3079
3079
    ADAFRUIT
    ADAFRUITFEATHER32U4RFM96WLOR
3079 数据手册
Adafruit Feather 32u4 RFM96W LoRa Radio - 433MHz PRODUCT ID: 3079 DESCRIPTION - Coming soon! Sign up to get notified when we will have these in stock. Feather is the new development board from Adafruit, and like its namesake it is thin, light, and lets you fly! We designed Feather to be a new standard for portable microcontroller cores. This is the Adafruit Feather 32u4 LoRa Radio (RFM95W) 433MHz - our take on an microcontroller packet radio transceiver with built in USB and battery charging. Its an Adafruit Feather 32u4 with a 433 MHz radio module cooked in! Great for making wireless networks that can go much further than 2.4GHz 802.15.4 and similar, are more flexible than Bluetooth LE and without the high power requirements of WiFi. We have other boards in the Feather family, check'em out here. This is the 433 MHz radio version. We also sell a 900MHz version of the same radio chipset which can be used for 868 or 915 MHz! And if you don't need LoRa radio, we have plain 433MHz packet radios as well At the Feather 32u4's heart is at ATmega32u4 clocked at 8 MHz and at 3.3V logic, a chip setup we've had tons of experience with as it's the same as the Flora. This chip has 32K of flash and 2K of RAM, with built in USB so not only does it have a USB-to-Serial program & debug capability built in with no need for an FTDI-like chip, it can also act like a mouse, keyboard, USB MIDI device, etc. To make it easy to use for portable projects, we added a connector for any of our 3.7V Lithium polymer batteries and built in battery charging. You don't need a battery, it will run just fine straight from the micro USB connector. But, if you do have a battery, you can take it on the go, then plug in the USB to recharge. The Feather will automatically switch over to USB power when its available. We also tied the battery thru a divider to an analog pin, so you can measure and monitor the battery voltage to detect when you need a recharge. Here's some handy specs! Like all Feather 32u4's you get: • Measures 2.0" x 0.9" x 0.28" (51mm x 23mm x 8mm) without headers soldered in • Light as a (large?) feather - 5.5 grams • ATmega32u4 @ 8MHz with 3.3V logic/power • 3.3V regulator with 500mA peak current output • USB native support, comes with USB bootloader and serial port debugging • You also get tons of pins - 20 GPIO pins • Hardware Serial, hardware I2C, hardware SPI support • 8 x PWM pins • 10 x analog inputs • Built in 100mA lipoly charger with charging status indicator LED • Pin #13 red LED for general purpose blinking • Power/enable pin • 4 mounting holes • Reset button This Feather 32u4 LoRa Radio uses the extra space left over to add a RFM95W 433 MHz radio module: • SX1276 based module with SPI interface • Packet radio with ready-to-go library • Uses the license-free ISM bands • +13 to +20 dBm up to 100 mW Power Output Capability (selectable in software) • Simple wire antenna or spot for uFL connector Comes fully assembled and tested, with a USB bootloader that lets you quickly use it with the Arduino IDE. We also toss in some headers so you can solder it in and plug into a solderless breadboard. You will need to cut and solder on a small piece of wire (any solid or stranded core is fine) in order to create your antenna. Lipoly battery card and USB cable not included but we do have lots of options in the shop if you'd like! https://www.adafruit.com/product/3079 4/11/2016 Technical Details FCC Test Report 51mm x 23mm x 8mm / 2.0" x 0.9" x 0.28" Weight: 5.5g
3079
1. 物料型号: Adafruit Feather 32u4 RFM96W LoRa Radio - 433MHz,产品ID: 3079。 2. 器件简介: Feather是一种便携式微控制器核心,设计得轻薄且易于使用。这款产品内置了433MHz无线电模块,适用于无线网络,比2.4GHz 802.15.4等技术传输更远,比蓝牙更灵活,且没有WiFi的高功率需求。 3. 引脚分配: 该Feather 32u4具有20个GPIO引脚,支持硬件串行通信、I2C和SPI。 4. 参数特性: ATmega32u4 @ 8MHz,3.3V逻辑/电源,3.3V调节器,最大输出500mA峰值电流,USB原生支持,包括USB引导加载程序和串行端口调试。 5. 功能详解: 包括硬件串行通信、硬件I2C、硬件SPI支持,8个PWM引脚,10个模拟输入,内置100mA锂聚合物充电器,充电状态指示灯,一般用途的闪烁红灯,电源/使能引脚,4个安装孔,复位按钮。 6. 应用信息: 适用于需要远程无线通信的项目,如物联网设备。 7. 封装信息: 尺寸为51mm x 23mm x 8mm,重量为5.5克,采用SX1276基模块,SPI接口,使用免许可的ISM频段,可输出功率从13dBm到20dBm,可软件选择,支持简单线天线或uFL连接器。
很抱歉,暂时无法提供与“3079”相匹配的价格&库存,您可以联系我们找货
  • 1+333.139181+43.15318
    • 1+651.52080
    • 200+259.96680
    库存:13
