WRL-12579
WRL-12579
    SPARKFUNELECTRONICS
    SPARKFUNBLUETOOTHMODULEBREAKO
WRL-12579 数据手册
Page 1 of 2   Export Restrictions This product has some level of export control/restriction, so may be delayed by 2-3 business days when shipping outside the United States. Contact us with questions, or we will contact you after you place your order. SparkFun Bluetooth Module Breakout Roving Networks (RN-41 v6.15) W R L- 125 79 R OH S   images are CC BY-NC-SA 3.0 3D Download: Sketchup, STL, Blender Description: This is a simple breakout for the Roving Networks Bluetooth module. All pertinent pins are broken out and labeled. This new version’s headers are unpopulated. Check below for appropriate headers. The module from Roving Networks is powerful, small, and very easy to use. This Bluetooth module is designed to replace serial cables. The Bluetooth stack is completely encapsulated. The end user just sees serial characters being transmitted back and forth. Press the ‘A’ character from a terminal program on your computer and an ‘A’ will be pushed out the TX pin of the Bluetooth module. Do not attach this device directly to a serial port. You will need an RS232 to TTL converter circuit if you need to attach this device to a computer. Features: • Fully qualified Bluetooth module • FCC Certified • Fully configurable UART Page 2 of 2 • • • • • • • • • UART Data rates up to 3Mbps Over air data rate of 721kbps to 2.0Mbps Low power sleep mode Compatible with all Bluetooth products that support SPP (almost all do) Includes support for BCSP, DUN, LAN, GAP SDP, RFCOMM, and L2CAP protocols 3.3V operation Status pin Bluetooth Technology v2.0 compatible Class 1 power output Dimensions: 1.0x0.9" https://www.sparkfun.com/products/12579 11/17/2015
WRL-12579 价格&库存
很抱歉,暂时无法提供与“WRL-12579”相匹配的价格&库存,您可以联系我们找货
