WAB-GW-GS2011MIZ
WAB-GW-GS2011MIZ
    GAINSPAN
    ADAPTERBOARDWI-FIPMOD
WAB-GW-GS2011MIZ 数据手册
T BRIEF PRELIMINARY PRODUCT BRIEF r GS2011M Wi-Fi Adapter Board PRODUCT OVERVIEW The Wi-Fi Adapter Board (WAB) is a GS2011MIZ Wi-Fi module based hardware adapter board that can be interfaced to a microcontroller (MCU) development board to enable Wi-Fi connectivity in MCU based applications. It provides the means to evaluate the capabilities of GainSpan’s lowpower GS2011MIZ Wi-Fi modules and Serial-to-Wi-Fi embedded software, and develop software for MCU host-based Wi-Fi enabled devices. The WAB supports IEEE 802.11b/g/n protocols and includes a GainSpan GS2011MIZ soldered down module. It communicates with the MCU over the SPI or UART interface. It is designed to plug into various MCU development platforms such as RL78, RX62/RX63, RX100/200/600, SuperH and others, using the PMOD and Application Header interface. The boards have built-in external flash for reliable over the air firmware upgrade, factory restore configuration as well as data storage for web pages. The WAB comes with pre-loaded Serial-to-Wi-Fi application firmware that supports complete Wi-Fi and networking stacks, Wi-Fi and application layer security, Wi-Fi and IP network configuration web pages, as well as the Limited AP capability for ease of provisioning. The Serial-to-Wi-Fi embedded software allows devices and appliances manufacturers to easily add Wi-Fi capabilities to their products with minor impact on the host microcontroller firmware. Small-footprint drivers and reference code are available for a variety of MCUs. BENEFITS:  Wi-Fi Adapter board for enabling Wi-Fi connectivity in MCU based applications with minor impact on host firmware  Easy integration of Wi-Fi and web connectivity with MCU based embedded devices, over UART or SPI interface  Allows evaluation of capabilities of the GS2000 SoC and enables customer application development  Serial-to-WiFi software allows easy addition of Wi-Fi capabilities to hosted embedded system using AT commands FEATURES:   Software and documentation for the WAB is available on the GainSpan customer support portal. .  Highly integrated, ultra-low power 802.11b/g/n GS2011MIZ Wi-Fi modules PMOD and Application header interfaces to plug into MCU development platforms Multiple serial ports o UART: up to 921 Kbps o SPI: up to 30MHz (master mode) 10MHz (slave mode)  Programmed with Serial-to-WiFi software including o Full Wi-Fi and networking stack - WiFi security (WEP, WPA/2), WPS, TCP/UDP/IP, DNS, DHCP, HTTP/s, DTLS, CoAP, TLS/SSL o Complete set of AT commands to communicate with the host MCU  Push buttons for Factory Restore and Reset  Jumpers for serial interface selection and power measurement PR E LIM IN AR Y P RO D UCT B RI EF WI-FI ADAPTER BOARD SPECIFICATIONS Feature Description RF Module GS2011MIZ Ultra-Low Power Module Radio Protocol IEEE 802.11 b/g/n, 2.4GHz Antenna Type Ceramic Antenna Power Source PMOD or Application Header Connector I/O Interfaces UART, SPI, GPIO Push Buttons Factory Restore and Reset Jumpers UART or SPI Selection, Current Measurement Connector PMOD and Application Header Interface Serial Flash External Flash for storing web pages or firmware code base for factory restore WI-FI ADAPTER BOARD ORDERING INFORMATION ITEM GS2011M Wi-Fi Adapter Board PART NUMBER WAB-GW-GS2011MIZ Copyright © 2014 GainSpan Corporation. All Rights Reserved. GS2K_WAB_PB Release 0.1 Description 802.11b/g/n Wi-Fi Adapter Board with a GS2011MIZ module 3590 N. First Street, Suite 300 San Jose, CA 95134 Tel +1 (408) 627-6500 info@gainspan.com www.gainspan.com
WAB-GW-GS2011MIZ 价格&库存
很抱歉,暂时无法提供与“WAB-GW-GS2011MIZ”相匹配的价格&库存,您可以联系我们找货
