XK-Z11-T-W
XK-Z11-T-W
    DIGIINTERNATIONAL
    KIT DIGI TANK SOL REST OF WORLD
XK-Z11-T-W 数据手册
Thank you for purchasing a Digi Tank Solutions Kit! Over the next hour you will be introduced to several important pieces of Digi technology: ZigBee communication hardware (gateway, module, and adapter), iDigi® (an M2M network operating platform), iDigi Dia® (device connection software), and application examples in both Windows and Google App Engine™ to help you jump-start your own development efforts. These pieces are presented in Digi’s free development environment, Digi ESP™ for Python. Quick Start Guide Digi Tank Solutions Kit After going through the kit you will have: - Configured the physical elements of a ZigBee wireless network - Remotely managed the network through iDigi - Run an iDigi Dia Tank Simulator Project - Seen how an application uses the data presented by iDigi to monitor and control a tank environment 90001202_C For more information about Digi Tank Solutions or for support with your kit, please visit www.digi.com/tanksolutionskit. 1 Verify Kit Contents XBee Module Power Supply with AC Power Cord Gateway Antenna ConnectPort® X4 Gateway XBIB-U-DEV USB Interface Board * Power Cord not supplied with international kits 2 Connect Hardware d a Connect the ConnectPort® X4 to a LAN with Internet access using the Ethernet cable. b Connect power supply. c Connect the Gateway Antenna to the ConnectPort® X4. d Install the XBee module onto the XBIB- U-DEV USB Interface Board. e Connect the USB cable to the XBIB unit and corresponding port on your PC. f Ethernet Cable USB Cable XStick e c a Connect the XStick to a USB port on your PC. b f NOTE: If the XStick or XBIB devices are not recognized automatically, you can download the corresponding drivers from the Documentation tab at www.digi.com/tanksolutionskit. 3 Install Digi ESP for Python Software 4 Run Digi ESP for Python TM a b ™ Download the Digi ESP for Python software from the Digi Tank Solutions Kit page at www.digi.com/tanksolutionskit. Double-click the downloaded file to execute the guided installer. Leave the default selections and also select Digi Tank Solutions Kit Support. Follow the guided steps to successfully install the ™ Digi ESP for Python. TM a Select a working directory for the application (you can leave it with the default value if preferred). b Click the “Getting Started” icon on the ESP Overview screen, and then click on the “Digi Tank Solutions Kit” icon. c Follow the Getting Started Guide steps to execute the Digi Tank Solutions Kit demo. © Digi International, Inc., 2011 Digi, Digi International, the Digi logo, iDig, and the iDigi logo are trademarks or registered trademarks of Digi International, Inc., in the United States and other countries worldwide. All other trademarks are property of their respective owners.
XK-Z11-T-W
PDF文档是关于Digi Tank Solutions Kit的快速入门指南。
它介绍了Digi公司的ZigBee通信硬件、iDigi® M2M网络操作系统平台、iDigi Dia®设备连接软件,以及Digi ESP for Python开发环境中的应用示例。
文档提供了如何配置ZigBee无线网络的物理元素、通过iDigi远程管理网络、运行iDigi Dia Tank Simulator Project,以及如何使用iDigi展示的数据来监控和控制水箱环境的指导。
文档中列出了套件的内容,包括Ethernet USB Cable、XStick、Cable、ConnectPort X4 Gateway、XBee Module、Gateway Antenna、Power Supply with AC Power Cord、XBIB-U-DEV USB Interface Board等。
还提供了硬件连接和软件安装的步骤,包括连接硬件、安装Digi ESP for Python软件,并按照入门指南执行Digi Tank Solutions Kit演示。
请注意,文档中并没有直接列出“物料型号”、“器件简介”、“引脚分配”、“参数特性”、“功能详解”、“应用信息”和“封装信息”等具体技术细节。
如果需要这些详细信息,可能需要查阅更专业的技术文档或数据手册。
XK-Z11-T-W 价格&库存
很抱歉,暂时无法提供与“XK-Z11-T-W”相匹配的价格&库存,您可以联系我们找货
