ ​shift​ ​the​ ​data INT RESET Skywire​ ​ON/OFF Skywire​ ​DTR 11 GND 12 VCC Interrupt​ ​signal​ ​from​ ​slave​ ​to​ ​master,​ ​connected​ ​to​ ​the​ ​SPI​ ​to UART​ ​converter​ ​chip Reset​ ​signal​ ​for​ ​master​ ​to​ ​reset​ ​SPI​ ​to​ ​UART​ ​converter Skywire​ ​On​ ​Off​ ​control​ ​line Skywire​ ​DTR​ ​signal 3.1.5 SPI​ ​to​ ​UART​ ​Chip​ ​Configurations To configure the XR20M1170 SPI to UART interface for communication between the PMOD interface (SPI) and the Skywire Cellular Modem (UART, 115200 bps) use the configuration sequence in the table below. The SPI interface from the host processor PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 8 should be configured to SPI MODE0, most Significant bit first, and the clocking rate must be​ ​16​ ​MHz​ ​or​ ​lower. Configuration​ ​Step Register Register​ ​Address 1 LCR 0x03 2 EFR 0x02 3 LCR 0x03 4 DLL 0x00 5 DLM 0x01 6 DLD 0x02 7 MCR 0x04 8 LCR 0x03 9 EFR 0x02 10 LCR 11 LCR Value Notes Configure​ ​LCR​ ​for​ ​EFR​ ​write 0x03 0xBF 0x10 0xB0 0x08 0x00 0x00 0x03 0xBF 0x00 0x03 0x02 0x07 Configure​ ​EFR Configure​ ​LCR​ ​for​ ​Baud​ ​rate​ ​config Configure​ ​baud​ ​rate​ ​for​ ​115200​ ​bps Configure​ ​baud​ ​rate​ ​for​ ​115200​ ​bps Configure​ ​baud​ ​rate​ ​for​ ​115200​ ​bps Configure​ ​clock​ ​prescaler Write​ ​LCR​ ​for​ ​EFR​ ​write Disable​ ​config​ ​mode Reset​ ​LCR​ ​for​ ​operation​ ​mode Enable​ ​and​ ​clear​ ​FIFOs 3.1.6 Board​ ​Orientation The adapter should be connected to the RL78/G13 Demonstration kit with the Skywire modem facing towards the demonstration kit as shown below or with a right​ ​angle​ ​adaptor​ ​with​ ​the​ ​Skywire​ ​Modem​ ​facing​ ​upwards. 3.2 Renesas​ ​Kurumi​ ​Adapter 3.2.1 About The​ ​Renesas​ ​Kurumi​ ​interface​ ​on​ ​the​ ​Skywire​ ​RL78-Kurumi​ ​Adapter​ ​provides​ ​a UART​ ​connection​ ​between​ ​the​ ​two​ ​boards. PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 9 3.2.2 Block​ ​Diagram 3.2.3 Switch​ ​Configuration SW1 is used to control the configuration mode of the adapter. To configure the adapter​ ​for​ ​use​ ​with​ ​the​ ​Renesas​ ​Kurumi​ ​do​ ​the​ ​following: 1.​ ​Remove​ ​power​ ​from​ ​J1​ ​and​ ​the​ ​PMOD​ ​connection. 2.​ ​Place​ ​SW1.1-SW1.5​ ​in​ ​the​ ​off​ ​position. 3.​ ​Place​ ​SW1.6​ ​in​ ​the​ ​on​ ​position. 4.​ ​Configuration​ ​complete. PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 10 3.2.4 Connections The following table shows the connections between the NimbeLink Skywire Cellular​ ​Modem​ ​and​ ​the​ ​Renesas​ ​Kurumi. Kurumi Pin 2 4 5 6 7 8 Signal Description Skywire​ ​DTR Skywire​ ​On​ ​Off Skywire​ ​CTS Skywire​ ​RTS Skywire​ ​DIN Skywire​ ​DOUT Skywire​ ​Data​ ​Terminal​ ​Ready​ ​Signal Skywire​ ​On/Off​ ​control​ ​line Skywire​ ​Clear​ ​to​ ​Send Skywire​ ​Ready​ ​to​ ​Send Skywire​ ​UART​ ​data​ ​in Skywire​ ​UART​ ​data​ ​out 3.2.5 Board​ ​Orientation The Renesas Kurumi board should be attached with the programming header aligned with​ ​the​ ​programming​ ​header​ ​breakout​ ​pins(J9)​ ​on​ ​the​ ​adapter​ ​board. PN​ ​30018​ ​rev​ ​2 ​©​ ​NimbeLink​ ​Corp.​ ​2017.​ ​All​ ​rights​ ​reserved. 11
NL-AB-PMOD 价格&库存
很抱歉,暂时无法提供与“NL-AB-PMOD”相匹配的价格&库存,您可以联系我们找货
