SD-GW-GS2100MIP
SD-GW-GS2100MIP
    GAINSPAN
    ADAPTERBOARDSDIOWI-FI
SD-GW-GS2100MIP 数据手册
PRODUCT BRIEF r GS2100M SDIO Wi-Fi Adapter Board PRODUCT OVERVIEW The SDIO Wi-Fi Adapter Board (WAB) is a GS2100MIP Wi-Fi module based hardware adapter board that can be interfaced to the SDIO interface of a host microcontroller / SOC. SDIO WAB provides the means to evaluate the capabilities of GainSpan’s low-power GS2100MIP Wi-Fi modules and Serial-to-Wi-Fi embedded software, and develop software for MCU host-based Wi-Fi enabled devices. and The SDIO board includes the GainSpan GS2100MIP module supports IEEE 802.11b/g/n protocols. It communicates with the MCU over the SDIO interface and is designed to plug into the SDIO interface on various MCU development platforms such as Renesas RZ and SH series, Freescale Tower K60, ST Micro STM32 development platforms and others. The modules on the board have builtin flash for reliable over the air firmware upgrade, as well as data storage for web pages. Serial-to-Wi-Fi pre-loaded The SDIO board comes with application firmware that supports complete Wi-Fi and networking stacks, Wi-Fi and application layer security, Wi-Fi and IP network configuration web pages, as well as the Limited AP capability for ease of provisioning. The Serial-to-Wi-Fi embedded software allows devices and appliances manufacturers to easily add Wi-Fi capabilities to their products with minor impact on the host microcontroller firmware. Small-footprint drivers and reference code are available for a variety of MCUs. Software and documentation for the WAB is available on the GainSpan customer support portal. BENEFITS: • SDIO adapter board for enabling Wi-Fi connectivity in MCU based applications with minor impact on host firmware • Easy integration of Wi-Fi and web connectivity to MCU based embedded devices with microcontroller, over SDIO interface • Allows evaluation of capabilities of the GS2000 SoC and enables customer application development • Serial-to-WiFi software allows easy addition of Wi-Fi capabilities to hosted embedded system using AT commands FEATURES: • Highly integrated, ultra-low power 802.11b/g/ n GS2100MIP Wi-Fi modules • SDIO interface compliant with v2.0 specifications o Device mode only UART port (921 Kbps) for program loading • o . Can also be used as host I/F with PC (only one host I/F at one time) • Programmed with Serial-to-WiFi software including o Full Wi-Fi and networking stack - WiFi security (WEP, WPA/2), WPS, TCP/ UDP/IP, DNS, DHCP, HTTP/s, DTLS, CoAP, TLS/SSL CoAP, TLS/SSL o Complete set of AT commands to communicate with the host MCU • Switches for Run/Program mode selection PRODUCT BRIEF SDIO WI-FI BOARD SPECIFICATIONS Feature Description RF Module GS2100MIP Ultra-Low Power Wi-Fi Module Radio Protocol IEEE 802.11 b/g/n, 2.4GHz Antenna Type PCB Trace Power Source SDIO Interface or USB (SDIO and USB are mutually exclusive; only one can be connected at once) I/O Interfaces SDIO or USB-UART Switches Run/Program, PC Control Connector SDIO, Mini-USB Serial Flash On-module Flash for storing web pages and firmware code SDIO WI-FI BOARD ORDERING INFORMATION ITEM SDIO Adapter Board PART NUMBER SD-GW-GS2100MIP Copyright © 2015 GainSpan Corporation. All Rights Reserved. GS2K_SDIO_PB Release 0.2 Description 802.11b/g/n SDIO Board with a GS2100MIP module 3590 N. First Street, Suite 300 San Jose, CA 95134 Tel +1 (408) 627-6500 info@gainspan.com www.gainspan.com
SD-GW-GS2100MIP 价格&库存
很抱歉,暂时无法提供与“SD-GW-GS2100MIP”相匹配的价格&库存,您可以联系我们找货
