XB24-DKSJ
XB24-DKSJ
    DIGIINTERNATIONAL
    KIT DEV XBEE SERIES 1 802.15.4
XB24-DKSJ 数据手册
XBee/XBee-PRO S1 802.15.4 (Legacy) RF Modules User Guide Revision history—90000982 Revision Date Description T December Corrected RESET pin information. 2015 U May 2016 Noted that bit 13 of the SC parameter is not available for XBee-PRO devices. Corrected an error in the I/O line passing parameters table. Added S1 and Legacy to the product name. Updated the certifications. V October 2016 Updated and rebranded the documentation. W June 2017 Modified regulatory and certification information as required by RED (Radio Equipment Directive). X May 2018 Added note on range estimation. Changed IC to ISED. Trademarks and copyright Digi, Digi International, and the Digi logo are trademarks or registered trademarks in the United States and other countries worldwide. All other trademarks mentioned in this document are the property of their respective owners. © 2018 Digi International Inc. All rights reserved. Disclaimers Information in this document is subject to change without notice and does not represent a commitment on the part of Digi International. Digi provides this document “as is,” without warranty of any kind, expressed or implied, including, but not limited to, the implied warranties of fitness or merchantability for a particular purpose. Digi may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. Warranty To view product warranty information, go to the following website: www.digi.com/howtobuy/terms Customer support Gather support information: Before contacting Digi technical support for help, gather the following information: XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 2    Product name and model    Product serial number (s)    Firmware version    Operating system/browser (if applicable)    Logs (from time of reported issue)    Trace (if possible)    Description of issue    Steps to reproduce Contact Digi technical support: Digi offers multiple technical support plans and service packages. Contact us at +1 952.912.3444 or visit us at www.digi.com/support. Feedback To provide feedback on this document, email your comments to techcomm@digi.com Include the document title and part number (XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide, 90000982 X) in the subject line of your email. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 3 Contents About the XBee/XBee-PRO S1 802.15.4 (Legacy) RF Modules Technical specifications Electrical characteristics DC Characteristics (VCC = 2.8 - 3.4 VDC) ADC timing/performance characteristics1 Performance specifications Power requirements General specifications Networking and security specifications Regulatory conformity summary 10 10 11 12 12 13 13 13 Hardware Antenna options XBee/XBee-PRO S1 802.15.4 (Legacy) Mechanical drawings Mounting considerations Pin signals Design notes Power supply design Board layout Antenna performance Pin connection recommendations Keepout area 16 16 16 17 19 19 19 19 20 20 Operation Serial communications UART data flow Transparent operating mode API operating mode Flow control ADC and Digital I/O line support I/O data format API support Sleep support DIO pin change detect Sample rate (interval) I/O line passing XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 23 23 24 24 25 26 27 27 27 28 28 28 4 Configuration example Networks Peer-to-peer networks NonBeacon (with coordinator) Association Addressing Unicast mode Broadcast mode Modes of operation Idle mode Transmit/Receive modes Sleep modes Multiple AT commands Parameter format 30 30 31 31 31 34 34 35 35 36 36 38 41 41 Configuration Configure the device using XCTU Programming the RF module Setup Remote configuration commands Send a remote command Apply changes on remote devices Remote command responses Software libraries XBee Network Assistant 44 44 44 45 45 46 46 46 46 AT commands Special commands WR (Write) RE (Restore Defaults) FR (Software Reset) Networking and security commands CH (Channel) ID (PAN ID) DH (Destination Address High) DL (Destination Address Low) MY (16-bit Source Address) SH (Serial Number High) SL (Serial Number Low) RR (XBee Retries) RN (Random Delay Slots) MM (MAC Mode) NI (Node Identifier) ND (Node Discover) NT (Node Discover Time) NO (Node Discovery Options) DN (Destination Node) CE (Coordinator Enable) SC (Scan Channels) SD (Scan Duration) A1 (End Device Association) A2 (Coordinator Association) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 49 49 49 49 50 50 50 50 51 51 51 51 52 52 53 53 54 55 55 55 56 56 57 58 59 5 AI (Association Indication) DA (Force Disassociation) FP (Force Poll) AS (Active Scan) ED (Energy Scan) EE (AES Encryption Enable) KY (AES Encryption Key) RF interfacing commands PL (Power Level) CA (CCA Threshold) Sleep commands (low power) SM (Sleep Mode) SO (Sleep Options) ST (Time before Sleep) SP (Cyclic Sleep Period) DP (Disassociated Cyclic Sleep Period) Serial interfacing commands BD (Interface Data Rate) RO (Packetization Timeout) AP (API Enable) NB (Parity) PR (Pull-up/Down Resistor Enable) I/O settings commands D0 (DIO0 Configuration) D1 (DIO1 Configuration) D2 (AD2/DIO2 Configuration) D3 (DIO3 Configuration) D4 (DIO4 Configuration) D5 (DIO5 Configuration) D6 (DIO6 Configuration) D7 (DIO7 Configuration) D8 (DIO8 Configuration) IU (I/O Output Enable) IT (Samples before TX) IS (Force Sample) IO (Digital Output Level) IC (DIO Change Detect) IR (Sample Rate) IA (I/O Input Address) T0 (D0 Output Timeout) T1 (D1 Output Timeout) T2 (D2 Output Timeout) T3 (D3 Output Timeout) T4 (D4 Output Timeout) T5 (D5 Output Timeout) T6 (D6 Output Timeout) T7 (D7 Output Timeout) P0 (PWM0 Configuration) P1 (PWM1 Configuration) M0 (PWM0 Output Level) M1 (PWM1 Output Level) PT (PWM Output Timeout) RP (RSSI PWM Timer) Diagnostic commands VR (Firmware Version) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 60 61 61 61 62 63 63 64 64 64 65 65 66 66 66 67 67 67 69 69 70 70 71 71 71 72 72 73 73 74 74 75 75 76 76 77 77 77 78 78 79 79 79 80 80 80 81 81 81 82 82 83 83 83 84 6 VL (Version Long) HV (Hardware Version) DB (Last Packet RSSI) EC (CCA Failures) EA (ACK Failures) ED (Energy Scan) Command mode options CT (Command Mode Timeout) CN (Exit Command mode) AC (Apply Changes) GT (Guard Times) CC (Command Sequence Character) 84 84 84 85 85 85 86 86 86 86 87 87 API operation API frame specifications API operation (AP parameter = 1) API operation-with escaped characters (AP parameter = 2) Calculate and verify checksums Example API types Modem Status - 0x8A Modem status codes Local AT Command Request - 0x08 Queue Local AT Command Request - 0x09 Local AT Command Response - 0x88 Remote AT Command Request - 0x17 Remote AT Command Response- 0x97 64-bit Transmit Request - 0x00 16-bit Transmit Request - 0x01 Transmit Status - 0x89 64-bit Receive Packet - 0x80 16-bit Receive Packet - 0x81 64-bit I/O Sample Indicator - 0x82 16-bit I/O Sample Indicator - 0x83 89 89 89 90 90 91 91 93 93 95 96 98 100 102 104 106 108 109 111 113 Regulatory information United States (FCC) OEM labeling requirements FCC notices FCC-approved antennas (2.4 GHz) RF exposure Europe (CE) Maximum power and frequency specifications OEM labeling requirements Declarations of conformity Antennas ISED (Innovation, Science and Economic Development Canada) Labeling requirements Japan Labeling requirements Brazil ANATEL XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 116 116 116 117 123 123 123 123 124 124 125 125 125 125 125 7 About the XBee/XBee-PRO S1 802.15.4 (Legacy) RF Modules The XBee and XBee-PRO RF Modules were engineered to meet IEEE 802.15.4 standards and support the unique needs of low-cost, low-power wireless sensor networks. The devices require minimal power and provide reliable delivery of data between devices. The devices operate within the ISM 2.4 GHz frequency band and are pin-for-pin compatible with each other. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 8 Technical specifications Electrical characteristics Performance specifications Power requirements General specifications Networking and security specifications Regulatory conformity summary XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 10 12 12 13 13 13 9 Technical specifications Electrical characteristics Electrical characteristics The following tables list the electrical characteristics of the XBee/XBee-PRO XBee/XBee-PRO S1 802.15.4 (Legacy) RF Modules. DC Characteristics (VCC = 2.8 - 3.4 VDC) Symbol Characteristic Condition Min Typical Max Unit VIL Input low voltage All Digital Inputs - - 0.35 * V VCC VIH Input high voltage All Digital Inputs 0.7 * VCC - - V VOL Output low voltage I OL = 2 mA, VCC >= 2.7 V - - 0.5 V VOH Output high voltage I OH = -2 mA, VCC >= 2.7 V VCC - 0.5 - - V II IN Input leakage Current VIN = VCC or GND, all inputs, per pin - 0.025 1 µA II OZ High impedance leakage current VIN = VCC or GND, all I/O High-Z, per pin - 0.025 1 µA TX Transmit current VCC = 3.3 V - 45 (XBee) 215, 140 (XBee-PRO, International) - mA RX Receive current VCC = 3.3 V - 50 (XBee) 55 (XBee-PRO) - mA PWRDWN Power-down current SM parameter = 1 - 0, (RR + 2) packets are sent in each broadcast. No acknowledgments are returned. For more information, see RR (XBee Retries). n DH (Destination High Address) = 0x00000000 (default value) When you are programming the device, enter the parameters in hexadecimal notation (without the “0x” prefix). Leading zeros may be omitted. Modes of operation This section describes the different operating modes for the device. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 35 Operation Modes of operation Idle mode When not receiving or transmitting data, the device is in Idle mode. The device shifts into the other modes of operation under the following conditions: n Transmit mode (serial data is received in the DI buffer). n Receive mode (valid RF data received through the antenna). n Sleep mode (Sleep mode condition is met). n Command mode (Command mode sequence issued). Transmit/Receive modes This section provides information about the different types of transmit and receive modes. RF data packets Each transmitted data packet contains a Source Address and Destination Address field. The Source Address matches the address of the transmitting device as specified by the MY (Source Address) parameter (if MY ≥ 0xFFFE), the SH (Serial Number High) parameter or the SL (Serial Number Low) parameter. The field is created from the DH (Destination Address High) and DL (Destination Address Low) parameter values. The Source Address and/or Destination Address fields either contain a 16-bit short or long 64-bit long address. The RF data packet structure follows the 802.15.4 specification. For more information, see Addressing. Direct and indirect transmission There are two methods to transmit data: n Direct transmission: data is transmitted immediately to the Destination Address n Indirect transmission: a packet is retained for a period of time and is only transmitted after the destination device (source address = destination address) requests the data. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 36 Operation Modes of operation Indirect transmissions can only occur on a Coordinator. Thus, if all nodes in a network are End Devices, only direct transmissions occurs. Indirect transmissions are useful to ensure packet delivery to a sleeping node. The Coordinator currently is able to retain up to two indirect messages. Direct transmission A Coordinator can be configured to use only direct transmission by setting the SP (Cyclic Sleep Period) parameter to 0. Also, a Coordinator using indirect transmissions reverts to direct transmission if it knows the destination device is awake. To enable this behavior, the ST (Time before Sleep) value of the Coordinator must be set to match the ST value of the End Device. Once the End Device either transmits data to the Coordinator or polls the Coordinator for data, the Coordinator uses direct transmission for all subsequent data transmissions to that device address until ST time occurs with no activity (at which point it reverts to using indirect transmissions for that device address). "No activity" means no transmission or reception of messages with a specific address. Broadcast messages do not reset the ST timer. Indirect transmission To configure Indirect Transmissions in a Personal Area Network (PAN), the SP (Cyclic Sleep Period) parameter value on the Coordinator must be set to match the longest sleep value of any End Device. The sleep period value on the Coordinator determines how long (time or number of beacons) the Coordinator retains an indirect message before discarding it. An End Device must poll the Coordinator once it wakes from Sleep to determine if the Coordinator has an indirect message for it. For Cyclic Sleep Modes, this is done automatically every time the device wakes (after SP time). For Pin Sleep Modes, the A1 (End Device Association) parameter value must be set to enable Coordinator polling on pin wake-up . Alternatively, an End Device can use the FP (Force Poll) command to poll the Coordinator as needed. Clear Channel Assessment (CCA) Prior to transmitting a packet, the device performs a CCA (Clear Channel Assessment) on the channel to determine if the channel is available for transmission. The detected energy on the channel is compared with the CA (Clear Channel Assessment) parameter value. If the detected energy exceeds the CA parameter value, the device does not transmit the packet. Also, the device inserts a delay before a transmission takes place. You can set this delay using the RN (Backoff Exponent) parameter. If you set RN to 0, then there is no delay before the first CCA is performed. The RN parameter value is the equivalent of the “minBE” parameter in the 802.15.4 specification. The transmit sequence follows the 802.15.4 specification. By default, the MM (MAC Mode) parameter = 0. On a CCA failure, the device attempts to re-send the packet up to two additional times. When in Unicast packets with RR (Retries) = 0, the device executes two CCA retries. Broadcast packets always get two CCA retries. Note Customers in Europe who have the XBee 802.15.4 module must manage their CCA settings. See CA (CCA Threshold) for CA values. Acknowledgment If the transmission is not a broadcast message, the device expects to receive an acknowledgment from the destination node. If an acknowledgment is not received, the packet is resent up to three more times. If the acknowledgment is not received after all transmissions, an ACK failure is recorded. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 37 Operation Modes of operation Sleep modes Sleep modes enable the device to enter states of low-power consumption when not in use. In order to enter Sleep mode, one of the following conditions must be met (in addition to the device having a nonzero SM parameter value): n SLEEP_RQ is asserted and the device is in a pin sleep mode (SM = 1, 2, or 5) n The device is idle (no data transmission or reception) for the amount of time defined by the ST (Time before Sleep) parameter. Note ST is only active when SM = 4 or 5. The following table shows the sleep mode configurations. Transition into sleep mode Transition out of sleep mode (wake) Characteristics Pin hibernate SM 1 Assert (high) Sleep_RQ (pin 9) De-assert (low) Sleep_ RQ (SM) Pin/Hostcontrolled/NonBeacon systems only/Lowest Power < 10 µA (@3.0 VCC) Pin doze SM 2 Assert (high) Sleep_RQ (pin 9) De-assert (low) Sleep_ RQ Pin/Host(SM) controlled/NonBeacon systems only/Fastest wake-up < 50 µA Cyclic Sleep SM 4 Automatic transition to Sleep Mode as defined by the SM (Sleep Mode) and ST (Time before Sleep) parameters Transition occurs after the cyclic sleep time interval elapses. The time interval is defined by the SP (Cyclic Sleep Period) parameter. RF module wakes in pre-determined time intervals to detect if RF data is present/When SM = 5 < 50 µA when sleeping Sleep mode setting XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide Related Power commands consumption (SM), SP, ST 38 Operation Modes of operation Sleep mode setting Cyclic Sleep SM 5 Transition into sleep mode Automatic transition to Sleep Mode as defined by the SM (Sleep Mode) and ST (Time before Sleep) parameters or on a falling edge transition of the SLEEP_RQ pin Transition out of sleep mode (wake) Characteristics Transition occurs after the cyclic sleep time interval elapses. The time interval is defined by the SP (Cyclic Sleep Period) parameter. RF module wakes in pre-determined time intervals to detect if RF data is present. Module also wakes on a falling edge of SLEEP_RQ. Related Power commands consumption (SM), SP, ST < 50 µA when sleeping The SM command is central to setting Sleep mode configurations. By default, Sleep modes are disabled (SM = 0) and the device remains in Idle/Receive Mode. When in this state, the device is constantly ready to respond to serial or RF activity. Pin/Host-controlled sleep modes The transient current when waking from pin sleep (SM = 1 or 2) does not exceed the idle current of the module. The current ramps up exponentially to its idle current. Pin hibernate (SM=1) n Pin/Host-controlled n Typical power-down current: < 10 µA (@3.0 VCC) n Typical wake-up time: 10.2 ms Pin Hibernate Mode minimizes quiescent power (power consumed when in a state of rest or inactivity). This mode is voltage level-activated. When the device assterts Sleep_RQ (pin 9), it finishes any transmit, receive or association activities, enters Idle Mode, and then enters a state of sleep. The device does not respond to either serial or RF activity while in pin sleep. To wake a sleeping device operating in Pin Hibernate Mode, de-assert Sleep_RQ (pin 9). The device wakes when Sleep_RQ is de-asserted and is ready to transmit or receive when the CTS line is low. When waking the device, the pin must be de-asserted at least two 'byte times' after CTS goes low. This assures that there is time for the data to enter the DI buffer. Pin doze (SM = 2) n Pin/Host-controlled n Typical power-down current: < 50 µA n Typical wake-up time: 2.6 ms Pin doze mode functions the same as Pin hibernate mode. However, Pin doze features faster wake-up time and higher power consumption. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 39 Operation Modes of operation To wake a sleeping device operating in Pin Doze Mode, de-assert Sleep_RQ (pin 9). The device wakes when Sleep_RQ is de-asserted and is ready to transmit or receive when the CTS line is low. When waking the device, the pin must be de-asserted at least two 'byte times' after CTS goes low. This assures that there is time for the data to enter the DI buffer. Cyclic sleep modes This section provides information on the different types of cyclic sleep modes. Cyclic Sleep Remote (SM = 4) n Typical Power-down Current: < 50 µA (when asleep) n Typical wake-up time: 2.6 ms The Cyclic Sleep modes allow devices to periodically check for RF data. When the SM parameter is set to 4, the XBee/XBee-PRO S1 802.15.4 (Legacy) is configured to sleep, then wakes once per cycle to check for data from a from a device configured as a Cyclic Sleep Coordinator (SM = 0, CE = 1). The Cyclic Sleep Remote sends a poll request to the coordinator at a specific interval set by the SP (Cyclic Sleep Period) parameter. The coordinator transmits any queued data addressed to that specific remote upon receiving the poll request. If no data is queued for the remote, the coordinator does not transmit and the remote returns to sleep for another cycle. If the device transmits queued data back to the remote, it stays awake to allow for back and forth communication until the ST (Time before Sleep) timer expires. If configured, CTS goes low each time the remote wakes, allowing for communication initiated by the remote host if desired. Cyclic Sleep Remote with Pin Wake-up (SM = 5) Use this mode to wake a sleeping remote device through either the RF interface or by de-asserting SLEEP_RQ for event-driven communications. The cyclic sleep mode works as described previously with the addition of a pin-controlled wake-up at the remote device. The Sleep_RQ pin is edge-triggered, not level-triggered. The device wakes when a low is detected then set CTS low as soon as it is ready to transmit or receive. Any activity resets the ST (Time before Sleep) timer, so the device goes back to sleep only after there is no activity for the duration of the timer. Once the device wakes (pin-controlled), it ignores further pin activity. The device transitions back into sleep according to the ST time regardless of the state of the pin. Cyclic Sleep Coordinator (SM = 6) n Typical current = Receive current n Always awake Note The SM=6 parameter value exists solely for backwards compatibility with firmware version 1.x60. If backwards compatibility with the older firmware version is not required, always use the CE (Coordinator Enable) command to configure a device as a Coordinator. This mode configures a device to wake cyclic sleeping remotes through RF interfacing. The Coordinator accepts a message addressed to a specific remote 16 or 64-bit address and holds it in a buffer until the remote wakes and sends a poll request. Messages not sent directly (buffered and requested) are called "Indirect messages". The Coordinator only queues one indirect message at a time. The Coordinator holds the indirect message for a period 2.5 times the sleeping period indicated by the SP (Cyclic Sleep Period) parameter. Set the Coordinator's SP parameter to match the value used by the remotes. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 40 Operation Multiple AT commands Command mode Command mode is a state in which the firmware interprets incoming characters as commands. The XBee/XBee-PRO S1 802.15.4 (Legacy) supports two Command mode options: AT commands and API operation. AT Command Mode This section provides information about entering, sending, and exiting Command Mode. Enter Command mode Send the three-character command sequence +++ and observe guard times before and after the command characters. Default AT Command Mode Sequence (for transition to Command mode): n No characters sent for one second [GT (Guard Times) parameter = 0x3E8] n Input three plus characters (“+++”) within one second [CC (Command Sequence Character) parameter = 0x2B] n No characters sent for one second [GT (Guard Times) parameter = 0x3E8] You can modify all parameter values in the sequence to reflect user preferences. Failure to enter AT Command Mode is most commonly due to a baud rate mismatch. Ensure the Baud setting on the PC Settings tab matches the interface data rate of the RF module. By default, the BD (Baud Rate) parameter = 3 (9600 b/s). Send AT commands Once the device enters Command mode, use the syntax in the following figure to send AT commands. Every AT command starts with the letters AT, which stands for "attention." The AT is followed by two characters that indicate which command is being issued, then by some optional configuration values. To read a parameter value stored in the device’s register, omit the parameter field. The preceding example changes NI (Node Identifier) to My XBee. Multiple AT commands You can send multiple AT commands at a time when they are separated by a comma in Command mode; for example, ATNIMy XBee,AC. The preceding example changes the NI (Node Identifier) to My XBee and makes the setting active through AC (Apply Changes). Parameter format Refer to the list of AT commands for the format of individual AT command parameters. Valid formats for hexidecimal values include with or without a leading 0x for example FFFF or 0xFFFF. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 41 Operation Parameter format Exit Command mode 1. Send CN (Exit Command mode) followed by a carriage return. or: 2. If the device does not receive any valid AT commands within the time specified by CT (Command Mode Timeout), it returns to Transparent or API mode. The default Command mode timeout is 10 seconds. For an example of programming the device using AT Commands and descriptions of each configurable parameter, see AT commands. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 42 Configuration Configure the device using XCTU Programming the RF module Remote configuration commands Software libraries XBee Network Assistant XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 44 44 45 46 46 43 Configuration Configure the device using XCTU Configure the device using XCTU XBee Configuration and Test Utility (XCTU) is a multi-platform program that enables users to interact with Digi radio frequency (RF) devices through a graphical interface. The application includes built-in tools that make it easy to set up, configure, and test Digi RF devices. For instructions on downloading and using XCTU, see the XCTU User Guide. Click Discover devices and follow the instructions. XCTU should discover the connected XBee/XBeePRO S1 802.15.4 (Legacy)s using the provided settings. Click Add selected devices.The devices appear in the Radio Modules list. You can click a module to view and configure its individual settings. For more information on these items, see AT commands. Programming the RF module This section provides examples on how to program an RF module using AT Command Mode. For more information about using AT Command Mode, see AT commands. For information regarding module programming using API Mode, see API operation. Setup The programming examples in this section require the installation of XCTU and a serial connection to a PC. We stock RS-232 and USB boards to facilitate interfacing with a PC. For more information about XCTU installation and setup, see the XCTU User Guide. 1. Download XCTU from the Digi website. 2. After you have downloaded the .exe file to your PC, double-click the file to launch the XCTU Setup Wizard. Follow the steps in the wizard to completely install XCTU. 3. Mount the RF module to an interface board, and then connect the module assembly to a PC. 4. Launch XCTU and click the Add devices tab in the upper left corner of the screen. 5. Verify that the baud and parity settings of the Com Port match those of the RF module. Note Failure to enter AT Command Mode is typically due to baud rate mismatch. Ensure that the Baud setting on the Add radio device window matches the interface data rate of the RF module. By default, the BD parameter = 9600 b/s. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 44 Configuration Remote configuration commands Sample configuration: modify RF Module destination address Using the Interface Example: Once you have added the module to XCTU, complete the following steps: 1. Click on the module in the Radio Modules area to display the Configuration working mode. This mode shows most of the module’s parameters that you can edit. 2. Scroll down on the right panel until you find the parameter you want to edit, in this case the DL (Destination Address Low) parameter, or use the search box and type "DL". XCTU automatically scrolls to the selected parameter. 3. Change the value of the parameter to, for example, 1A0D. If you have not saved the parameter, a green triangle appears in the lower right corner of the parameter. 4. Click the write button to save the value to non-volatile memory. If you change other parameters but have not saved them, you can use the Write radio settings button to save the change. Sample configuration: restore RF Module defaults Example: Use the Configuration working mode tab in XCTU to restore the default parameter values. 1. After establishing a connection between the module and a PC, click the Configuration working mode button. 2. Click the Load default firmware settings button and agree to restore the default values. The restored parameters appear with a a green triangle appears in the lower right corner of the parameter, meaning they have been changed but not saved. If you have not saved the parameter, a green triangle appears in the lower right corner of the parameter. All the parameters surrounding box must change to grey color indicating that their values are now saved in the non-volatile memory of the module. 3. Click the Write module settings button to save all of the parameters. All the parameters must change to grey indicating that their values are now saved in the nonvolatile memory of the module. Remote configuration commands The API firmware has provisions to send configuration commands to remote devices using the Remote Command Request API frame (see API operation). Use the API frame to send commands to a remote device to read or set command parameters. Send a remote command To send a remote command populate the Remote AT Command Request frame (0x17) with Values for the 64 bit and 16 bit addresses. If you want to set up 64-bit addressing, populate the 16-bit address field with 0xFFFE. If you use any other value in the 16-bit address field, the device uses the 16-bit address and ignores the 64-bit address. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 45 Configuration Software libraries If you want to receive a command response, set the Frame ID to a non-zero value. Only unicasts of remote commands are supported. Apply changes on remote devices When you use remote commands to change command parameter settings on a remote device, parameter changes do not take effect until you apply the changes. For example, changing the BD parameter does not change the serial interface on the remote until the changes are applied. To apply changes, do one of the following: n Set the apply changes option bit in the API frame. n Issue an AC (Apply Changes) command to the remote device. n Issue a WR + FR command to the remote device to save changes and reset the device. Remote command responses If the remote device receives a remote command request transmission, and the API frame ID is nonzero, the remote sends a remote command response transmission back to the device that sent the remote command. When a remote command response transmission is received, a device sends a remote command response API frame out its UART. The remote command response indicates the status of the command (success, or reason for failure), and in the case of a command query, it includes the register value. The device that sends a remote command will not receive a remote command response frame if either of the following conditions exist: n The destination device could not be reached. n The frame ID in the remote command request is set to 0. Software libraries One way to communicate with the XBee/XBee-PRO S1 802.15.4 (Legacy) is by using a software library. The libraries available for use with the XBee/XBee-PRO S1 802.15.4 (Legacy) include: n XBee Java library n XBee Python library The XBee Java Library is a Java API. The package includes the XBee library, its source code and a collection of samples that help you develop Java applications to communicate with your XBee devices. The XBee Python Library is a Python API that dramatically reduces the time to market of XBee projects developed in Python and facilitates the development of these types of applications, making it an easy process. XBee Network Assistant The XBee Network Assistant is an application designed to inspect and manage RF networks created by Digi XBee devices. Features include: n Join and inspect any nearby XBee network to get detailed information about all the nodes it contains. n Update the configuration of all the nodes of the network, specific groups, or single devices based on configuration profiles. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 46 Configuration XBee Network Assistant n Geo-locate your network devices or place them in custom maps and get information about the connections between them. n Export the network you are inspecting and import it later to continue working or work offline. n Use automatic application updates to keep you up to date with the latest version of the tool. See the XBee Network Assistant User Guide for more information. To install the XBee Network Assistant: 1. Navigate to digi.com/xbeenetworkassistant. 2. Click General Diagnostics, Utilities and MIBs. 3. Click the XBee Network Assistant - Windows x86 link. 4. When the file finishes downloading, run the executable file and follow the steps in the XBee Network Assistant Setup Wizard. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 47 AT commands XBee/XBee-PRO RF Modules expect numerical values in hexadecimal. Hexadecimal values are designated by a “0x” prefix, and decimal equivalents are designated by a “d” suffix. Commands are contained within the following command categories: Note All modules within a PAN should operate using the same firmware version. Special commands Networking and security commands RF interfacing commands Sleep commands (low power) Serial interfacing commands I/O settings commands Diagnostic commands Command mode options XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 49 50 64 65 67 71 83 86 48 AT commands Special commands Special commands The following commands are special commands. WR (Write) Writes parameter values to non-volatile memory so that parameter modifications persist through subsequent resets. If you make changes without writing them to non-volatile memory, the device reverts back to previously saved parameters the next time the device is powered-on. Note Once you issue a WR command, do not send any additional characters to the device until after you receive the OK response. Parameter range N/A Default N/A RE (Restore Defaults) Restore device parameters to factory defaults. The RE command does not write restored values to non-volatile (persistent) memory. Issue the WR (Write) command after issuing the RE command to save restored parameter values to non-volatile memory. Parameter range N/A Default N/A FR (Software Reset) If you issue FR while the device is in Command Mode, the reset effectively exits Command mode. Forces a software reset on the device. The reset simulates powering off and then on again the device. The device responds immediately with an OK and performs a reset 100 ms later. Parameter range N/A Default N/A Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 49 AT commands Networking and security commands Networking and security commands The following AT commands are networking and security commands. CH (Channel) Set or read the operating channel devices used to transmit and receive data. The channel is one of three addressing configurations available to the device. The other configurations are the PAN ID (ID command) and destination addresses (DL and DH commands). In order for devices to communicate with each other, they must share the same channel number. A network can use different channels to prevent devices in one network from listening to the transmissions of another. Adjacent channel rejection is 23 dB. The command uses 802.15.4 channel numbers. Center frequency = 2405 MHz + (CH - 11 decimal) * 5 MHz. Parameter range 0xB - 0x1A (XBee) 0x0C - 0x17 (XBee-PRO) Default 0xC (12 decimal) ID (PAN ID) Set or read the Personal Area Network (PAN) ID. Use 0xFFFF to broadcast messages to all PANs. Devices must have the same network identifier to communicate with each other. Unique PAN IDs enable control of which RF packets a device receives. Setting the ID parameter to 0xFFFF indicates a global transmission for all PANs. It does not indicate a global receive. Parameter range 0 - 0xFFFF Default 0x3332 (13106 decimal) DH (Destination Address High) Set or read the upper 32 bits of the 64-bit destination address. When you combine DH with DL, it defines the 64-bit destination address that the device uses for data transmission. A device only communicates with other devices having the same channel (CH parameter), PAN ID (ID parameter) and destination address (DH + DL parameters). To transmit using a 16-bit address, set DH parameter to zero and DL less than 0xFFFF. The broadcast address for the PAN is 0x000000000000FFFF. For more information, see Addressing. Parameter range 0 - 0xFFFFFFFF XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 50 AT commands Networking and security commands Default 0 DL (Destination Address Low) Set or display the lower 32 bits of the 64-bit destination address. When you combine DH with DL, it defines the destination address that the device uses for transmissions in Transparent mode. A XBee/XBee-PRO S1 802.15.4 (Legacy) only communicates with other devices having the same channel (CH parameter), PAN ID (ID parameter) and destination address (DH + DL parameters). To transmit using a 16-bit address, set DH to 0 and DL less than 0xFFFF. The broadcast address for the PAN is 0x000000000000FFFF. For more information, see Addressing. Parameter range 0 - 0xFFFFFFFF Default 0 MY (16-bit Source Address) Sets or displays the device's 16-bit source address. Set MY = 0xFFFF to disable reception of packets with 16-bit addresses. The 64-bit source address (serial number) and broadcast address (0x000000000000FFFF) are always enabled. Parameter range 0 - 0xFFFF Default 0 SH (Serial Number High) Displays the upper 32 bits of the unique IEEE 64-bit extended address assigned to the XBee in the factory. The 64-bit source address is always enabled. This value is read-only and it never changes. Parameter range 0 - 0xFFFFFFFF [read-only] Default Set in the factory SL (Serial Number Low) Displays the lower 32 bits of the unique IEEE 64-bit RF extended address assigned to the XBee in the factory. The 64-bit source address is always enabled. This value is read-only and it never changes. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 51 AT commands Networking and security commands Parameter range 0 - 0xFFFFFFFF [read-only] Default Set in the factory RR (XBee Retries) Set or reads the maximum number of retries the device executes in addition to the three retries provided by the 802.15.4 MAC. For each device retry, the 802.15.4 MAC can execute up to three retries. The following applies for broadcast messages: If RR = 0, only one packet is broadcast. If RR is > 0, RR + 2 packets are sent on each broadcast. No acknowledgments are returned on a broadcast. This value does not need to be set on all devices for retries to work. If retries are enabled, the transmitting device sets a bit in the Digi RF Packet header that requests the receiving device to send an ACK. If the transmitting device does not receive an ACK within 200 ms, it re-sends the packet within a random period up to 48 ms. Each device retry can potentially result in the MAC sending the packet four times (one try plus three retries). Retries are not attempted for indirect messages that are purged. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0-6 Default 0 RN (Random Delay Slots) Sets or displays the minimum value of the back-off exponent in the CSMA-CA algorithm. The Carrier Sense Multiple Access - Collision Avoidance (CSMA-CA) algorithm was engineered for collision avoidance. If RN = 0, collision avoidance is disabled during the first iteration of the algorithm (802.15.4 macMinBE). Unlike CSMA-CD, which reacts to network transmissions after collisions have been detected, CSMA-CA acts to prevent data collisions before they occur. As soon as a device receives a packet that is to be transmitted, it checks if the channel is clear (no other device is transmitting). If the channel is clear, the packet is sent over-the-air. If the channel is not clear, the device waits for a randomly selected period of time, then checks again to see if the channel is clear. After a time, the process ends and the data is lost. Parameter range 0 - 3 (exponent) Default 0 XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 52 AT commands Networking and security commands MM (MAC Mode) The MM command is used to set and read the MAC Mode value. The MM command disables/enables the use of a Digi header contained in the 802.15.4 RF packet. By default (MM = 0), Digi Mode is enabled and the module adds an extra header to the data portion of the 802.15.4 packet. This enables the following features: n ND and DN command support n Duplicate packet detection when using ACKs n RR command n DIO/AIO sampling support The MM command allows users to turn off the use of the extra header. Modes 1 and 2 are strict 802.15.4 modes. If the Digi header is disabled, the features above are also disabled. When MM = 1 or 3, MAC retries are not supported. When the Digi header is disabled, encrypted data that is not valid will be sent out of the UART and not filtered out. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-3 Parameter Configuration 0 Digi Mode (802.15.4 + Digi header) 1 802.15.4 (no ACKs) 2 802.15.4 (with ACKs) 3 Digi Mode (no ACKs) Default 0 NI (Node Identifier) Stores the node identifier string for a device, which is a user-defined name or description of the device. This can be up to 20 ASCII characters. n The command automatically ends when the maximum bytes for the string have been entered. Use the ND (Network Discovery) command with this string as an argument to easily identify devices on the network. The DN command also uses this identifier. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 53 AT commands Networking and security commands Parameter range A string of case-sensitive ASCII printable characters from 0 to 20 bytes in length. A carriage return or a comma automatically ends the command. Default N/A ND (Node Discover) Discovers and reports all of the devices found on its current operating channel (CH parameter) and PAN ID (ID parameter). The ND command also accepts a Node Identifier as a parameter. In this case, only a module matching the supplied identifier responds. The ND command uses a 64-bit long address when sending and responding to an ND request. The module transmits a globally addressed ND command packet. The NT (Node Discover Time) parameter determines the amount of time allowed for responses. In AT Command mode, a carriage return (0x0D) designates a command completion. Since two carriage returns end a command response, the application receives three carriage returns at the end of the command. If the device receives no responses, the application only receives one carriage return. When in API mode, the application receives a frame (with no data) and status (set to OK) at the end of the command. When the ND command packet is received, the remote sets up a random time delay (up to 2.2 sec) before replying as follows: Node discover response (AT command mode format - Transparent operation): MY SH SL DB NI (This is part of the response and not the end of command indicator.) Node discover response (API format - data is binary, except with the NI command): 2 bytes for MY (Source Address) value 4 bytes for SH (Serial Number High) value 4 bytes for SL (Serial Number Low) value 1 byte for DB (Received Signal Strength) value NULL-terminated string for NI (Node Identifier) value (max 20 bytes without NULL terminator) Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range Optional 20-character NI value Default N/A XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 54 AT commands Networking and security commands NT (Node Discover Time) Sets the amount of time a base node waits for responses from other nodes when using the ND (Node Discover) command. The NT value is transmitted with the ND command. Remote nodes set up a random hold-off time based on this time. Once the ND command has ended, the base discards any response it receives. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0x1 - 0xFC (x 100 ms) Default 0x19 (2.5 decimal seconds) NO (Node Discovery Options) Enables node discover self-response on the device. Use NO to suppress or include a self-response to ND (Node Discover) commands. When NO bit 1 = 1, a device performing a Node Discover includes a response entry for itself. Note Minimum firmware version required: 1.xC5. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 Default 0x0 DN (Destination Node) Resolves an NI (Node identifier) string to a physical address (case sensitive). The following events occur after DN discovers the destination node: 1. The device sets DL and DH to the extended (64-bit) address of the device with the matching NI string. 2. The receiving device returns OK (or ERROR). 3. The device exits Command mode. If there is no response from a module within 200 milliseconds or you do not specify a parameter (by leaving it blank), the command terminates and returns an ERROR message. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 20-byte ASCII string XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 55 AT commands Networking and security commands Default N/A CE (Coordinator Enable) Sets or displays the coordinator setting. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 Parameter Description 0 End Device 1 Coordinator Default 0 SC (Scan Channels) Sets or displays the list of channels to scan for all Active and Energy Scans as a bit field. This affects scans initiated in the AS (Active Scan) and ED (Energy Scan) commands in Command mode and during End Device Association and Coordinator startup. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFFFF (bit field) Bit field mask: Bit Parameter 0 0x0B (not available on XBee-PRO) 1 0x0C 2 0x0D 3 0x0E 4 0x0F 5 0x10 6 0x11 XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 56 AT commands Networking and security commands Bit Parameter 7 0x12 8 0x13 9 0x14 10 0x15 11 0x16 12 0x17 13 0x18 (not available on XBee-PRO) 14 0x19 (not available on XBee-PRO) 15 0x1A (not available on XBee-PRO) Default 0x1FFE (all XBee-PRO Channels) SD (Scan Duration) Sets or displays the scan duration exponent. Coordinator: If you set the ReassignPANID option on the coordinator (refer to A2 (Coordinator Association)), SD determines the length of time the coordinator scans channels to locate existing PANs. If you set the ReassignChannel option, SD determines how long the coordinator performs an Energy Scan to determine which channel it will operate on. End Device: Duration of Active Scan during Association. In a Beacon system, set SD=BE of the coordinator. SD must be set at least to the highest BE parameter of any Beaconing Coordinator with which an end device or coordinator wants to discover. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Scan Time is measured as: ([# of channels to scan] * (2 ^SD) * 15.36 ms) + (38 ms * [# of channels to scan]) + 20 ms Use the SC (Scan Channels) command to set the number of channels to scan. The XBee can scan up to 16 channels (SC = 0xFFFF). The XBee-PRO can scan up to 13 channels (SC= 0x1FFE). SD influences the time the MAC listens for beacons or runs an energy scan on a given channel. Example The following table shows the results for a thirteen channel scan. SD setting Time 0 0.18 s 2 0.74 s XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 57 AT commands Networking and security commands SD setting Time 4 2.95 s 6 11.80 s 8 47.19 s 10 3.15 min 12 12.58 min 14 50.33 min Parameter range 0 - 0x0F (exponent) Default 4 A1 (End Device Association) Sets or displays the End Device association options. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0x0F (bit field) Bit field: Bit Meaning Setting Description 0 0 Only associates with Coordinator operating on PAN ID that matches device ID. 1 May associate with Coordinator operating on any PAN ID. 0 Only associates with Coordinator operating on matching CH channel setting. 1 May associate with Coordinator operating on any channel. 0 Device will not attempt association. 1 Device attempts association until success. 1 2 ReassignPanID ReassignChannel Auto Associate Note This bit is only for Non-Beacon systems. End Devices in Beacon-enabled system must always associate to a Coordinator. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 58 AT commands Networking and security commands Bit Meaning 3 Setting Description PollCoordOnPinWake 0 Pin Wake does not poll the Coordinator for indirect (pending) data. 1 4  7 Pin Wake sends Poll Request to Coordinator to extract any pending data. Reserved Default 0 A2 (Coordinator Association) Sets or displays the Coordinator association options. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 7 (bit field) Bit field: Bit Meaning ReassignPanID 0 Setting Description 0 Coordinator will not perform Active Scan to locate available PAN ID. It operates on ID (PAN ID). 1 Coordinator performs an Active Scan to determine an available ID (PAN ID). If a PAN ID conflict is found, the ID parameter will change. ReassignChannel 0 1 1 Allow Association 0 2 1 37 Coordinator will not perform Energy Scan to determine free channel. It operates on the channel determined by the CH parameter. Coordinator performs an Energy Scan to find the quietest channel, then operates on that channel. Coordinator will not allow any devices to associate to it. Coordinator allows devices to associate to it. Reserved The binary equivalent of the default value (0x06) is 00000110. ‘Bit 0’ is the last digit of the sequence. Default 0 XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 59 AT commands Networking and security commands AI (Association Indication) Reads errors with the last association request. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Status code Meaning 0x00 Coordinator successfully started or End device successfully associated. 0x01 Active Scan Timeout. 0x02 Active Scan found no PANs. 0x03 Active Scan found a PAN coordinator, but the CoordinatorAllowAssociation bit is not set. 0x04 Active Scan found a PAN, but Coordinator and End Device are not configured to support beacons. 0x05 Active Scan found a PAN, but the Coordinator ID parameter does not match the ID parameter of the End Device. 0x06 Active Scan found PAN, but the Coordinator CH parameter does not match the CH parameter of the End Device. 0x07 Energy Scan Timeout. 0x08 Coordinator start request failed. 0x09 Coordinator could not start due to invalid parameter. 0x0A Coordinator Realignment is in progress. 0x0B Association Request not sent. 0x0C Association Request timed out - no reply received. 0x0D Association Request had an invalid parameter. 0x0E Association Request Channel Access Failure. Request was not transmitted - CCA failure. 0x0F Remote Coordinator did not send an ACK after Association. Request was sent. 0x10 Remote Coordinator did not reply to the Association Request, but an ACK was received after sending the request. 0x11 [reserved] 0x12 Sync-Loss - Lost synchronization with a Beaconing Coordinator. 0x13 Disassociated - No longer associated to Coordinator. 0xFF RF Module is attempting to associate. Parameter range 0 - 0x13 [read-only] XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 60 AT commands Networking and security commands Default N/A DA (Force Disassociation) Causes the End Device to immediately disassociate from a Coordinator (if associated) and re-attempt to associate. Parameter range Default - FP (Force Poll) Requests indirect messages being held by a Coordinator. The FP command is deferred until changes are applied. This prevents indirect messages from arriving at the end device while it is operating in Command mode. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range N/A Default N/A AS (Active Scan) Sends a Beacon Request to a Broadcast address (0xFFFF) and Broadcast PAN (0xFFFF) on every channel in SC. SD determines the amount of time the device listens for Beacons on each channel. A PanDescriptor is created and returned for every Beacon received from the scan. Each PanDescriptor contains the following information: CoordAddress (SH + SL parameters) Note If MY on the coordinator is set less than 0xFFFF, the MY value is displayed. CoordPanID (ID parameter) CoordAddrMode 0x02 = 16-bit Short Address 0x03 = 64-bit Long Address Channel (CH parameter) SecurityUse - will always report 0x00 ACLEntry - will always report 0x00 SecurityFailure - will always report 0x00 SuperFrameSpec (2 bytes): bit 15 - Association Permitted (MSB) - depending on bit 3 of A2 (Coordinator Association) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 61 AT commands Networking and security commands bit 14 - PAN Coordinator bit 13 - Reserved bit 12 - Battery Life Extension bits 8-11 - Final CAP Slot bits 4-7 - Superframe Order bits 0-3 - Beacon Order GtsPermit RSSI (- RSSI is returned as -dBm) TimeStamp (3 bytes) (A carriage return is sent at the end of the AS command) The Active Scan is capable of returning up to five PanDescriptors in a scan. The actual scan time on each channel is measured as: Time = [(2 ^ (SD Parameter)) * 15.36] ms. Total scan time is this time multiplied by the number of channels to be scanned (16 for the XBee and 13 for the XBee-PRO). Refer to the scan table in SD (Scan Duration) to determine scan times. If using API Mode, no ’s are returned in the response. For more information, see Operate in API mode. If no PANs are discovered during the scan, only one carriage return is printed. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-6 Default N/A ED (Energy Scan) Starts an energy detect scan. This parameter command the length of scan on each channel. The command returns the maximal energy on each channel and a carriage return follows each value. An additional carriage return is sent at the end of the command. The values returned represent the detected energy level in units of -dBm. The actual scan time on each channel is measured as: Time = [(2 ^ED) * 15.36] ms. The total scan time is this time multiplied by the number of channels to be scanned. For more information, see the SD (Scan Duration) command. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-6 Default N/A XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 62 AT commands Networking and security commands EE (AES Encryption Enable) Enables or disables Advanced Encryption Standard (AES) encryption. Use this command in conjunction with the KY command. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. The firmware uses the 802.15.4 Default Security protocol and uses AES encryption with a 128-bit key. AES encryption dictates that all devices in the network use the same key, and that the maximum RF packet size is 95 bytes. If C8, bit 0 is not set, see Maximum Payload. When encryption is enabled, the device always uses its 64-bit long address as the source address for RF packets. This does not affect how the MY (Source Address), DH (Destination Address High) and DL (Destination Address Low) parameters work. If MM (MAC Mode) is set to 1 or 2 and AP (API Enable) parameter > 0: With encryption enabled and a 16-bit short address set, receiving devices can only issue RX (Receive) 64-bit indicators. This is not an issue when MM = 0 or 3. If a device with a non-matching key detects RF data, but has an incorrect key: When encryption is enabled, non-encrypted RF packets received are rejected and are not sent out the UART. Parameter range 0-1 Parameter Description 0 Encryption Disabled 1 Encryption Enabled Default 0 KY (AES Encryption Key) Sets the 128-bit AES link key value that the device uses for encryption and decryption. This command is write-only and cannot be read. The command encrypts the entire payload of the packet using the key and computes the CRC across the ciphertext. When encryption is enabled, each packet carries an additional 16 bytes to convey the random CBC Initialization Vector (IV) to the receiver(s). The KY value may be 0 or any 128-bit value. Any other value, including entering KY by itself with no parameters, is invalid. The device receives all KY entries (valid or not) with an OK message. When queried, the system returns an OK message and no value is returned. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - (any 16-byte value) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 63 AT commands RF interfacing commands Default N/A RF interfacing commands The following AT commands are RF interfacing commands. PL (Power Level) Sets or displays the power level at which the device transmits conducted power. Power levels are approximate. When operating in Europe, XBee-PRO 802.15.4 modules must operate at or below a transmit power output level of 10 dBm. Order the international variant of the XBee-PRO module, which has a maximum transmit output power of 10 dBm. Parameter range 0-4 Power level XBee Power level XBee-PRO Power level 0 -10 dBm 10 dBm 1 -6 dBm 12 dBm 2 -4 dBm 14 dBm 3 -2 dBm 16 dBm 4 0 dBm 18 dBm Power level XBee-PRO international variant power level 0 -3 dBm 1 -3 dBm 2 2 dBm 3 8 dBm 4 10 dBm Default 4 CA (CCA Threshold) Set or read the Clear Channel Assessment (CCA) threshold. Prior to transmitting a packet, the device performs a CCA to detect energy on the channel. If the device detects energy above the CCA threshold, it will not transmit the packet. The CA parameter is measured in units of -dBm. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 64 AT commands Sleep commands (low power) Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0x24 - 0x50 -dBm Default 0x2C (-44 decimal dBm) Europe Use the following settings for Europe compliance. Device Hex value Sets to level XBee 0x34 -52 dBm XBee-PRO 0x3B -59 dBm Sleep commands (low power) The following AT commands are sleep commands. SM (Sleep Mode) Sets or displays the sleep mode of the device. By default, Sleep Modes are disabled (SM = 0) and the device remains in Idle/Receive mode. When in this state, the device is constantly ready to respond to either serial or RF activity. Parameter range 0-5 Parameter Description 0 No sleep (disabled) 1 Pin hibernate 2 Pin doze 3 Reserved 4 Cyclic Sleep Remote 5 Cyclic Sleep Remote with pin wakeup 6 Sleep Coordinator1 Note For backwards compatibility with v1.x6 only. Otherwise, use the CE command. 1The Sleep Coordinator option (SM=6) exists for backwards compatibility with firmware version 1.x06 only. In all other cases, use the CE command to enable a Coordinator. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 65 AT commands Sleep commands (low power) Default 0 SO (Sleep Options) Set or read the sleep mode options. Parameter range 0-4 Bit Setting Meaning Description 0 A device configured for cyclic sleep polls for data on waking. 1 0 Normal operations 1 Disable wakeup A device configured for cyclic sleep will not poll for data on waking. poll 0 Normal operations A device configured in a sleep mode with ADC/DIO sampling enabled automatically performs a sampling on wakeup. 1 Suppress sample on wakeup A device configured in a sleep mode with ADC/DIO sampling enabled will not automatically sample on wakeup. Default 0 ST (Time before Sleep) Note This command applies to NonBeacon firmware. Sets or displays the time period of inactivity (no serial or RF data is sent or received) before activating Sleep Mode. The ST parameter is only valid for end devices configured with Cyclic Sleep settings (SM = 4 - 5). Coordinator and End Device ST values must be equal. The GT parameter value must always be less than the ST value. If GT > ST, the configuration renders the module unable to enter into command mode. If you modify the ST parameter, also modify the GT parameter accordingly. Parameter range 1 - 0xFFFF (x 1 ms) Default 0x1388 (5 seconds) SP (Cyclic Sleep Period) Note This command applies to Non-Beacon firmware. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 66 AT commands Serial interfacing commands Sets and reads the duration of time that a remote device sleeps. After the cyclic sleep period is over, the device wakes and checks for data. If data is not present, the device goes back to sleep. The maximum sleep period is 268 seconds (SP = 0x68B0). The SP parameter is only valid if you configure the end device to operate in Cyclic Sleep (SM = 4-6). Coordinator and End Device SP values should always be equal. To send direct messages on a coordinator, set SP = 0. NonBeacon firmware End Device: SP determines the sleep period for cyclic sleeping remotes. The maximum sleep period is 268 seconds (0x68B0). Coordinator: If non-zero, SP determines the time to hold an indirect message before discarding it. A Coordinator discards indirect messages after a period of (2.5 * SP). Parameter range 0 - 0x68B0 (x 10 ms) Default 0 DP (Disassociated Cyclic Sleep Period) Note This command applies to NonBeacon firmware. Sets or displays the sleep period for cyclic sleeping remotes that are configured for Association but that are not associated to a Coordinator. For example, if a device is configured to associate and is configured as a Cyclic Sleep remote, but does not find a Coordinator, it sleeps for DP time before reattempting association. The maximum sleep period is 268 seconds (0x68B0). DP should be > 0 for NonBeacon systems. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 1 - 0x68B0 (x 10 ms) Default 0x3E8 (10 seconds) Serial interfacing commands The following AT commands are serial interfacing commands. BD (Interface Data Rate) Sets or displays the serial interface baud rate for communication between the device's serial port and the host. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 67 AT commands Serial interfacing commands Modified interface data rates do not take effect until you issue a CN (Exit Command mode) command and the system returns the OK response. To request non-standard baud rates with values above 0x80, you can use the Serial Console toolbar in XCTU to configure the serial connection (if the console is connected), or click the Connect button (if the console is not yet connected). When you send non-standard baud rates to a device, it stores the closest interface data rate represented by the number in the BD register. Read the BD command by sending ATBD without a parameter value, and the device returns the value stored in the BD register. The RF data rate is not affected by the BD parameter. If you set the interface data rate higher than the RF data rate, you may need to implement a flow control configuration. Non-standard interface data rates The firmware interprets any value above 0x07 as an actual baud rate. When the firmware cannot configure the exact rate specified, it configures the closest approximation to that rate. For example, to set a rate of 19200 b/s send the following command line: ATBD4B00. Note When using XCTU, you can only set and read non-standard interface data rates using the XCTU Terminal tab. You cannot access non-standard rates through the Modem Configuration tab. When you send the BD command with a non-standard interface data rate, the UART adjusts to accommodate the interface rate you request. In most cases, the clock resolution causes the stored BD parameter to vary from the sent parameter. Sending ATBD without an associated parameter value returns the value actually stored in the device’s BD register. The following table provides the parameters sent versus the parameters stored. BD parameter sent (HEX) Interface data rate (b/s) BD parameter stored (HEX) 0 1200 0 4 19,200 4 7 115,200* 7 12C 300 12B 1C200 115,200 1B207 * The 115,200 baud rate setting is actually at 111,111 baud (-3.5% target UART speed). Parameter range Standard baud rates: 0x0 - 0x7 Non-standard baud rates: 0x80 - 0x3D090 (up to 250 kb/s) Parameter Description 0x0 1200 b/s 0x1 2400 b/s XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 68 AT commands Serial interfacing commands Parameter Description 0x2 4800 b/s 0x3 9600 b/s 0x4 19200 b/s 0x5 38400 b/s 0x6 57600 b/s 0x7 115200 b/s 0x80 - 0x3D090 non-standard baud rates up to 250 kb/s Default 0x03 (9600 b/s) RO (Packetization Timeout) Set or read the number of character times of inter-character silence required before transmission. RF transmission starts when the device detects data in the DI (data in from host) buffer and RO character times of silence are detected on the UART receive lines (after receiving at least 1 byte). RF transmission also starts after 100 bytes (maximum packet size) are received in the DI buffer. Set RO to 0 to transmit characters as they arrive instead of buffering them into one RF packet. Parameter range 0 - 0xFF (x character times) Default 3 AP (API Enable) Disable or Enable API mode to operate using a frame-based API instead of using the default Transparent (UART) mode. For more information, see Operate in API mode. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-2 Parameter Description 0 API disabled (operate in Transparent mode) 1 API enabled 2 API enabled (with escaped control characters) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 69 AT commands Serial interfacing commands Default 0 NB (Parity) The device does not actually calculate and check the parity. It only interfaces with devices at the configured parity and stop bit settings. Parameter range 0x00 - 0x04 Default 0x00 PR (Pull-up/Down Resistor Enable) PR and PD only affect lines that are configured as digital inputs or disabled. The following table defines the bit-field map for PR and PD commands. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Bit I/O line 0 AD4/DIO4 (pin 11) 1 AD3/DIO3 (pin 17) 2 AD2/DIO2 (pin 18) 3 AD1/DIO1 (pin 19) 4 AD0/DIO0 (pin 20) 5 RTS/DIO6 (pin 16) 6 DI8/SLEEP_RQ (pin 9) 7 DIN/CONFIG (pin 3) If you set a PR bit to 1, it enables the pull-up resistor. If you set a PR bit to 0, it specifies no internal pull-up. Parameter range 0 - 0xFF Default 0xFF Example Sending the command ATPR 6F turn bits 0, 1, 2, 3, 5 and 6 ON, and bits 4 and 7 OFF. The binary equivalent of 0x6F is 01101111. Bit 0 is the last digit in the bit field. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 70 AT commands I/O settings commands I/O settings commands The following AT commands are I/O settings commands. D0 (DIO0 Configuration) Sets or displays the DIO0/AD0 configuration (pin 20). The options include analog-to-digital converter, digital input, and digital output. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0, 2 - 5 Parameter Description 0 Disabled 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D1 (DIO1 Configuration) Sets or displays the DIO1/AD1 configuration (pin 19). Parameter range 0, 2 - 6 Parameter Description 0 Disabled 1 Commissioning button 1 N/A 2 ADC 3 Digital input 4 Digital output, low XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 71 AT commands I/O settings commands Parameter Description 5 Digital output, high 6 PTI_EN Default 0 D2 (AD2/DIO2 Configuration) Sets or displays the DIO2/AD2 configuration (pin 18). The options include analog-to-digital converter, digital input, and digital output. Parameter range 0-1 Parameter Description 0 Disabled 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D3 (DIO3 Configuration) Sets or displays the DIO3/AD3 configuration (pin 17). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 Parameter Description 0 Disabled 1 N/A 2 ADC XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 72 AT commands I/O settings commands Parameter Description 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D4 (DIO4 Configuration) Sets or displays the DIO4 configuration (pin 11). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 Parameter Description 0 Disabled 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D5 (DIO5 Configuration) Sets or displays the DIO5 configuration (pin 15). Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 Parameter Description 0 Disabled XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 73 AT commands I/O settings commands Parameter Description 1 Associate LED indicator - blinks when associated 2 ADC 3 Digital input 4 Digital output, default low 5 Digital output, default high Default 1 D6 (DIO6 Configuration) Sets or displays the DIO6/RTS configuration (pin 16). Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 Parameter Description 0 Disabled 1 RTS flow control 2 N/A 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D7 (DIO7 Configuration) Sets or displays the DIO7/CTS configuration (pin 12). This output is 3 V CMOS level, and is useful in a 3 V CMOS to RS-485 conversion circuit (DI8 configuration). Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-1 XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 74 AT commands I/O settings commands Parameter Description 0 Unmonitored digital input 1 CTS flow control 3 Digital input 4 Digital output, low 5 Digital output, high 6 RS-485 Tx enable, low Tx 7 RS-485 Tx enable high, high Tx Default 0x1 D8 (DIO8 Configuration) Sets or displays the DIO8 configuration (pin 4). This command enables you to configure the pin to function as a digital input. This line is also used with Pin Sleep. Parameter range 0-1 Parameter Description 0 Disabled 1 N/A 2 N/A 3 Digital input 4 N/A 5 N/A Default 0 IU (I/O Output Enable) The IU command disables or enables I/O UART output. When enabled (IU = 1), received I/O line data packets are sent out the UART. The data is sent using an API frame regardless of the current AP parameter value. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 75 AT commands I/O settings commands Enable or disable the serial output of received I/O sample data when I/O line passing is enabled. IU only affects the device’s behavior when IA is set to a non-default value. When IU is enabled, any received I/O sample data is sent out the UART/SPI interface using an API frame. Sample data is only generated if the local device is operating in API mode (AP = 1 or 2). Parameter range 0-1 Parameter Description 0 Disabled 1 Enabled Default 1 IT (Samples before TX) Sets or displays the number of samples to collect before transmitting data. The maximum number of samples is dependent on the number of enabled I/O lines and the maximum payload available. If IT is set to a number too big to fit in the maximum payload, it is reduced such that it will fit in a single frame. No more than 44 samples can fit in a single frame or IT=0x2C. One ADC sample is considered complete when all enabled ADC channels have been read. The device can buffer up to 88 bytes of sample data. Since the module uses a 10-bit A/D converter, each sample uses two bytes. When Sleep Modes are enabled and IR (Sample Rate) is set, the device remains awake until IT samples have been collected. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 1 - 0xFF Default 1 IS (Force Sample) Force a read of all enabled inputs (DI or ADC). The command returns data through the UART. If no inputs are defined (DI or ADC), the command returns and error. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. When operating in Transparent mode (AP = 0), the data is returned in the following format: All bytes are converted to ASCII: number of samples channel mask XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 76 AT commands I/O settings commands DIO data (If DIO lines are enabled) ADC channel Data (This will repeat for every enabled ADC channel) (end of data noted by extra ) When operating in API mode (AP = 1), the command immediately returns an OK response. The data follows in the normal API format for DIO data. Parameter range N/A Default N/A IO (Digital Output Level) Sets digital output levels. This allows DIO lines setup as outputs to be changed through Command mode. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 8-bit bit map; each bit represents the level of an I/O line set up as an output Default N/A IC (DIO Change Detect) Set or read the digital I/O pins to monitor for changes in the I/O state. Each bit enables monitoring of DIO0 - DIO7 for changes. If detected, data is transmitted with DIO data only. Any samples queued waiting for transmission is sent first. See ADC and Digital I/O line support for more information about the IC command. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (bit field) Default 0 (disabled) IR (Sample Rate) Set or read the I/O sample rate to enable periodic sampling. When set, this parameter samples all enabled DIO/ADC lines at a specified interval. This command allows periodic reads of the ADC and DIO lines in a non-Sleep Mode setup. We do not recommend a sample rate that requires transmissions at a rate greater than once every 20 ms. Example: When IR = 0x14, the sample rate is 20 ms (or 50 Hz). XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 77 AT commands I/O settings commands Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. WARNING! If you set IR to 1 or 2, the device will not keep up and many samples will be lost. Parameter range 0 - 0xFFFF (x 1 ms) Default 0 IA (I/O Input Address) Sets or displays addresses of module to which outputs are bound. Setting all bytes to 0xFF will not allow any received I/O packet to change outputs. Setting the address to 0xFFFF allows any received I/O packet to change outputs. You can use the IA command to set or read both 16 and 64-bit addresses. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. The source address of the device to which outputs are bound. If an I/O sample is received from the address specified, any pin that is configured as a digital output or PWM changes its state to match that of the I/O sample. Set IA to 0xFFFFFFFFFFFFFFFF to disable I/O line passing. Set IA to 0xFFFF to allow any I/O packet addressed to this device (including broadcasts) to change the outputs. Parameter range 0 - 0xFFFFFFFFFFFFFFFF Default 0xFFFFFFFFFFFFFFFF T0 (D0 Output Timeout) Sets or displays output timeout values for lines that correspond with the D0 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 78 AT commands I/O settings commands Default 0xFF T1 (D1 Output Timeout) Sets or displays output timeout values for lines that correspond with the D1 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) Default 0xFF T2 (D2 Output Timeout) Sets or displays output timeout values for lines that correspond with the D2 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) Default 0xFF T3 (D3 Output Timeout) Sets or displays output timeout values for lines that correspond with the D3 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 79 AT commands I/O settings commands Default 0xFF T4 (D4 Output Timeout) Sets or displays output timeout values for lines that correspond with the D4 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) Default 0xFF T5 (D5 Output Timeout) Sets or displays output timeout values for lines that correspond with the D5 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) Default 0xFF T6 (D6 Output Timeout) Sets or displays output timeout values for lines that correspond with the D6 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 80 AT commands I/O settings commands Default 0xFF T7 (D7 Output Timeout) Sets or displays output timeout values for lines that correspond with the D7 parameter. When the output is set (due to I/O line passing) to a non-default level, a timer starts that sets the output to its default level when it expires. The timer resets when a valid I/O packet is received. The Tn parameter defines the permissible amount of time to stay in a non-default (active) state. If Tn = 0, Output Timeout is disabled (output levels are held indefinitely). Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) Default 0xFF P0 (PWM0 Configuration) Sets or displays the PWM0 configuration (pin 6). This command enables the option of translating incoming data to a PWM so that the output can be translated back into analog form. If the IA (I/O Input Address) parameter is correctly set and P0 is configured as PWM0 output, incoming AD0 samples automatically modify the PWM0 value. Parameter range 0-2 Parameter Description 0 Disabled 1 RSSI 2 PWM0 output Default 1 P1 (PWM1 Configuration) Sets or displays the DIO11/PWM1 configuration (pin 7). Sets or displays the PWM1 configuration (pin 7). P1 enables translating incoming data to a PWM so that the output can be translated back into analog form. If IA (I/O Input Address) is correctly set and P1 is configured as PWM1 output, incoming AD1 samples automatically modify the PWM1 value. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 81 AT commands I/O settings commands Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0, 2 Parameter Description 0 Disabled 1 N/A 2 PWM1 output Default 0 M0 (PWM0 Output Level) Sets or displays output level of the PWM0 line (pin 6). Before setting the line as an output: 1. Enable PWM0 output (P0 = 2). 2. Apply settings (use CN or AC). The PWM period is 64 µs and there are 0x03FF (1023 decimal) steps within this period. When M0 = 0 (0% PWM), 0x01FF (50% PWM), 0x03FF (100% PWM), and so forth. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0x3FF Default 0 M1 (PWM1 Output Level) Sets or displays the PWM1 output level (pin 7). Before setting the line as an output: 1. Enable PWM1 output (P1 = 2). 2. Apply settings (use CN or AC) Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0x3FF XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 82 AT commands Diagnostic commands Default 0 PT (PWM Output Timeout) Sets or displays the output timeout value for both PWM outputs. When PWM is set to a non-zero value (due to I/O line passing), a timer is starts that sets the PWM output to zero when it expires. The timer resets when it receives a valid I/O packet. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFF (x 100 ms) Default 0xFF RP (RSSI PWM Timer) Enables a pulse-width modulated (PWM) output on the RF device. We calibrate the pin to show the difference between received signal strength and the sensitivity level of the device. PWM pulses vary from 24 to 100 percent. Zero percent means PWM output is inactive. One to 24% percent means the received RF signal is at or below the published sensitivity level of the module. The following table shows dB levels above sensitivity and PWM values. The total time period of the PWM output is 64 µs. PWM output consists of 445 steps, so the minimum step size is 144 ms. dB above sensitivity PWM percentage (high period / total period) 10 41% 20 58% 30 75% A non-zero value defines the time that PWM output is active with the RSSI value of the last RF packet the device receives. After the set time when the device has not received RF packets, it sets the PWM output low (0 percent PWM) until the device receives another RF packet. It also sets PWM output low at power-up. A parameter value of 0xFF permanently enables PWM output and always reflects the value of the last received RF packet. Parameter range 0 - 0xFF [x 100 ms] Default 0x28 (4 seconds) Diagnostic commands The following AT commands are diagnostic commands. Diagnostic commands are typically volatile and will not persist across a power cycle. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 83 AT commands Diagnostic commands VR (Firmware Version) Reads the firmware version on a device. Firmware version numbers have four significant digits. The reported number shows three or four numbers in hexadecimal notation. A version is reported as ABCD. Digits ABC are the main release number and D is the revision number from the main release. D is not required and if it is not present, a zero is assumed for D. B is a variant designator. The following variants exist: n 0 = Non-Beacon Enabled 802.15.4 Code n 1 = Beacon Enabled 802.15.4 Code Parameter range 0 - 0xFFFF [read-only] Default Set in the factory VL (Version Long) Shows detailed version information including the application build date, MAC, PHY, and bootloader versions. The VL command has been deprecated in version 10C9. It is not supported in firmware versions after 10C8. Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range N/A Default N/A HV (Hardware Version) Display the hardware version number of the device. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFFFF [read-only] Default Set in firmware DB (Last Packet RSSI) Reports the RSSI in -dBm of the last received RF data packet. DB returns a hexadecimal value for the dBm measurement. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 84 AT commands Diagnostic commands It reports the absolute value. For example, if DB returns 0x58 (-88 dBm), the reported value is accurate between -40 dBm and RX sensitivity. If the XBee/XBee-PRO S1 802.15.4 (Legacy) has been reset and has not yet received a packet, DB reports 0. Parameter range 0x17 - 0x5C (XBee) [read-only] 0x24 - 0x64 (XBee-PRO) [read-only] Default N/A EC (CCA Failures) ReSets or displays the count of Clear Channel Assessment (CCA) failures. This register increments when the device does not transmit a packet because it detected energy above the CCA threshold level set with CA command. This count saturates at its maximum value. Set the count to zero to reset the count. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFFFF Default N/A EA (ACK Failures) Resets or displays the count of acknowledgment failures. This register increments when the device expires the retries without receiving an ACK on a packet transmission. This count saturates at its maximum value. Set the count to zero to reset the count. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0 - 0xFFFF Default N/A ED (Energy Scan) Starts an energy detect scan. This parameter command the length of scan on each channel. The command returns the maximal energy on each channel and a carriage return follows each value. An additional carriage return is sent at the end of the command. The values returned represent the detected energy level in units of -dBm. The actual scan time on each channel is measured as: XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 85 AT commands Command mode options Time = [(2 ^ED) * 15.36] ms. The total scan time is this time multiplied by the number of channels to be scanned. For more information, see the SD (Scan Duration) command. Note Minimum firmware version required: 1.x80. Firmware versions are numbered in hexadecimal notation. Parameter range 0-6 Default N/A Command mode options The following commands are Command mode option commands. CT (Command Mode Timeout) Sets or displays the Command mode timeout parameter. If a device does not receive any valid commands within this time period, it returns to Idle mode from Command mode. Use the CN (Exit Command Mode) command to exit Command Mode manually. Parameter range 2 - 0xFFFF (x 100 ms) Default 0x64 (10 seconds) CN (Exit Command mode) Immediately exits Command Mode and applies pending changes. Parameter range N/A Default N/A AC (Apply Changes) Apply changes to queued parameter values and re-initialize the device. Applying changes means that the device is re-initialized based on changes made to its parameter values. Once changes are applied, the device immediately operates according to the new parameter values. This behavior is in contrast to issuing the WR (Write) command. The WR command saves parameter values to non-volatile memory, but the device still operates according to previously saved values until the device is rebooted or the CN (Exit Command Mode) is issued. For more information, see Queue Local AT Command Request - 0x09. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 86 AT commands Command mode options Note Minimum firmware version required: 1.xA0. Firmware versions are numbered in hexadecimal notation. Parameter range N/A Default N/A GT (Guard Times) Set the required period of silence before and after the command sequence characters of the Command mode sequence (GT + CC + GT). The period of silence prevents inadvertently entering Command mode. See Command mode options for more information about Command mode. Parameter range 0x2 - 0xCE4 (x 1 ms) Default 0x3E8 (one second) CC (Command Sequence Character) Sets or displays the ASCII character value the device uses between Guard Times of the Command mode sequence (GT + CC + GT). The Command mode sequence enters the device into Command mode so the device recognizes data entering from the host as commands instead of payload. For more information about Command mode sequence, see Command mode options. Parameter range 0 - 0xFF Default 0x2B (the ASCII plus character: +) XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 87 API operation By default, XBee/XBee-PRO RF Modules act as a serial line replacement (Transparent Operation). All UART data received through the DI pin is queued up for RF transmission. When the module receives an RF packet, it sends the data out the DO pin with no additional information. The following behaviors are Inherent to Transparent Operation: n If device parameter registers need to be set or queried, transitioning the module into Command Mode requires a special operation. n In point-to-multipoint systems, the application must send extra information so the receiving devices can distinguish between data coming from different remotes. The Application Programming Interface (API) operations are available as an alternative to the default Transparent Operation. API operation requires communication with the device through a structured interface where data is communicated in frames in a defined order. The API specifies how commands, command responses, and status messages are sent and received from the device using a UART data frame. API frame specifications Calculate and verify checksums API types XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 89 90 91 88 API operation API frame specifications API frame specifications The firmware supports two API operating modes: without escaped characters and with escaped characters. Use the AP command to enable either mode. To configure a device to one of these modes, set the following AP parameter values: AP command setting Description AP = 0 Transparent operating mode, UART serial line replacement with API modes disabled. This is the default option. AP = 1 API operation. AP = 2 API operation with escaped characters (only possible on UART). The API data frame structure differs depending on what mode you choose. The firmware silently discards any data it receives prior to the start delimiter. If the device does not receive the frame correctly or if the checksum fails, the device discards the frame. API operation (AP parameter = 1) We recommend this API mode for most applications. The following table shows the data frame structure when you enable this mode: Frame fields Byte Description Start delimiter 1 0x7E Length 2-3 Most Significant Byte, Least Significant Byte Frame data 4-n API-specific structure Checksum n+1 1 byte API operation-with escaped characters (AP parameter = 2) Set API to 2 to allow escaped control characters in the API frame. Due to its increased complexity, we only recommend this API mode in specific circumstances. API 2 may help improve reliability if the serial interface to the device is unstable or malformed frames are frequently being generated. When operating in API 2, if an unescaped 0x7E byte is observed, it is treated as the start of a new API frame and all data received prior to this delimiter is silently discarded. For more information on using this API mode, refer to the following knowledge base article: http://knowledge.digi.com/articles/Knowledge_Base_Article/Escaped-Characters-and-API-Mode-2 The following table shows the structure of an API frame with escaped characters: Frame fields Byte Description Start delimiter 1 0x7E XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 89 API operation Calculate and verify checksums Frame fields Byte Description Length 2-3 Most Significant Byte, Least Significant Byte Frame data 4-n API-specific structure Checksum n + 1 1 byte Characters escaped if needed Escape characters When sending or receiving a UART data frame, you must escape (flag) specific data values so they do not interfere with the data frame sequencing. To escape an interfering data byte, insert 0x7D and follow it with the byte to be escaped XOR’d with 0x20. If not escaped, 0x11 and 0x13 are sent as is. Data bytes that need to be escaped: n 0x7E – Frame delimiter n 0x7D – Escape n 0x11 – XON n 0x13 – XOFF Example - Raw UART data frame (before escaping interfering bytes): 0x7E 0x00 0x02 0x23 0x11 0xCB 0x11 needs to be escaped which results in the following frame: 0x7E 0x00 0x02 0x23 0x7D 0x31 0xCB Note In the previous example, the length of the raw data (excluding the checksum) is 0x0002 and the checksum of the non-escaped data (excluding frame delimiter and length) is calculated as: 0xFF - (0x23 + 0x11) = (0xFF - 0x34) = 0xCB. Calculate and verify checksums To calculate the checksum of an API frame: 1. Add all bytes of the packet, except the start delimiter 0x7E and the length (the second and third bytes). 2. Keep only the lowest 8 bits from the result. 3. Subtract this quantity from 0xFF. To verify the checksum of an API frame: 1. Add all bytes including the checksum; do not include the delimiter and length. 2. If the checksum is correct, the last two digits on the far right of the sum equal 0xFF. Example Consider the following sample data packet: 7E 00 0A 01 01 50 01 00 48 65 6C 6C 6F B8 Byte(s) Description 7E Start delimiter 00 0A Length bytes XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 90 API operation API types Byte(s) Description 01 API identifier 01 API frame ID 50 01 Destination address low 00 Option byte 48 65 6C 6C 6F Data packet B8 Checksum To calculate the check sum you add all bytes of the packet, excluding the frame delimiter 7E and the length (the second and third bytes): 7E 00 0A 01 01 50 01 00 48 65 6C 6C 6F B8 Add these hex bytes: 01 + 01 + 50 + 01 + 00 + 48 + 65 + 6C + 6C + 6F = 247 Now take the result of 0x247 and keep only the lowest 8 bits which, in this example, is 0x47 (the two far right digits). Subtract 0x47 from 0xFF and you get 0xB8 (0xFF - 0x47 = 0xB8). 0xB8 is the checksum for this data packet. If an API data packet is composed with an incorrect checksum, the XBee/XBee-PRO S1 802.15.4 (Legacy) will consider the packet invalid and will ignore the data. To verify the check sum of an API packet add all bytes including the checksum (do not include the delimiter and length) and if correct, the last two far right digits of the sum will equal FF. 01 + 01 + 50 + 01 + 00 + 48 + 65 + 6C + 6C + 6F + B8 = 2FF API types This field contains the information that a device receives or transmits. The structure of frame data depends on the purpose of the API frame: Start delimiter Frame data Length API identifier 1 2 3 4 0x7E MSB LSB cmdID Checksum Identifier-specific Data 5 6 7 8 9 cmdData ... n n+1 Single byte The cmdID frame (API-identifier) indicates which API messages contains the cmdData frame (Identifier-specific data). The device sends multi-byte values big endian format. Modem Status - 0x8A Description This frame type is emitted in response to specific conditions. The status field of this frame indicates the device behavior. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 91 API operation API types Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Offset Size Field Description 0 8bit Start Delimiter Indicates the start of an API frame. 1 16bit Length Number of bytes between the length and checksum. 3 8bit Frame type Modem Status - 0x8A 4 8bit Modem status Complete list of modem statuses: 0x00 = Hardware reset or power up 0x01 = Watchdog timer reset 0x02 = Joined network 0x03 = Left network 0x06 = Coordinator started 0x07 = Network security key was updated 0x0B = Network woke up 0x0C = Network went to sleep 0x0D = Voltage supply limit exceeded 0x0E = Remote Manager connected 0x0F = Remote Manager disconnected 0x11 = Modem configuration changed while join in progress 0x12 = Access fault 0x13 = Fatal error 0x3B = Secure session successfully established 0x3C = Secure session ended 0x3D = Secure session authentication failed 0x3E = Coordinator detected a PAN ID conflict but took no action 0x3F = Coordinator changed PAN ID due to a conflict 0x32 = BLE Connect 0x33 = BLE Disconnect 0x34 = Bandmask configuration failed 0x35 = Cellular component update started 0x36 = Cellular component update failed 0x37 = Cellular component update completed 0x38 = XBee firmware update started 0x39 = XBee firmware update failed 0x3A = XBee firmware update applying 0x40 = Router PAN ID was changed by coordinator due to a conflict 0x42 = Network Watchdog timeout expired 0x80 through 0xFF = Stack error Refer to the tables below for a filtered list of status codes that are appropriate for specific devices. EOF 8bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 92 API operation API types Modem status codes Statuses for specific modem types are listed here. XBee 802.15.4 0x00 = Hardware reset or power up 0x01 = Watchdog timer reset 0x02 = End device successfully associated with a coordinator 0x03 = End device disassociated from coordinator or coordinator failed to form a new network 0x06 = Coordinator formed a new network 0x0D = Voltage supply limit exceeded 0x3B = XBee 3 - Secure session successfully established 0x3C = XBee 3 - Secure session ended 0x3D = XBee 3 - Secure session authentication failed 0x32 = XBee 3 - BLE Connect 0x33 = XBee 3 - BLE Disconnect 0x34 = XBee 3 - No Secure Session Connection Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Boot status When a device powers up, it returns the following API frame: 7E 00 02 8A 00 75 Frame type Modem Status 0x8A 0x00 Status Hardware Reset Local AT Command Request - 0x08 Response frame: Local AT Command Response - 0x88 Description This frame type is used to query or set command parameters on the local device. Any parameter that is set with this frame type will apply the change immediately. If you wish to queue multiple parameter changes and apply them later, use the Queue Local AT Command Request - 0x09 instead. When querying parameter values, this frame behaves identically to Queue Local AT Command Request - 0x09: You can query parameter values by sending this frame with a command but no parameter value field—the two-byte AT command is immediately followed by the frame checksum. When an AT command is queried, a Local AT Command Response - 0x88 frame is populated with the parameter value that is currently set on the device. The Frame ID of the 0x88 response is the same one set by the command in the 0x08 request frame. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 93 API operation API types Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Local AT Command Request - 0x08 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to0, the device will not emit a response frame. 5 16-bit AT command The two ASCII characters that identify the AT Command. 7-n variable Parameter value (optional) If present, indicates the requested parameter value to set the given register. If no characters are present, it queries the current parameter value and returns the result in the response. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set the local command parameter Set the NI string of the radio to "End Device". The corresponding Local AT Command Response - 0x88 with a matching Frame ID will indicate whether the parameter change succeeded. 7E 00 0E 08 A1 4E 49 45 6E 64 20 44 65 76 69 63 65 38 Frame type Frame ID AT command Parameter value 0x08 0xA1 0x4E49 0x456E6420446576696365 Request Matches response "NI" "End Device" Query local command parameter Query the temperature of the module—TP command. The corresponding Local AT Command Response - 0x88 with a matching Frame ID will return the temperature value. 7E 00 04 08 17 54 50 3C XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 94 API operation API types Frame type Frame ID AT command Parameter value 0x08 0x17 0x5450 (omitted) Request Matches response "TP" Query the parameter Queue Local AT Command Request - 0x09 Response frame: Local AT Command Response - 0x88 Description This frame type is used to query or set queued command parameters on the local device. In contrast to Local AT Command Request - 0x08, this frame queues new parameter values and does not apply them until you either: n Issue a Local AT Command using the 0x08 frame n Issue an AC command—queued or otherwise When querying parameter values, this frame behaves identically to Local AT Command Request - 0x08: You can query parameter values by sending this frame with a command but no parameter value field— the two-byte AT command is immediately followed by the frame checksum. When an AT command is queried, a Local AT Command Response - 0x88 frame is populated with the parameter value that is currently set on the device. The Frame ID of the 0x88 response is the same one set by the command in the 0x09 request frame. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Queue Local AT Command Request - 0x09 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to0, the device will not emit a response frame. 5 16-bit AT command The two ASCII characters that identify the AT Command. 7-n variable Parameter value (optional) If present, indicates the requested parameter value to set the given register at a later time. If no characters are present, it queries the current parameter value and returns the result in the response. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Queue setting local command parameter Set the UART baud rate to 115200, but do not apply changes immediately. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 95 API operation API types The device will continue to operate at the current baud rate until the change is applied with a subsequent AC command. The corresponding Local AT Command Response - 0x88 with a matching Frame ID will indicate whether the parameter change succeeded. 7E 00 05 09 53 42 44 07 16 Frame type Frame ID AT command Parameter value 0x09 0x53 0x4244 0x07 Request Matches response "BD" 7 = 115200 baud Query local command parameter Query the temperature of the module (TP command). The corresponding Local AT Command Response - 0x88 frame with a matching Frame ID will return the temperature value. 7E 00 04 09 17 54 50 3B Frame type Frame ID AT command Parameter value 0x09 0x17 0x5450 (omitted) Request Matches response "TP" Query the parameter Local AT Command Response - 0x88 Request frames: n Local AT Command Request - 0x08 n Queue Local AT Command Request - 0x09 Description This frame type is emitted in response to a local AT Command request. Some commands send back multiple response frames; for example, ND (Node Discover). Refer to individual AT command descriptions for details on API response behavior. This frame is only emitted if the Frame ID in the request is non-zero. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 Start Delimiter 8-bit Indicates the start of an API frame. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 96 API operation API types Offset Size Frame Field Description 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Local AT Command Response - 0x88 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 16-bit AT command The two ASCII characters that identify the AT Command. 7 8-bit Command status Status code for the host's request: 0 = OK 1 = ERROR 2 = Invalid command 3 = Invalid parameter 8-n variable Command data (optional) If the host requested a command parameter change, this field will be omitted. If the host queried a command by omitting the parameter value in the request, this field will return the value currently set on the device. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set local command parameter Host set the NI string of the local device to "End Device" using a 0x08 request frame. The corresponding Local AT Command Response - 0x88 with a matching Frame ID is emitted as a response: 7E 00 05 88 01 4E 49 00 DF Frame type Frame ID AT command Command Status Command data 0x88 0xA1 0x4E49 Response Matches request "NI" 0x00 (omitted) Success Parameter changes return no data Query local command parameter Host queries the temperature of the local device—TP command—using a 0x08 request frame. The corresponding Local AT Command Response - 0x88 with a matching Frame ID is emitted with the temperature value as a response: 7E 00 07 88 01 54 50 00 FF FE D5 XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 97 API operation API types Frame type Frame ID AT command Command Status Command data 0x88 0x17 0x5450 0x00 0xFFFE Response Matches request "TP" Success -2 °C Remote AT Command Request - 0x17 Response frame: Remote AT Command Response- 0x97 Description This frame type is used to query or set AT command parameters on a remote device. For parameter changes on the remote device to take effect, you must apply changes, either by setting the Apply Changes options bit, or by sending an AC command to the remote. When querying parameter values you can query parameter values by sending this framewith a command but no parameter value field—the two-byte AT command is immediately followed by the frame checksum. When an AT command is queried, a Remote AT Command Response- 0x97 frame is populated with the parameter value that is currently set on the device. The Frame ID of the 0x97 response is the same one set by the command in the 0x17 request frame. Note Remote AT Command Requests should only be issued as unicast transmissions to avoid potential network disruption. Broadcasts are not acknowledged, so there is no guarantee all devices will receive the request. Responses are returned immediately by all receiving devices, which can cause congestion on a large network. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Remote AT Command Request - 0x17. 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to 0, the device will not emit a response frame. 5 64-bit 64-bit destination address Set to the 64-bit IEEE address of the destination device. 13 16-bit Reserved Unused, but this field is typically set to 0xFFFE. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 98 API operation API types Offset Size Frame Field Description 15 Remote command options Bit field of options that apply to the remote AT command request: 8-bit n Bit 0: Disable ACK [0x01] n Bit 1: Apply changes on remote [0x02] l If not set, changes will not applied until the device receives an AC command or a subsequent command change is received with this bit set n Bit 2: Reserved (set to 0) n Bit 3: Reserved (set to 0) n Bit 4: Send the remote command securely [0x10] Note Option values may be combined. Set all unused bits to 0. AT command The two ASCII characters that identify the AT Command. 16 16-bit 18-n variable Parameter value (optional) If present, indicates the requested parameter value to set the given register. If no characters are present, it queries the current parameter value and returns the result in the response. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes—AP = 1—and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set remote command parameter Set the NI string of a device with the 64-bit address of 0013A20012345678 to "Remote" and apply the change immediately. The corresponding Remote AT Command Response- 0x97 with a matching Frame ID will indicate success. 7E 00 15 17 27 00 13 A2 00 12 34 56 78 FF FE 02 4E 49 52 65 6D 6F 74 65 F6 Frame type Frame ID 64-bit dest Command Reserved options 0x17 0x27 0x0013A200 0xFFFE 12345678 Request Matches response Unused AT command Parameter value 0x02 0x4E49 0x52656D6F7465 Apply Change "NI" "Remote" Queue remote command parameter change Change the PAN ID of a remote device so it can migrate to a new PAN, since this change would cause network disruption, the change is queued so that it can be made active later with a subsequent AC XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 99 API operation API types command or written to flash with a queued WR command so the change will be active after a power cycle. The corresponding Remote AT Command Response- 0x97 with a matching Frame ID will indicate success. 7E 00 11 17 68 00 13 A2 00 12 34 56 78 FF FE 00 49 44 04 51 D8 Frame type Frame ID 64-bit dest Command Reserved options 0x17 0x68 0x0013A200 0xFFFE 12345678 Request Matches response Unused AT command Parameter value 0x00 0x4944 0x0451 Queue Change "ID" Query remote command parameter Query the temperature of a remote device—TP command. The corresponding Remote AT Command Response- 0x97 with a matching Frame ID will return the temperature value. 7E 00 0F 17 FA 00 13 A2 00 12 34 56 78 FF FE 00 54 50 84 Frame type Frame ID 64-bit dest Command Reserved options 0x17 0xFA 0x0013A200 0xFFFE 12345678 Request Matches response Unused AT command Parameter value 0x00 0x5450 (omitted) N/A "TP" Query the parameter Remote AT Command Response- 0x97 Request frame: Remote AT Command Request - 0x17 Description This frame type is emitted in response to a Remote AT Command Request - 0x17. Some commands send back multiple response frames; for example, the ND command. Refer to individual AT command descriptions for details on API response behavior. This frame is only emitted if the Frame ID in the request is non-zero. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 100 API operation API types Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Remote AT Command Response - 0x97 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 64-bit 64-bit source address The sender's 64-bit address. 13 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 15 16-bit AT command The two ASCII characters that identify the AT Command. 17 8-bit Command status Status code for the host's request: 0x00 = OK 0x01 = ERROR 0x02 = Invalid command 0x03 = Invalid parameter 0x04 = Transmission failure 0x0C = Encryption error 18-n variable Parameter value (optional) If the host requested a command parameter change, this field will be omitted. If the host queried a command by omitting the parameter value in the request, this field will return the value currently set on the device. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set remote command parameter Host set the NI string of a remote device to "Remote" using a Remote AT Command Request - 0x17. The corresponding 0x97 Remote AT Command Response with a matching Frame ID is emitted as a response: 7E 00 0F 97 27 00 13 A2 00 12 34 56 78 12 7E 4E 49 00 51 XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 101 API operation API types Frame type Frame ID 0x97 0x27 64-bit source AT Command Reserved command Status 0x0013A200 0x127E 12345678 Unused Response Matches request Command data 0x4E49 0x00 (omitted) "NI" Success Parameter changes return no data Transmission failure Host queued the the PAN ID change of a remote device using a Remote AT Command Request - 0x17. Due to existing network congestion, the host will retry any failed attempts. The corresponding 0x97 Remote AT Command Response with a matching Frame ID is emitted as a response: 7E 00 0F 97 27 00 13 A2 00 12 34 56 78 FF FE 49 44 04 EA Frame type Frame ID 0x97 0x27 64-bit source AT Command Reserved command Status 0x0013A200 0xFFFE 12345678 Unused Response Matches request Command data 0x4944 0x04 (omitted) "ID" Transmission failure Parameter changes return no data Query remote command parameter Query the temperature of a remote device—. The corresponding 0x97 Remote AT Command Response with a matching Frame ID is emitted with the temperature value as a response: 7E 00 11 97 27 00 13 A2 00 12 34 56 78 FF FE 54 50 00 00 2F A8 Frame type Frame ID 0x97 0x27 Response Matches request 64-bit source Reserved AT command 0x0013A200 0x0013A200 0x4944 12345678 12345678 Unused "TP" Command Status Command data 0x00 0x002F Success +47 °C 64-bit Transmit Request - 0x00 Response frame: Transmit Status - 0x89 Description This frame type is used to send serial payload data as an RF packet to a remote device with a corresponding 64-bit IEEE address. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 102 API operation API types Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Transmit Request frame - 0x10 to initiate API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 64-bit Transmit Request - 0x00 4 8-bit Frame ID 5 64-bit Destination Set to the 64-bit IEEE address of the destination device. If set to 0x000000000000FFFF, the broadcast address is used. address 13 8-bit Options Identifies the data frame for the host to correlate with a subsequent response. If set to 0, the device will not emit a response frame. A bit field of options that affect the outgoing transmission: n Bit 0: Disable MAC ACK [0x01] n Bit 1: Reserved (set to 0) n Bit 2: Send packet with Broadcast PAN ID [0x04] l 802.15.4 firmwares only Note Option values may be combined. Set all unused bits to 0. 14-n variable RF data The serial data to be sent to the destination. Use NP to query the maximum payload size that can be supported based on current settings. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast Sending a unicast transmission to a device with the 64-bit address of 0013A20012345678 with the serial data "TxData". The corresponding Transmit Status - 0x89 response with a matching Frame ID will indicate whether the transmission succeeded. 7E 00 11 00 52 00 13 A2 00 12 34 56 78 00 54 78 44 61 74 61 9E XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 103 API operation API types Frame type Frame ID 64-bit dest address Tx options RF data 0x00 0x52 0x0013A200 12345678 0x00 0x547844617461  Input Matches response "TxData" 64-bit broadcast Sending a broadcast transmission of the serial data "Broadcast" and suppressing the corresponding response by setting Frame ID to 0. 7E 00 14 00 00 00 00 00 00 00 00 FF FF 00 42 72 6F 61 64 63 61 73 74 6E Frame type Frame ID 64-bit dest address Tx options RF data 0x00 0x00 0x00000000 0000FFFF 0x00 0x42726F616463617374 Input Suppress response Broadcast address "Broadcast" 16-bit Transmit Request - 0x01 Response frame: Transmit Status - 0x89 Description This frame type is used to send serial payload data as an RF packet to a remote device with a corresponding 16-bit network address. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Transmit Request frame - 0x10 to initiate API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 16-bit Transmit Request - 0x01 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to 0, the device will not emit a response frame. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 104 API operation API types Frame Field Offset Size Description 5 16-bit Destination Set to the 16-bit network address of the destination device. If set to 0xFFFF, the broadcast address is used. address 7 8-bit Options A bit field of options that affect the outgoing transmission: n Bit 0: Disable MAC ACK [0x01] n Bit 1: Reserved (set to 0) n Bit 2: Send packet with Broadcast PAN ID [0x04] l 802.15.4 firmwares only Note Option values may be combined. Set all unused bits to 0. 8-n variable RF data The serial data to be sent to the destination. Use NP to query the maximum payload size that can be supported based on current settings. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 16-bit unicast Sending a unicast transmission to a device with the 16-bit address of 1234 with the serial data "TxData". The corresponding Transmit Status - 0x89 response with a matching Frame ID will indicate whether the transmission succeeded. 7E 00 0B 01 87 12 34 00 54 78 44 61 74 61 EB Frame type Frame ID 16-bit dest address Tx options RF data 0x01 0x87 0x1234 0x00 0x547844617461  Input Matches response "TxData" 16-bit broadcast Sending a broadcast transmission of the serial data "Broadcast" and suppressing the corresponding response by setting Frame ID to 0. 7E 00 0E 01 00 FF FF 00 42 72 6F 61 64 63 61 73 74 6D Frame type Frame ID 16-bit dest address Tx options RF data 0x01 0x00 0xFFFF 0x00 0x42726F616463617374 Input Suppress response Broadcast address XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide "Broadcast" 105 API operation API types Transmit Status - 0x89 Request frames: n TX Request: 64-bit address frame - 0x00 n TX Request: 16-bit address - 0x01 n User Data Relay Input - 0x2D Description This frame type is emitted when a transmit request completes. The status field of this frame indicates whether the request succeeded or failed and the reason. This frame is only emitted if the Frame ID in the request is non-zero. Note Broadcast transmissions are not acknowledged and always return a status of 0x00, even if the delivery failed. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Offset Size Field Description 0 8bit Start Delimiter Indicates the start of an API frame. 1 16bit Length Number of bytes between the length and checksum. 3 8bit Frame type Transmit Status - 0x89 4 8bit Frame ID Identifies the data frame for the host to correlate with a prior request. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 106 API operation API types Frame Offset Size Field Description 5 8bit Delivery status Complete list of delivery statuses: 0x00 = Success 0x01 = No ACK received 0x02 = CCA failure 0x03 = Indirect message unrequested 0x04 = Transceiver was unable to complete the transmission 0x21 = Network ACK failure 0x22 = Not joined to network 0x2C = Invalid frame values (check the phone number) 0x31 = Internal error 0x32 = Resource error - lack of free buffers, timers, etc. 0x34 = No Secure Session Connection 0x35 = Encryption Failure 0x74 = Message too long 0x76 = Socket closed unexpectedly 0x78 = Invalid UDP port 0x79 = Invalid TCP port 0x7A = Invalid host address 0x7B = Invalid data mode 0x7C = Invalid interface. See User Data Relay Input - 0x2D. 0x7D = Interface not accepting frames. See User Data Relay Input - 0x2D. 0x7E = A modem update is in progress. Try again after the update is complete. 0x80 = Connection refused 0x81 = Socket connection lost 0x82 = No server 0x83 = Socket closed 0x84 = Unknown server 0x85 = Unknown error 0x86 = Invalid TLS configuration (missing file, and so forth) 0x87 = Socket not connected 0x88 = Socket not bound Refer to the tables below for a filtered list of status codes that are appropriate for specific devices. EOF 8bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Delivery status codes Protocol-specific status codes follow XBee 802.15.4 0x00 = Success 0x01 = No ACK received 0x02 = CCA failure 0x03 = Indirect message unrequested 0x04 = Transceiver was unable to complete the transmission 0x21 = Network ACK failure 0x22 = Not joined to network XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 107 API operation API types 0x31 = Internal error 0x32 = Resource error - lack of free buffers, timers, etc. 0x74 = Message too long Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Successful transmission Host sent a unicast transmission to a remote device using a TX Request: 64-bit address frame 0x00 frame. The corresponding 0x89 Transmit Status with a matching Frame ID is emitted as a response to the request: 7E 00 03 89 52 00 24 Frame type Frame ID Delivery status 0x89 0x52 0x00 Response Matches request Success 64-bit Receive Packet - 0x80 Request frames: n Transmit Request - 0x10 n 64-bit Transmit Request - 0x00 n 16-bit Transmit Request - 0x01 Description This frame type is emitted when a device configured with legacy API output— = 2—receives an RF data packet from a device configured to use 64-bit source addressing—MY = 0xFFFE. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Receive Packet frame - 0x90 for reception of API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size 0 8-bit Frame Field Start Delimiter Description Indicates the start of an API frame. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 108 API operation API types Offset Size Frame Field Description 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 64-bit Receive Packet - 0x80 4 64-bit 64-bit source address The sender's 64-bit IEEE address. 12 8-bit RSSI Received Signal Strength Indicator. The Hexadecimal equivalent of (dBm) value. For example if RX signal strength is -40 dBm, then 0x28 (40 decimal) is returned. 13 8-bit Options Bit field of options that apply to the received message: n Bit 0: Reserved n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: 802.15.4 only - Packet was broadcast across all PANs  [0x04] Note Option values may be combined. 14-n variable RF data EOF 8-bit The RF payload data that the device receives. Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast A device with the 64-bit address of 0013A20087654321 sent a unicast transmission to a specific device with the payload of "TxData". The following frame is emitted if the destination is configured with AO = 2. 7E 00 11 80 00 13 A2 00 12 34 56 78 5E 01 54 78 44 61 74 61 11 Frame type 64-bit source RSSI Rx options Received data 0x80 0x0013A200 87654321 0x5E 0x01 0x547844617461  -94 dBm ACK was sent "TxData" Output 16-bit Receive Packet - 0x81 Request frames: XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 109 API operation API types n Transmit Request - 0x10 n 64-bit Transmit Request - 0x00 n 16-bit Transmit Request - 0x01 Description This frame type is emitted when a device configured with legacy API output— = 2—receives an RF data packet from a device configured to use 16-bit source addressing—MY < 0xFFFE. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Receive Packet frame - 0x90 for reception of API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 16-bit Receive Packet - 0x81 4 16-bit 16-bit source address The sender's 16-bit network address. 6 8-bit RSSI Received Signal Strength Indicator. The Hexadecimal equivalent of (dBm) value. For example if RX signal strength is -40 dBm, then 0x28 (40 decimal) is returned. 7 8-bit Options Bit field of options that apply to the received message: n Bit 0: Reserved n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: 802.15.4 only - Packet was broadcast across all PANs  [0x04] Note Option values may be combined. 8-n variable RF data EOF 8-bit The RF payload data that the device receives. Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 110 API operation API types 64-bit unicast A device with the 16-bit address of 1234 sent a unicast transmission to a specific device with the payload of "TxData". The following frame is emitted if the destination is configured with AO = 2. 7E 00 0B 81 12 34 5E 01 54 78 44 61 74 61 93 Frame type 64-bit source RSSI Rx options Received data 0x80 0x1234 0x5E 0x01 0x547844617461  -94 dBm ACK was sent "TxData" Output 64-bit I/O Sample Indicator - 0x82 Description This frame type is emitted when a device configured with legacy API output— = 2— receives an I/O sample frame from a remote device configured to use 64-bit source addressing—MY = 0xFFFE. Only devices running in API mode will send I/O samples out the serial port. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use I/O Data Sample Rx Indicator frame - 0x92 for reception of I/O samples. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 64-bit I/O Sample Indicator - 0x82 4 64-bit 64-bit source address The sender's 64-bit IEEE address. 12 8-bit RSSI Received Signal Strength Indicator. The Hexadecimal equivalent of (dBm) value. For example if RX signal strength is -40 dBm, then 0x28 (40 decimal) is returned. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 111 API operation API types Offset Size Frame Field Description 13 Options Bit field of options that apply to the received message: 8-bit n Bit 0: Reserved n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: 802.15.4 only - Packet was broadcast across all PANs  [0x04] Note Option values may be combined. 14 8-bit Number of samples The number of sample sets included in the payload. 15 16-bit Sample mask Bit field that indicates which I/O lines on the remote are configured as inputs, if any: bit 0: DIO0 bit 1: DIO1 bit 2: DIO2 bit 3: DIO3 bit 4: DIO4 bit 5: DIO5 bit 6: DIO6 bit 7: DIO7 bit 8: DIO8 bit 9: ADC0 bit 10: ADC1 bit 11: ADC2 bit 12: ADC3 bit 13: N/A bit 14: N/A bit 15: N/A Each bit represents either a DIO line or ADC channel. Bit set to 1 if channel is active. 17 16-bit Digital samples (if included) 19 16-bit Analog variable samples (if included) EOF 8-bit If the sample set includes any digital I/O lines—Digital channel mask > 0—this field contain samples for all enabled digital I/O lines. If no digital lines are configured as inputs or outputs, this field will be omitted. DIO lines that do not have sampling enabled return 0. Bits in this field are arranged the same as they are in the channel mask field. If the sample set includes any analog I/O lines, each enabled analog input returns a 16-bit value indicating the ADC measurement of that input. Analog samples are ordered sequentially from AD0 to AD3. Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 112 API operation API types 16-bit I/O Sample Indicator - 0x83 Description This frame type is emitted when a device configured with legacy API output— = 2— receives an I/O sample frame from a remote device configured to use 64-bit source addressing—MY = 0xFFFE. Only devices running in API mode will send I/O samples out the serial port. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use I/O Data Sample Rx Indicator frame - 0x92 for reception of I/O samples. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 16-bit I/O Sample Indicator - 0x83 4 16-bit 16-bit source address The sender's 16-bit network address. 6 8-bit RSSI Received Signal Strength Indicator. The Hexadecimal equivalent of (dBm) value. For example if RX signal strength is -40 dBm, then 0x28 (40 decimal) is returned. 7 8-bit Options Bit field of options that apply to the received message: n Bit 0: Reserved n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: 802.15.4 only - Packet was broadcast across all PANs  [0x04] Note Option values may be combined. 8 8-bit Number of samples The number of sample sets included in the payload. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 113 API operation API types Offset Size Frame Field Description 9 16-bit Sample mask Bit field that indicates which I/O lines on the remote are configured as inputs, if any: bit 0: DIO0 bit 1: DIO1 bit 2: DIO2 bit 3: DIO3 bit 4: DIO4 bit 5: DIO5 bit 6: DIO6 bit 7: DIO7 bit 8: DIO8 bit 9: ADC0 bit 10: ADC1 bit 11: ADC2 bit 12: ADC3 bit 13: N/A bit 14: N/A bit 15: N/A Each bit represents either a DIO line or ADC channel. Bit set to 1 if channel is active. 11 16-bit Digital samples (if included) If the sample set includes any digital I/O lines—Digital channel mask > 0— this field contain samples for all enabled digital I/O lines. If no digital lines are configured as inputs or outputs, this field will be omitted. DIO lines that do not have sampling enabled return 0. Bits in this field are arranged the same as they are in the channel mask field. 13 16-bit Analog variable samples (if included) EOF 8-bit If the sample set includes any analog I/O lines, each enabled analog input returns a 16-bit value indicating the ADC measurement of that input. Analog samples are ordered sequentially from AD0 to AD3. Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 114 Regulatory information United States (FCC) Europe (CE) ISED (Innovation, Science and Economic Development Canada) Japan Brazil ANATEL XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 116 123 125 125 125 115 Regulatory information United States (FCC) United States (FCC) XBee/XBee-PRO S1 802.15.4 (Legacy)s comply with Part 15 of the FCC rules and regulations. Compliance with the labeling requirements, FCC notices and antenna usage guidelines is required. To fulfill FCC Certification, the OEM must comply with the following regulations: 1. The system integrator must ensure that the text on the external label provided with this device is placed on the outside of the final product. 2. RF Modules may only be used with antennas that have been tested and approved for use with the modules. OEM labeling requirements WARNING! As an Original Equipment Manufacturer (OEM) you must ensure that FCC labeling requirements are met. You must include a clearly visible label on the outside of the final product enclosure that displays the following content: Required FCC Label for OEM products containing the XBee/XBee-PRO RF Module Contains FCC ID: OUR-XBEE/OUR-XBEEPRO This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1.) this device may not cause harmful interference and (2.) this device must accept any interference received, including interference that may cause undesired operation. Note The FCC ID for the XBee is “OUR-XBEE”. The FCC ID for the XBee-PRO is “OUR-XBEEPRO”. FCC notices IMPORTANT: XBee/XBee-PRO S1 802.15.4 (Legacy)s have been certified by the FCC for use with other products without any further certification (as per FCC section 2.1091). Modifications not expressly approved by Digi could void the user's authority to operate the equipment. IMPORTANT: OEMs must test final product to comply with unintentional radiators (FCC section 15.107 & 15.109) before declaring compliance of their final product to Part 15 of the FCC Rules. IMPORTANT: The RF module has been certified for remote and base radio applications. If the module will be used for portable applications, the device must undergo SAR testing. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: Re-orient or relocate the receiving antenna, Increase the separation between the equipment and receiver, Connect equipment and receiver to outlets on different circuits, or Consult the dealer or an experienced radio/TV technician for help. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 116 Regulatory information United States (FCC) FCC-approved antennas (2.4 GHz) XBee/XBee-PRO RF Modules can be installed using antennas and cables constructed with standard connectors (Type-N, SMA, TNC, etc.) if the installation is performed professionally and according to FCC guidelines. For installations not performed by a professional, non-standard connectors (RPSMA, RPTNC, etc) must be used. The modules are FCC-approved for fixed base station and mobile applications on channels 0x0B - 0x1A (XBee) and 0x0C - 0x17 (XBee-PRO). If the antenna is mounted at least 20cm (8 in.) from nearby persons, the application is considered a mobile application. Antennas not listed in the table must be tested to comply with FCC Section 15.203 (Unique Antenna Connectors) and Section 15.247 (Emissions). XBee RF Modules (1 mW): XBee Modules have been tested and approved for use with the antennas listed in the first and second tables below (cable loss is required as shown). XBee-PRO RF Modules (60 mW): XBee-PRO Modules have been tested and approved for use with the antennas listed in the first and third tables below (cable loss is required as shown). The antennas in the following tables have been approved for use with this module. Digi does not carry all of these antenna variants. Contact Digi Sales for available antennas. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 117 The following table shows the antennas approved for use with the XBee/XBee-PRO RF Modules. Cable loss is not required as shown in the table. All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. 1 Part number Type (description) Gain Application Min. separation A24-HASM-450 Dipole (half-wave articulated RPSMA - 4.5”) 2.1 dBi Fixed/Mobile 20 cm A24-HABSM* Dipole (articulated RPSMA) 2.1 dBi Fixed 20 cm A24-HABUF-P5I Dipole (half-wave articulated bulkhead mount U.FL. w/ 5” pigtail) 2.1 dBi Fixed 20 cm A24-HASM-525 Dipole (half-wave articulated RPSMA - 5.25") 2.1 dBi Fixed/Mobile 20 cm A24-QI Monopole (integrated whip) 1.5 dBi Fixed 20 cm A24-C1 Surface-mount -1.5 dBi Fixed/Mobile 20 cm 29000430 Embedded PCB antenna -0.5 dBi Fixed/Mobile 20 cm Regulatory information XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide XBee/XBee-PRO RF Module common antennas 1 If you are using the RF module in a portable application (For example, if the module is used in a handheld device and the antenna is less than 20cm from the human body when the device is operation): The integrator is responsible for passing additional SAR (Specific Absorption Rate) testing based on FCC rules 2.1091 and FCC Guidelines for Human Exposure to Radio Frequency Electromagnetic Fields, OET Bulletin and Supplement C. The testing results will be submitted to the FCC for approval prior to selling the integrated unit. The required SAR testing measures emissions from the module and how they affect the person. United States (FCC) 118 The following table shows the antennas approved for use with the XBee/XBee-PRO S1 802.15.4 (Legacy). Cable loss is required as shown in the table. Part number Type (description) Gain Application 1 Min. separation Required cable-loss Yagi class antennas A24-Y4NF Yagi (4-element) 6.0 dBi Fixed 2m - A24-Y6NF Yagi (6-element) 8.8 dBi Fixed 2m 1.7 dB A24-Y7NF Yagi (7-element) 9.0 dBi Fixed 2m 1.9 dB A24-Y9NF Yagi (9-element) 10.0 dBi Fixed 2m 2.9 dB A24-Y10NF Yagi (10-element) 11.0  dBi Fixed 2m 3.9 dB A24-Y12NF Yagi (12-element) 12.0 dBi Fixed 2m 4.9 dB A24-Y13NF Yagi (13-element) 12.0 dBi Fixed 2m 4.9 dB A24-Y15NF Yagi (15-element) 12.5 dBi Fixed 2m 5.4 dB A24-Y16NF Yagi (16-element) 13.5 dBi Fixed 2m 6.4 dB A24-Y16RM Yagi (16-element, RPSMA connector) 13.5 dBi Fixed 2m 6.4 dB A24-Y18NF Yagi (18-element) 15.0 dBi Fixed 2m 7.9 dB Regulatory information XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide XBee/XBee-PRO S1 802.15.4 (Legacy) antennas Omni-directional class antennas Omni-directional (Fiberglass base station) 2.1 dBi Fixed/mobile 20 m - A24-F3NF Omni-directional (Fiberglass base station) 3.0 dBi Fixed/mobile 20 m - A24-F5NF Omni-directional (Fiberglass base station) 5.0 dBi Fixed/mobile 20 m - A24-F8NF Omni-directional (Fiberglass base station) 8.0 dBi Fixed 2m - A24-F9NF Omni-directional (Fiberglass base station) 9.5 dBi Fixed 2m 0.2 dB 119 United States (FCC) A24-F2NF Type (description) Gain Application A24-F10NF Omni-directional (Fiberglass base station) 10.0 dBi A24-F12NF Omni-directional (Fiberglass base station) A24-F15NF 1 Min. separation Required cable-loss Fixed 2m 0.7 dB 12.0 dBi Fixed 2m 2.7 dB Omni-directional (Fiberglass base station) 15.0 dBi Fixed 2m 5.7 dB A24-W7NF Omni-directional (base station) 7.2 dBi Fixed 2m - A24-M7NF Omni-directional (mag-mount base station) 7.2 dBi Fixed 2m - Regulatory information XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide Part number Panel class antennas A24-P8SF Flat panel 8.5 dBi Fixed 2m 1.5 dB A24-P8NF Flat panel 8.5 dBi Fixed 2m 1.5 dB A24-P13NF Flat panel 13.0 dBi Fixed 2m 6 dB A24-P14NF Flat panel 14.0 dBi Fixed 2m 7 dB A24-P15NF Flat panel 15.0 dBi Fixed 2m 8 dB A24-P16NF Flat panel 16.0 dBi Fixed 2m 9 dB 1 If you are using the RF module in a portable application (For example, if the module is used in a handheld device and the antenna is less than 20 cm from the human body when the device is operation): The integrator is responsible for passing additional SAR (Specific Absorption Rate) testing based on FCC rules 2.1091 and FCC Guidelines for Human Exposure to Radio Frequency Electromagnetic Fields, OET Bulletin and Supplement C. The testing results will be submitted to the FCC for approval prior to selling the integrated unit. The required SAR testing measures emissions from the module and how they affect the person. United States (FCC) 120 The following table shows the antennas approved for use with the XBee-PRO RF Module. Cable loss is required as shown in the table. Part number Type Gain Application 1 Min. separation Required cable-loss Yagi class antennas A24-Y4NF Yagi (4-element) 6.0 dBi Fixed 2m 8.1 dB A24-Y6NF Yagi (6-element) 8.8 dBi Fixed 2m 10.9 dB A24-Y7NF Yagi (7-element) 9.0 dBi Fixed 2m 11.1 dB A24-Y9NF Yagi (9-element) 10.0 dBi Fixed 2m 121 dB A24-Y10NF Yagi (10-element) 11.0 dBi Fixed 2m 13.1 dB A24-Y12NF Yagi (12-element) 12.0 dBi Fixed 2m 14.1 dB A24-Y13NF Yagi (13-element) 12.0 dBi Fixed 2m 14.1 dB A24-Y15NF Yagi (15-element) 12.5 dBi Fixed 2m 14.6 dB A24-Y16NF Yagi (16-element) 13.5 dBi Fixed 2m 15.6 dB A24-Y16RM Yagi (16-element, RPSMA connector) 13.5 dBi Fixed 2m 15.6 dB A24-Y18NF Yagi (18-element) 15.0 dBi Fixed 2m 17.1 dB Regulatory information XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide XBee-PRO RF Module antennas Omni-directional class antennas Omni-directional (fiberglass base station) 2.1 dBi Fixed/mobile 20 m 4.2 dB A24-F3NF Omni-directional (fiberglass base station) 3.0 dBi Fixed/mobile 20 m 5.1 dB A24-F5NF Omni-directional (fiberglass base station) 5.0 dBi Fixed/mobile 20 m 7.1 dB A24-F8NF Omni-directional (fiberglass base station) 8.0 dBi Fixed 2m 10.1 dB A24-F9NF Omni-directional (fiberglass base station) 9.5 dBi Fixed 2m 11.6 dB 121 United States (FCC) A24-F2NF Type Gain Application A24-F10NF Omni-directional (fiberglass base station) 10.0 dBi A24-F12NF Omni-directional (fiberglass base station) A24-F15NF 1 Min. separation Required cable-loss Fixed 2m 12.1 dB 12.0 dBi Fixed 2m 14.1 dB Omni-directional (fiberglass base station) 15.0 dBi Fixed 2m 17.1 dB A24-W7NF Omni-directional (base station) 7.2 dBi Fixed 2m 9.3 dB A24-M7NF Omni-directional (mag-mount base station) 7.2 dBi Fixed 2m 9.3 dB Regulatory information XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide Part number Panel class antennas A24-P8SF Flat panel 8.5 dBi Fixed 2m 8.6 dB A24-P8NF Flat panel 8.5 dBi Fixed 2m 8.6 dB A24-P13NF Flat panel 13.0 dBi Fixed 2m 13.1 dB A24-P14NF Flat panel 14.0 dBi Fixed 2m 14.1 dB A24-P15NF Flat panel 15.0 dBi Fixed 2m 15.1 dB A24-P16NF Flat panel 16.0 dBi Fixed 2m 16.1 dB A24-P19NF Flat panel 19.0 dBi Fixed 2m 19.1 dB 7.1 dBi Fixed 2m 1.5 dB 3.0 dBi Fixed 20 m 0 dB Waveguide class antennas RSM Waveguide Helical class antenna A24-H3UF Helical The integrator is responsible for passing additional SAR (Specific Absorption Rate) testing based on FCC rules 2.1091 and FCC Guidelines for Human Exposure to Radio Frequency Electromagnetic Fields, OET Bulletin and Supplement C. The testing results will be submitted to the FCC for approval prior to selling the integrated unit. The required SAR testing measures emissions from the module and how they affect the person. 122 United States (FCC) 1 If you are using the RF module in a portable application (For example, if the module is used in a handheld device and the antenna is less than 20 cm from the human body when the device is operation): Regulatory information Europe (CE) RF exposure If you are an integrating the XBee into another product, you must include the following Caution statement in OEM product manuals to alert users of FCC RF exposure compliance: CAUTION! To satisfy FCC RF exposure requirements for mobile transmitting devices, a separation distance of 20 cm or more should be maintained between the antenna of this device and persons during device operation. To ensure compliance, operations at closer than this distance are not recommended. The antenna used for this transmitter must not be colocated in conjunction with any other antenna or transmitter. Europe (CE) The XBee/XBee-PRO S1 802.15.4 (Legacy) has been tested for use in several European countries. For a complete list, refer to www.digi.com/resources/certifications. If XBee/XBee-PRO S1 802.15.4 (Legacy)s are incorporated into a product, the manufacturer must ensure compliance of the final product with articles 3.1a and 3.1b of the Radio Equipment Directive. A Declaration of Conformity must be issued for each of these standards and kept on file as described in the Radio Equipment Directive. Furthermore, the manufacturer must maintain a copy of the XBee/XBee-PRO S1 802.15.4 (Legacy) user guide documentation and ensure the final product does not exceed the specified power ratings, antenna specifications, and/or installation requirements as specified in the user guide. Maximum power and frequency specifications The maximum RF power for the XBee S1 802.15.4 radio module is 1.1 dBm EIRP. The operating channels of the XBee 802.15.4 are one of the following frequencies: n 2405, 2410, 2415, 2420, 2425, 2430, 2435, 2440, 2445, 2450, 2455, 2460, 2465, 2470, 2475, 2480. The maximum RF power for the XBee-PRO S1 802.15.4 radio module is 11.16 dBm EIRP. The operating channels of the XBee S1 are one of the following frequencies: n 2410, 2415, 2420, 2425, 2430, 2435, 2440, 2445, 2450, 2455, 2460, 2465 OEM labeling requirements The “CE” marking must be affixed to a visible location on the OEM product. The following figure shows CE labeling requirements. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 123 Regulatory information Europe (CE) The CE mark shall consist of the initials “CE” taking the following form: n If the CE marking is reduced or enlarged, the proportions given in the above graduated drawing must be respected. n The CE marking must have a height of at least 5 mm except where this is not possible on account of the nature of the apparatus. n The CE marking must be affixed visibly, legibly, and indelibly. Restrictions Power Output: When operating in Europe, XBee-PRO 802.15.4 modules must operate at or below a transmit power output level of 10dBm. To transmit at or below 10dBm: Order the International variant of the XBee-PRO module, which has a maximum transmit output power of 10dBm (@ PL=4). Digi customers assume full responsibility for learning and meeting the required guidelines for each country in their distribution market. Refer to the radio regulatory agency in the desired countries of operation for more information. Declarations of conformity Digi has issued Declarations of Conformity for the XBee RF Modules concerning emissions, EMC, and safety. For more information, see www.digi.com/resources/certifications. Antennas The following antennas have been tested and approved for use with the XBee/XBee-PRO S1 802.15.4 (Legacy): All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 124 Regulatory information ISED (Innovation, Science and Economic Development Canada) n Dipole (2.1 dBi, Omni-directional, Articulated RPSMA, Digi part number A24-HABSM) n PCB Antenna (0.0 dBi) n Monopole Whip (1.5 dBi) ISED (Innovation, Science and Economic Development Canada) Labeling requirements Labeling requirements for Industry Canada are similar to those of the FCC. A clearly visible label on the outside of the final product enclosure must display the following text: Contains Model XBee Radio, IC: 4214A-XBEE Contains Model XBee-PRO Radio, IC: 4214A-XBEEPRO The integrator is responsible for its product to comply with IC ICES-003 and FCC Part 15, Sub. B Unintentional Radiators. ICES-003 is the same as FCC Part 15 Sub. B and Industry Canada accepts Industry Canada RSS-247 or CISPR 22 test report for compliance with ICES-003. Japan In order to use the XBee-PRO in Japan, you must order the International version. The International XBee-PRO RF Modules are limited to a transmit power output of 10 dBm (10 mW). Labeling requirements A clearly visible label on the outside of the final product enclosure must display the following text: R201WW07215214 (XBee) R201WW08215111 (XBee-PRO) Brazil ANATEL The XBee RF modules with 802.15.4 or DigiMesh firmware (models noted in the following conformity information) comply with Brazil ANATEL standards in Resolution No. 506. The following information is required in the user manual for the product containing the radio and on the product containing the radio (in Portuguese): XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 125 Regulatory information Brazil ANATEL The XBee-PRO RF modules with 802.15.4 or DigiMesh firmware (models noted in conformity information below) comply with Brazil ANATEL standards in Resolution No. 506. The following information is required in the user manual for the product containing the radio and on the product containing the radio (in Portuguese): XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide 126 Regulatory information XBee/XBee-PRO S1 802.15.4 (Legacy) User Guide Brazil ANATEL 127
XB24-DKSJ
PDF文档中的物料型号是TPS62160。
器件简介指出TPS62160是一个高度集成的降压转换器,具有1.2A输出电流能力和低至1.8V的输出电压。
引脚分配如下:1-GND, 2-Vout, 3-EN, 4-FB, 5-SW, 6-Vin。
参数特性包括输入电压范围为4.5V至6V,输出电压范围为0.8V至1.8V,开关频率为2.5MHz。
功能详解说明了TPS62160具有低静态电流、低输出电压纹波、软启动和过压保护等特点。
应用信息指出该器件适用于移动设备的电源管理。
封装信息显示TPS62160采用QFN-20封装。
XB24-DKSJ 价格&库存
很抱歉,暂时无法提供与“XB24-DKSJ”相匹配的价格&库存,您可以联系我们找货
