MYRIADRF-1
MYRIADRF-1
    LIMEMICROSYSTEMS
    EVAL BOARD FOR LMS6002D
MYRIADRF-1 数据手册
LMS6002D Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs SUMMARY FEATURES TXINI TXINQ   2 DEMUX TXD[11:0] 12 TX_IQ_SEL    Femtocell and Picocell base stations Repeaters Broadband wireless communication devices for WCDMA/HSPA, LTE, GSM, CDMA2000, IEEE® 802.16x radios 2 IQ DACs 12 APPLICATIONS TX Power Control TXLPF TXVGA1 DAC TX Gain Control TXVGA2 TXMIX PA1 LO Leakage QDAC 12 TX_CLK DAC 0o 90o TXPLL /2 LMS6002D RX_CLK_OUT /2 RX_CLK RXPLL 0o 90o 12 RXD[11:0] IADC MUX RX_IQ_SEL 12 2 TXOUT1 IDAC 12 QADC IQ ADCs RXVGA2 RXLPF RXVGA1 RXMIX PA2 LNA1 2 LNA2 2 2 RX Power Control RX Gain Control RXIN1 RXIN2 2 RXIN3 SPI SEN SCLK SDIO SDO RXOUTI RXOUTQ 2 TXOUT2 LNA3 RXLNA RXOUTSW 2 AUXPA RF loopback    120 pin DQFN package Power down option Serial port interface PLLCLK     Single chip transceiver covering 0.3-3.8GHz frequency range Digital interface to baseband with integrated 12 bit D/A and A/D converters Fully differential baseband signals Few external components Programmable modulation bandwidth: 1.5, 1.75, 2.5, 2.75, 3, 3.84, 5, 5.5, 6, 7, 8.75, 10, 12, 14, 20 and 28MHz Supports both TDD and FDD operation modes Low voltage operation, 1.8V and 3.3V PLLCLKOUT  Figure 1: Functional block diagram GENERAL DESCRIPTION LNA, PA driver, RX/TX mixers, RX/TX filters, synthesizers, RX gain control, and TX power control with very few external components. The LMS6002D is a fully integrated, multi-band, multi-standard RF transceiver for 3GPP (WCDMA/HSPA, LTE), 3GPP2 (CDMA2000) and 4G LTE applications, as well as for GSM pico BTS. It combines the Document version: 1.1.0 Last modified: 03/12/2012 © Copyright Lime Microsystems The information contained in this document is subject to change without prior notice. Lime Microsystems assumes no responsibility for its use, nor for infringement of patents or other rights of third parties. Lime Microsystems' standard terms and conditions apply at all times. LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs The top level architecture of LMS6002D transceiver is shown in Figure 1. Both transmitter and receiver are implemented as zero IF architectures providing up to 28MHz modulation bandwidth (equivalent to 14MHz baseband IQ bandwidth). mixed with the receive PLL (RXPLL) output to directly down convert to baseband. Large AGC steps can be implemented by an IF amplifier (RXVGA1) prior to the programmable bandwidth lowpass channel select filters (RXLPF). The received IQ signal is further amplified by a programmable gain amplifier RXVGA2. DC offset is applied at the input of RXVGA2 to prevent saturation and to preserve receive the ADC(s) dynamic range. The resulting analog receive IQ signals are converted into the digital domain using the on chip receive ADCs and provided as an output to the baseband processor on a multiplexed 12 bit CMOS output level parallel bus. The receive clock, RX_CLK, is provided off chip at the RX_CLK_OUT pin and can be used to synchronise with the baseband digital receive data sampling clock. On the transmit side, IQ DAC samples from the baseband processor are provided to the LMS6002D on a 12 bit multiplexed parallel CMOS input level bus. Analog IQ signals are generated by on chip transmit DACs. These are fed to the TXINI and TXINQ inputs. Transmit low pass filters (TXLPF) remove the images generated by zero hold effect of the DACs. The IQ signals are then amplified (TXVGA1) and DC offset is inserted in the IQ path by LO leakage DACs in order to cancel the LO leakage. The IQ signals are then mixed with the transmit PLL (TXPLL) output to produce a modulated RF signal. This RF signal is then split and amplified by two separate variable gain amplifiers (TXVGA2) and two off chip outputs are provided as RF output. By closing the RXOUT switch and powering down RXVGA2, the RXOUTI and RXOUTQ pins can be used as IQ ADCs inputs. In this configuration the ADCs can be used to measure two external signals, such as an off chip PA temperature sensor or peak detector. Transmitter gain control range of 56dB is provided by IF (TXVGA1, 31dB range) and RF (TXVGA2, 25 dB range) variable gain amplifiers. Both TXVGAs have 1dB gain step control. Two transmitter outputs (TXOUT1, TXOUT2) and three receiver inputs (RXIN1, RXIN2, RXIN3) are provided to facilitate multi-band operation. The LMS6002D provides an RF loop back option (see Figure 1) which enables the TX RF signal to be fed back into the baseband for calibration and test purposes. The RF loop back signal is amplified by an auxiliary PA (AUXPA) in order to increase the dynamic range of the loop. On the receive side, three separate inputs are provided each with a dedicated LNA. Each port preconditioned RF signal is first amplified by a programmable low noise amplifier (RXLNA). The RF signal is then Parameter The functionality of the LMS6002D is fully controlled by a set of internal registers which can be accessed through a serial port. In order to enable full duplex operation, the LMS6002D contains two separate synthesizers (TXPLL, RXPLL) both driven from the same reference clock source PLLCLK. The PLLCLK signal is provided at the PLLCLKOUT output pin and can be used as the baseband clock. Differential signalling is done in the receive and transmit analog paths throughout the chip. Condition/Comment TRX RF Frequency Range Min Typ 0.3 Baseband Bandwidth 0.75 Frequency Resolution 3.1 TRX 1.8V Supply 1.7 Unit 3.8 GHz 14 MHz 2.4 Hz 3.3 3.5 V 1.8 1.9 V Using 41MHz PLL reference clock TRX 3.3V Supply Max TX Supply Current At maximum gain 280 mA RX Supply Current At maximum gain 220 mA Digital Core Supply Voltage Digital Peripheral (IO) Supply Voltage Ambient Temperature Can go below 3.3V nominal to support LV CMOS signalling Storage Temperature Continuous wave Absolute Maximum RF Input Power No damage PLL Phase Noise 1.8 1.9 V 1.7 3.3 3.5 V -40 25 85 o 125 o -65 Maximum RF Output Power PLL Reference Clock 1.7 6 LMS6002D 2 © Copyright Lime Microsystems dBm 23 Table 1: General specifications C dBm 23 For continuous LO frequency range 1MHz offset C 41 -125 MHz dBc/Hz Parameter Condition/Comment Min TRX RF Bandwidth Typ Max 0.3 Unit 3.8 GHz Transmit Input Impedance Differential, programmable 100 Ohms Transmit Load Impedance Differential 65 Ohms Transmit Differential I and Q Input Voltages Differential Common mode 250 65 mVpp mV Transmit Gain Control Range TXVGA1, TXVGA2 56 dB 1 dB Transmit Gain Control Step TX LO Leakage LO leakage not calibrated -50 RX LNA1 Frequency Range Narrow band 0.3 2.8 dBc GHz RX LNA2 Frequency Range Narrow band 1.5 3.8 GHz RX LNA3 Frequency Range Broad band 0.3 3.0 GHz RX LNA1 Input Impedance Differential RX LNA2 Input Impedance RX LNA3 Input Impedance Receive Load Impedance 50 Ohms Differential 50 Ohms Differential 200 Ohms Differential 2k Ohms Noise Figure 5 3.5 5.5 10 pF LNA1 at 0.95GHz LNA2 at 1.95GHz LNA3 at 1.95GHz 3rd Order Input Referred Intercept Point LNA2 at Mid. Gain -1 dBm RXLNA, RXVGA1, RXVGA2 RXVGA1, not log-linear RXVGA2 61 Receive Load Capacitance Receive Gain Control Range Receive Gain Control Step dB dB 1 dB 3 Table 2: General RF specifications The LMS6002D transmitter has two programmable gain stages, TXVGA1 is located in the IF section and TXVGA2 is in the RF section, (see Figure 2). TXVGA1 is implemented on the I and Q branches but controlled by a single control word. TXVGA2 consists of 2 amplifiers one for each of the transmitter outputs, however only one of these output amplifiers can be active at any time. TXINQ TXINI TXVGA2 Note: The TXLPF has a gain of 6dB or 0dB when bypassed. 2 TXLPF TXVGA1 DAC 2 TXMIX PA1 LO Leakage 2 DAC 0o o 90 2 PA2 TXPLL Figure 2: TX gain control architecture Parameter TXLPF Gain Condition 0 dB gain when bypassed TXVGA1 Gain Control Range TXVGA1 Gain Step Size Guaranteed monotonic TXVGA2 Gain Control Range TXVGA2 Gain Step Size Guaranteed monotonic Table 3: TX gain control LMS6002D 3 © Copyright Lime Microsystems Min Typ 0 Max 6 Unit dB 31 dB 1 dB 25 dB 1 dB TXOUT2 TXOUT1 TX GAIN CONTROL RXOUTQ RXOUTI The LMS6002D receiver has three gain control elements, RXLNA, RXVGA1, and RXVGA2 (see Figure 3). RXLNA gain control consists of a single 6dB step for AGC when large in co-channel blockers are present and a reduction in system NF is acceptable. The main LNAs (LNA1 and LNA2) have fine gain control via a 6 bit word which offers ±6dB control intended for frequency correction when large input bandwidths are required. RXVGA1 offers 25dB of control range, a 7 bit control word is used and the response is not log-linear. Maximum step size is 1dB. RXVGA1 is intended for AGC steps needed to reduce system gain prior to the channel filters when large in band blockers are present. This gain can be under control of the baseband or fixed on calibration. RXPLL o 0 90o LNA1 2 LNA2 2 LNA3 2 2 2 RXVGA2 RXLPF RXVGA1 RXMIX RXLNA RXVGA2 provides the bulk of gain control for AGC if a constant RX signal level at the ADC input is required. It has 30dB gain range control in 3dB steps. RXIN3 RXIN2 RXIN1 RX GAIN CONTROL Figure 3: RX gain control architecture Note: RXLPF has a gain of 0dB when bypassed. Parameter RXLNA Gain Control Range Condition Min Single step Typ 6 RXVGA1 Gain Control Range 25 RXVGA1 Gain Step Size Not log-linear RXLPF Gain 0 dB gain when bypassed Unit dB dB 0 RXVGA2 Gain Control Range RXVGA2 Gain Step Size Max 0 1 dB 6 dB 30 dB 3 dB Guaranteed monotonic Table 4: RX gain control SYNTHESIZERS PFD 0o CHP VCO o 90 /N SD NINT, NFRAC Figure 4: PLL architecture LMS6002D 4 © Copyright Lime Microsystems Output Divider T(R)CPOUT PLLCLK The LMS6002D can accept clipped sine as well as the CMOS level signals as the PLL reference clock. Both DC and AC coupling are supported as shown in Figure 5. Internal buffer self biasing must be enabled for AC coupling mode. PLL reference clock input can also be low voltage CMOS (2.5V or 1.8V, for example) which is implemented by lowering clock buffer supply PVDDSPI33. T(R)XVTUNE External Loop Filter LMS6002D has two low phase noise synthesizers to enable full duplex operation. Both synthesizers are capable of output frequencies up to 3.8GHz. Each synthesizer uses a fractional-N PLL architecture as shown in Figure 4. The same reference frequency is used for both synthesisers and is flexible between 23 to 41MHz. The synthesizers produce a complex output with suitable level to drive IQ mixers in both the TX and the RX paths. LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs PVDDSPI33 PVDDSPI33 PLLCLK TXCO External TXCO External CLKBUF LMS6002D PLLCLK VSS LMS6002D (a) CLKBUF VSS (b) Figure 5: PLL reference clock input buffer, (a) DC coupled (b) AC coupled Parameter Frequency Range Reference Amplitude Reference Frequency Frequency Step Size Phase Noise 10 KHz offset 100 KHz offset 1 MHz offset Condition At PVDDSPI33=3.3V For continuous LO frequency range At 41MHz reference clock 800MHz 1.9GHz Phase Noise 10 KHz offset 100 KHz offset 1 MHz offset Reference Spurious Outputs Other Spurious Outputs 2.6GHz IQ Amplitude Error PLL settling time Typ 0.8 Max 3.8 3.3 41 2.4 Unit GHz Vpp MHz Hz -94 -113 -130 Phase Noise 10 KHz offset 100 KHz offset 1 MHz offset IQ Phase Error Min 0.3 0.2 23 -89 -95 -125 dBc/Hz -86 -90 -125 800MHz 1.9GHz 2.6GHz To 1ppm, 50kHz loop bandwidth 1 3 9 0.4 20 -50 dBc -50 dBc deg dB μs Table 5: Synthesizer specifications RF PORTS TX and RX LOW PASS FILTERS LMS6002D has two transmitter outputs and three receiver inputs. LMS6002D integrates highly selective low pass filters in both TX and RX paths. Filters have a programmable pass band in order to provide more flexibility on the DAC/ADC clock frequency and also to provide excellent adjacent channel rejection in the receive chain. The following LPF pass bands are supported: 14, 10, 7, 6, 5, 4.375, 3.5, 3, 2.75, 2.5, 1.92, 1.5, 1.375, 1.25, 0.875, and 0.75MHz. Filters are also tunable to compensate for process/temperature variation. The TX and RX filters are the same but controlled via SPI link independently. Measured amplitude responses are shown in Figure 6. The transmitter output ports are optimized for a 65Ω differential load, the final stage amplifiers are open drain and require +3.3V voltage supply, see LMS6002D typical application circuit in Figure 19. The receiver inputs are all different. RXIN1 is the low frequency input and can operate in the range 0.3 – 2.8GHz, RXIN2 is the high frequency input and can operate in the range 1.5 – 3.8GHz. Both RXIN1 and RXIN2 require matching circuits for optimum performance. A simple match is shown in Figure 19. RXIN3 is a broadband input covering the range 0.3 – 3.0GHz, it is 200Ω differential and is typically matched with a wideband transformer. Assuming 40MHz DAC/ADC clock, 28MHz modulation bandwidth (equivalent to 14MHz baseband IQ bandwidth) and 28MHz channel spacing, performance of the TRX filters is summarised as below. TX low pass filter:  First DAC image attenuation  Second DAC image attenuation LMS6002D 5 © Copyright Lime Microsystems >= 55dB >= 70dB LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs RX low pass filter  Alias attenuation  First adjacent channel attenuation  Second adjacent channel attenuation Recommended LMS6002D initialization sequence is as follows: >= 50dB >= 45 dB >= 70 dB 1. 2. 3. 10 4. 0 -10 Normalized Gain [dB] 5. 0.75MHz -20 0.875MHz 1.25MHz 6. 1.375MHz -30 1.5MHz 1.92MHz 2.5MHz -40 2.75MHz -50 -60 -70 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 7. 8. 9. 6.5 Frequency [MHz] Apply RESET pulse (active low). This sets all the configuration registers to their default values. Set target LO frequency and gain for both TX and RX chains. LPF tuning a. DC offset cancellation of the tuning module b. Execute LPF bandwidth tuning procedure TXLPF a. DC offset cancellation of I filter b. DC offset cancellation of Q filter RXLPF a. DC offset cancellation of I filter b. DC offset cancellation of Q filter RXVGA2 a. DC offset cancellation of the reference generator b. DC offset cancellation of the first gain stage, I branch c. DC offset cancellation of the first gain stage, Q branch d. DC offset cancellation of the second gain stage, I branch e. DC offset cancellation of the second gain stage, Q branch TX LO leakage cancellation TX IQ gain/phase error calibration RX IQ gain/phase error calibration Once the device is calibrated, register values can be stored and uploaded back into LMS6002D at the next power up/reset point which will shorten the initialization time. 10 0 Refer to “LMS6002D Programming and Calibration Guide” for more details. 3MHz -20 DIGITAL IQ DATA INTERFACE 3.5MHz 4.375MHz 5MHz 6MHz Description 7MHz 10MHz -50 -60 -70 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 Frequency [MHz] IQ DACs Figure 6: Measured TX/RX LPF amplitude responses TXD[11:0] 12 CALIBRATION AND INITIALIZATION TX_IQ_SEL There are a number of calibrations which the LMS6002D can carry out internally when instructed via the SPI. These calibrations can be initiated on power up/reset to produce optimum settings. The following auto calibration options are available: DC offset cancellation within the various blocks TRX LPF bandwidth tuning QDAC TX_CLK /2 RX_CLK /2 12 RX_IQ_SEL Additionally, LMS6002D provides the blocks such as LO leakage DACs and RF loop back to further facilitate the following calibrations:   IDAC 12 IADC MUX   12 RXD[11:0] 12 12 QADC IQ ADCs LO leakage in the transmit chain IQ gain and phase mismatch in both transmit and receive chains Figure 7: Baseband data interface Note that these calibrations require the loop to be closed externally via the baseband. 1 LMS6002D LimeLight™ 6 © Copyright Lime Microsystems LimeLight™ is trademark of Lime Microsystems Ltd TXINQ TXINI The functionality of LMS6002D transceiver implements a subset of the LimeLight™ LMS600X-01008031 digital IQ interface with a 12 bit multiplexed transmit path and a 12 bit multiplexed receive path as shown in Figure 7. TX and RX interfaces require a clock running at twice the data converters sample rate. Separate clocks can be provided for the TX and RX interface. Location of the IQ samples in the multiplexed stream is flagged by the IQ select signals which are required as an input to the transmit path and provided as an output from the receive path. 14MHz RXOUTI -40 RXOUTQ -30 DEMUX Normalized Gain [dB] -10 LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs tSETUP tHOLD For both TX and RX interfaces IQ_SEL (frame sync) polarity and interleave mode are independently programmable via the SPI link, see Figure 8. Here, the frame is defined as two consecutive T(R)X_CLK, i.e. one T(R)X_IQ_SEL, periods while IQ data from the same sampling point are present on the multiplexed bus. TX_CLK TX_IQ_SEL Frame Frame TXD[11:0] T(R)X_ IQ_SEL Positive IQ_SEL polarity T(R)X_IQ_SEL Negative IQ_SEL polarity T(R)XD[11:0] I0 Q0 Q1 I1 I_DATA[11:0] I0 I1 Q_DATA[11:0] Q0 Q1 IQ interleave mode Q0 Q1 I1 TX_CLK/2 I2 QI interleave mode T(R)XD[11:0] Q0 I0 I0 External Signals I1 Q1 Q2 Internal Signals Figure 10: TX IQ interface signals Some examples of the TX interface data rates are provided below: Figure 8: Frame sync polarity and interleave modes  Transmitter Data Interface More detailed functional diagram of the TX data interface is shown in Figure 9. Corresponding waveforms are given in Figure 10. The interface is a 12 bit parallel bus from the base band IC carrying multiplexed IQ data samples for the transmit DACs. The interface data rate is twice the DACs sample rate. TX_IQ_SEL flag is used to identify I and Q samples on the multiplexed bus. Note that the DACs sampling clock is not derived by dividing TX_CLK by two as indicated in Figure 7. Instead, registered version of TX_IQ_SEL is used. Hence, for the DACs to receive sampling clock TX_IQ_SEL must be provided and toggled as in Figure 8. DACs sampling edge is also programmable via SPI link. RX digital IQ interface related pins are described as follows:  RX_CLK RX interface data clock, positive edge sensitive (input)  RXD[11:0] 12 bit multiplexed IQ data bus (output)  RX_IQ_SEL Indicates the location of I and Q data on the multiplexed bus (output) adc_clk_pol Q CLK Divide by 2 TX_CLK/2 tx_interleave_mode Figure 9: TX data interface QN rx_interleave_mode rx_fsinc_polarity Figure 11: RX data interface 7 © Copyright Lime Microsystems Q CLK dac_clk_pol LMS6002D D DFF B D QN RX_IQ_SEL B Y DFF Y SEL MUX A RX_CLK/2 Y RX_CLK QN B SEL CLK A A MUX Q D[11:0] CLK MUX DAC CLK ADC SEL D[11:0] B[11:0] D[11:0] Q[11:0] Y[11:0] RXD[11:0] Dual ADC Dual DAC CLK D Q_DATA[11:0] RXOUTQ B[11:0] Y[11:0] A[11:0] CLK TXINQ CLK Q_DATA[11:0] MUX A[11:0] I_DATA[11:0] REG D[11:0] MUX DAC SEL REG D[11:0] Q[11:0] tx_fsinc_polarity LimeLight™ ADC SEL TXINI D[11:0] More detailed functional diagram of the RX data interface is shown in Figure 11. Corresponding waveforms are given in Figure 12. The interface is a 12 bit parallel bus output from the LMS6002D to the base band IC carrying multiplexed IQ data samples from the receive ADCs. The interface data rate is twice the ADCs sample rate. RX_IQ_SEL flag is provided to identify I and Q samples on the multiplexed bus. The receive clock coming from the baseband is on chip divided by two before being used by the ADC’s. The ADCs sampling edge is also programmable via SPI link. RXOUTI B[11:0] Y[11:0] Receiver Data Interface CLK DFF TX_IQ_SEL TX_CLK MUX CLK TXD[11:0] CLK A[11:0] SEL REG D[11:0] Q[11:0] REG D[11:0] Q[11:0] I_DATA[11:0] The TX digital IQ interface related pins are described as follows:  TX_CLK TX interface data clock, positive edge sensitive (input)  TXD[11:0] 12 bit multiplexed IQ data bus (input)  TX_IQ_SEL Indicates the location of I and Q data on the multiplexed bus (input)  DACs sample rate o WCDMA 15.36 MS/s o GSM 1.083 MS/s TX IQ interface data rate o WCDMA 30.72 MS/s o GSM 2.167 MS/s LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs Some examples of the RX interface data rates are provided below: tOD RX_CLK  RX_CLK/2  I_DATA[11:0] I0 I1 Q_DATA[11:0] Q0 Q1 RXD[11:0] I0 Q0 I1 IQ Interface Timing Parameters Q1 Parameter TX Setup Time (tSETUP) TX Hold Time (tHOLD ) RX Output Delay (tOD) at 15pF load RX_IQ_SEL External Signals ADCs sample rate o WCDMA 15.36 MS/s o GSM 1.083 MS/s RX IQ interface data rate o WCDMA 30.72 MS/s o GSM 2.167 MS/s Min 1 0.2 Typ Max 6 Internal Signals Table 6: Digital IQ interface timing parameters at 3.3V IO supply Figure 12: RX data interface signals DACs Electrical Specifications (At TA = 25°C, TAVDD33 = 3.3 V, FCLK = 40 MSPS, FOUT = 4 MHz, internal references, -1 dBFS input signal unless otherwise noted) Parameter Condition Digital Core Supply Analog Supply Number of Bits Min Typ Max 1.7 1.8 1.9 V 3.1 3.3 3.5 V Two’s complement format 12 DAC Sampling Rate Unit bits 40 MHz Full Scale Current Programmable 2.5 mA Output Amplitude At 100 Ohm differential load 250 mVpp diff SFDR 60 dBc ENOB 10 bits Table 7: DACs electrical specifications ADCs Electrical Specifications (At TA = 25°C, RAVDD18 = 1.8 V, FCLK = 40 MSPS, FOUT = 4 MHz, internal references, -1 dBFS input signal unless otherwise noted) Parameter Min Typ Max Digital Core Supply 1.7 1.8 1.9 V Analog Supply 1.7 1.8 1.9 V Number of Bits Condition Two’s complement format 12 ADC Sampling Rate Input Amplitude Differential 1 Input Common Mode Voltage Input buffer off 0.9 Unit bits 40 MHz 1.8 Vpp V Input Impedance 2 kOhm ENOB 10 bits Table 8: ADCs electrical specifications LMS6002D LimeLight™ 8 © Copyright Lime Microsystems Unit ns ns ns LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs Digital IQ Interface IO Buffers Specifications Parameter Condition Can go below 3.3V nominal to support LV CMOS signalling Supply Voltage (PVDD) Input High VIH Input Low VIL Output High VOH Output Low VOL Input Pad Capacitance CIN Output Drive Current1 1 Min Typ Max 1.7 3.3 3.5 PVDD-0.8 0.8 PVDD-0.4 0.4 3.5 8 Unit V V V V V pF mA Maximum peak current that flows when the output digital lines change state and begin charging the load capacitance. Table 9: Digital IO buffers specifications at 3.3V supply Both write and read SPI operations are supported. The serial port can be configured to run in 3 or 4 wire mode with the following pins used:  SEN serial port enable, active low  SCLK serial clock, positive edge sensitive  SDIO serial data in/out in 3 wire mode serial data input in 4 wire mode  SDO serial data out in 4 wire mode don’t care in 3 wire mode Implementing Low Voltage Digital IQ Interface Digital IO buffers in LMS6002D are supplied using four pins (PVDDAD33A - PVDDAD33D). All these pins must be supplied by the same supply PVDD. There is one additional supply pin (PVDDVGG) dedicated for ESD protection diodes supply. PVDDVGG must be supplied by +3.3V. However, PVDD can go below 3.3V to implement low voltage signaling. For example, if PVDD=2.5V then all data lines in Figure 13 are set to 2.5V CMOS IOs. Having PVDDVGG=3.3V sets all inputs to be 3.3V tolerant. Minimum PVDD is 1.8V. PVDD 1.8 - 3.3 V +3.3 V 0 - PVDD CMOS Logic Levels Base Band 12 12 PVDDAD33A PVDDAD33B PVDDAD33C PVDDAD33D IO Buffers Supplies PVDDVGG ESD Diodes Supply TXD[11:0] TX_IQ_SEL TX_CLK TX (DAC) Interface Serial port key features:  16 SPI clock cycles are required to complete write operation.  16 SPI clock cycles are required to complete read operation.  Multiple write/read operations are possible without toggling serial port enable signal. All configuration registers are 8-bit wide. Write/read sequence consists of 8-bit instruction followed by 8-bit data to write or read. MSB of the instruction bit stream is used as SPI command where CMD=1 for write and CMD=0 for read. Remaining 7 bits of the instruction represent register address. The write/read cycle waveforms are shown in Figures 14, 15 and 16. Note that the write operation is the same for both 3-wire and 4-wire modes. Although not shown in the figures, multiple byte write/read is possible by repeating the instruction/data sequence while keeping SEN low. RX_CLK_OUT RX_CLK RX (ADC) RX_IQ_SEL Interface RXD[11:0] SPI Timing Parameters LMS6002D Parameter Clock Frequency, Figure 13: Digital IQ interface supplies 4-wire mode 3-wire mode Enable Setup Time (tES) Enable Hold Time (tEH) Data Setup Time (tDS) Data Hold Time (tDH) Data Output Delay (tOD) at 12pF load SERIAL PORT INTERFACE Description The functionality of LMS6002D transceiver is fully controlled by a set of internal registers which can be accessed through a serial port interface. Min Typ Max 50 20 2 0.2 1 0.2 9 Table 10: SPI timing parameters at 3.3V IO supply LMS6002D LimeLight™ 9 © Copyright Lime Microsystems Unit MHz MHz ns ns ns ns ns Write Operation tES tEH tDS tDH SEN SCLK DON'T CARE SDIO DON'T CARE DON'T CARE 1 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 WRITE INSTRUCTION D4 D3 D2 D1 DON'T CARE D0 DATA Figure 14: SPI write cycle, 3-wire and 4-wire modes Read Operation tES tOD tDS tEH tDH SEN SCLK DON'T CARE SDIO DON'T CARE DON'T CARE A6 0 A5 A4 A3 A2 A1 DON'T CARE A0 READ INSTRUCTION SDO D7 DON'T CARE D6 D5 D4 D3 D2 D1 DON'T CARE D0 OUTPUT DATA Figure 15: SPI read cycle, 4-wire mode (default) tES tDS tOD tEH tDH SEN SCLK DON'T CARE SDIO DON'T CARE DON'T CARE 0 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 READ INSTRUCTION D4 D3 D2 D1 D0 DON'T CARE OUTPUT DATA Figure 16: SPI read cycle, 3-wire mode SPI Memory Map The LMS6002D configuration registers are divided into eight logical blocks as shown in Table 11. 3 MSBs of the available 7-bit address are used as block address while the remaining 4 bits are used to address particular registers within the block. Integer and fractional part of the PLL divider are stored in four bytes of configuration memory. To change their values, four write cycles are required. Hence, the controlled PLL should see new NINT and NFRAC when all four bytes are updated, otherwise it will generate unpredicted and wrong LO frequency while being configured. Such parameters are provided through a shadow register. Shadow register outputs new values only when SEN is high, i.e. there is no access to configuration memory. For that reason, DSM (PLL) SPI synchronization clock, derived from the PLL reference, must be enabled while writing to or reading from the PLL configuration registers and should last at least two cycles more after SEN goes high. Address (7 bits) 000:xxxx 001:xxxx Description Top level configuration TX PLL © Copyright Lime Microsystems 010:xxxx 011:xxxx 100:xxxx 101:xxxx 110:xxxx 111:xxxx RX PLL TX LPF TX RF RX LPF, DACs and ADCs RX VGA2 RX RF Table 11: LMS6002D SPI memory map Implementing Low Voltage SPI Digital IO buffers and ESD protection diodes in the SPI region are all supplied from a single pin PVDDSPI33. PVDDSPI33 can go below 3.3V to implement low voltage signaling. For example, if PVDDSPI33=2.5V then all data lines in Figure 17, including PLL reference clock input, are set to 2.5V CMOS IOs. There is no dedicated ESD protection diodes supply here so when PVDDSPI33 is less than 3.3V, inputs will not be 3.3V tolerant. Minimum PVDDSPI33 is 1.8V. Base Band 0 - PVDDSPI CMOS Logic Levels 1.8 - 3.3 V PVDDSPI IO Buffers and PVDDSPI33 ESD Diodes Supply SEN SDO SDIO CLK SPI RESET TXEN RXEN Chip Control PLLCLK Reference Clock LMS6002D Figure 17: SPI supplies LMS6002D LimeLight™ 11 © Copyright Lime Microsystems PACKAGE OUTLINE AND PIN DESCRIPTION 9 mm 6.5 mm NC 116 114 112 115 7 101 99 96 97 94 95 92 93 90 91 88 89 87 2 86 4 84 6 82 8 80 10 78 85 83 81 79 9 11 7 mm 9 mm 13 DQFN120 9 x 9 mm 0.5 mm pitch 12 14 15 16 17 18 77 76 75 74 73 72 71 70 19 69 20 68 22 66 24 64 26 62 28 60 21 67 23 65 25 63 27 61 29 59 31 NC 30 33 32 35 34 37 36 39 38 41 40 43 42 45 44 47 46 49 48 51 50 53 52 55 54 57 56 0.5 mm 7 mm Figure 18: DQFN120 package (top view) LMS6002D LimeLight™ NC 12 © Copyright Lime Microsystems 58 NC 8.5 mm 5 109 107 105 103 98 7.5 mm 3 113 111 104 102 100 6.5 mm 1 110 108 106 Pin No Pin Name Type Description 1 2 3 4 5 6 7 8 9 10 11 12 13 PVDDAD33A RXD11 RXD10 RXD9 RXD8 RXD7 PVDDVGG RXD5 RXD6 RXD3 RXD4 PVDDAD33B RXD2 pads supply out cmos out cmos out cmos out cmos out cmos esd supply out cmos out cmos out cmos out cmos pads supply out cmos ADCs/DACs IOs supply (3.3V) ADCs digital output, bit 11 (MSB) ADCs digital output, bit 10 ADCs digital output, bit 9 ADCs digital output, bit 8 ADCs digital output, bit 7 ADCs/DACs IOs ESD supply (3.3V) ADCs digital output, bit 5 ADCs digital output, bit 6 ADCs digital output, bit 3 ADCs digital output, bit 4 ADCs/DACs IOs supply (3.3V) ADCs digital output, bit 2 14 15 16 17 18 19 20 21 22 23 24 RXD1 RXD0 RX_IQ_SEL RX_CLK PVDDAD33C TX_CLK TX_IQ_SEL TXD0 TXD1 TXD2 TXD3 out cmos out cmos out cmos in cmos pads supply in cmos in cmos in cmos in cmos in cmos in cmos ADCs digital output, bit 1 ADCs digital output, bit 0 (LSB) RX digital interface IQ flag RX digital interface clock ADCs/DACs IOs supply (3.3V) TX digital interface clock TX digital interface IQ flag DACs digital input, bit 0 (LSB) DACs digital input, bit 1 DACs digital input, bit 2 DACs digital input, bit 3 25 26 27 28 29 30 TXD4 TXD5 TXD6 TXD7 TXD8 TXD9 in cmos in cmos in cmos in cmos in cmos in cmos DACs digital input, bit 4 DACs digital input, bit 5 DACs digital input, bit 6 DACs digital input, bit 7 DACs digital input, bit 8 DACs digital input, bit 9 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 TXD10 TXD11 RDVDD18 PVDDAD33D RAVDD18 TDVDD18 TAVDD33 VREFAD XRESAD RX_CLK_OUT PLLCLKOUT ATP TXVCCLPF33 TXOUT2N TXVCCMIX33 TXOUT2P TXPVDD33 in cmos in cmos digital supply pads supply analogue supply digital supply analogue supply in/out in/out out cmos out cmos out analogue supply out analogue supply out esd supply DACs digital input, bit 10 DACs digital input, bit 11 (MSB) ADCs digital supply (1.8V) ADCs/DACs pads supply (3.3V) ADCs analogue supply (1.8V) DACs digital supply (1.8V) DACs analogue supply (3.3V) External capacitor for ADCs/DACs (>100nF) External resistor for ADCs/DACs Buffered RX_CLK (ADCs) clock, CMOS level Buffered PLLCLK (PLL reference) clock, CMOS level Analogue test point TXLPF supply (3.3V) TX output 2, negative TXMIX supply (3.3V) TX output 2, positive TX pads ESD supply (3.3V) 48 49 50 51 52 53 54 55 56 57 58 59 60 TXOUT1P TXVCCDRV33 TXOUT1N TXININ TXINIP UNUSED TXINQP UNUSED TXINQN TXVTUNE TXPVDDPLL33A TXVCCVCO33 TXVDDVCO18 out analogue supply out in/out in/out TX output 1, positive TXVGA2 supply (3.3V) TX output 1, negative TXDAC output / TXLPF input TXDAC output / TXLPF input in/out TXDAC output / TXLPF input in/out in/out esd supply analogue supply analogue supply TXDAC output / TXLPF input TXPLL loop filter output TXPLL pads ESD supply (3.3V) TXPLL 3.3V supply (3.3V) TXPLL VCO supply (1.8V) Note Can be lowered down to 1.8V to support LV signalling Two's complement Can be lowered down to 1.8V to support LV signalling Can be lowered down to 1.8V to support LV signalling Two's complement Can be lowered down to 1.8V to support LV signalling Can be used to align RXD[11:0] sampling clock in BB. Can be used as BB clock. Connect to ground Connect to ground Table 12: Pin descriptions LMS6002D 13 © Copyright Lime Microsystems Pin No Pin Name 61 62 63 64 65 66 67 68 69 70 TXVCCPLL18 TXPVDDPLL33B TXVCCCHP33 TXCPOUT TSTD_out1 TXEN SEN SDO SDIO SCLK 71 PLLCLK 72 TRXVDDDSM18 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 Type Description digital supply esd supply analogue supply in/out out cmos in cmos in cmos out cmos in/out cmos in cmos in, cmos or clipped sine digital supply TX PLL modules 1.8V supply (1.8V) TX PLL pads ESD supply (3.3V) TX PLL charge pump supply (3.3V) Transmit PLL loop filter input TX and RX PLLs digital test point Transmitter enable, active high Serial port enable, active low Serial port data out Serial port data in/out Serial port clock, positive edge sensitive VSPI18 PVDDSPI33 RESET RXEN TSTD_out2 RXVCCCHP33 RXVCCLOB33 RXCPOUT RXPVDDPLL33B RXVCCVCO33 RXVCCPLL18 RXVDDVCO18 RXVCCPLL33 RXPVDDPLL33A RXVTUNE UNUSED XRES12k digital supply esd supply in cmos in cmos out cmos analogue supply analogue supply in/out esd supply analogue supply digital supply analogue supply analogue supply esd supply in/out SPI digital core supply (1.8V) SPI pads and ESD Supply (3.3V) Hardware reset, active low Receiver enable, active high TX and RX PLLs digital test point RXPLL charge pump supply (3.3V) RXPLL LO buffer supply (3.3V) RXPLL loop filter input RXPLL pads ESD supply (3.3V) RXPLL 3.3V supply (3.3V) RXPLL 1.8V supply (1.8V) RX PLL VCO supply (1.8V) RX PLL 3.3V supply RXPLL pads ESD supply (3.3V) RXPLL loop filter output in/out External 12k 1% resistor to ground 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 RXVCCMIX33 OEXLNA1P IEXMIX1P UNUSED IEXMIX1N OEXLNA1N RXIN1P RXIN1EP RXIN1N RXIN1EN RXIN2P RXVCCLNA33 RXIN2N OEXLNA2P IEXMIX2P OEXLNA2N IEXMIX2N RXPVDD33 analogue supply out in RXMIX supply (3.3V) LNA1 output positive Mixer input 1 positive in out in in in in in analogue supply in out in out in esd supply Mixer input 1 negative LNA1 output negative RX1 (LNA1) input LNA1 external emitter inductance RX1 (LNA1) input LNA1 external emitter inductance RX2 (LNA2) input RX LNA supply (3.3V) RX2 (LNA2) input LNA2 output positive Mixer input 2 positive LNA 2 output negative Mixer input 2 negative RX pads ESD supply (3.3V) 108 109 110 111 112 113 114 115 116 117 RXIN3P RXVCCTIA33 RXIN3N RXVCCLPF33 RXVCCVGA33 RXOUTQP RXOUTQN RXOUTIN RXOUTIP GLOBAL GND in analogue supply in analogue supply analogue supply in/out in/out in/out in/out GLOBAL GND RX3 (LNA3) input RXTIA (RXVGA1) supply (3.3V) RX3 (LNA3) input RXLPF supply (3.3V) RXVGA2 supply (3.3V) RXVGA2 output / RX ADC input RXVGA2 output / RX ADC input RX VGA2 output / RX ADC input RX VGA2 output / RX ADC input Package paddle ground PLL reference clock input (23MHz - 41 MHz) Note High Z when SEN=1 Minimum input level is 0.2Vpp. Both DC and AC coupling supported. Delta sigma digital core supply (1.8V) Can be lowered down to 1.8V to support LV signalling Connect to ground Connect to ground Connect to ground Connect to ground Table 12: Pin descriptions (continued) LMS6002D 14 © Copyright Lime Microsystems LMS6002D - Multi-band Multi-standard Transceiver with Integrated Dual DACs and ADCs TYPICAL APPLICATION Typical application circuit of LMS6002D is given in Figure 19. Note that only RF part is shown. It is recommended all unused pins to be grounded, digital test pins should be left open while RF pins should be connected as in Figure 19. As shown, RF ports are matched for UMTS bands I and V while TXOUT2 and RXIN3 are broadband matched. Refer to “LMS6002D Reference Design and PCB Layout Recommendations” for more details. Figure 19: LMS6002D Typical Application Circuit Diagram – RF part Lime Microsystems Surrey Tech Centre Occam Road The Surrey Research Park Guildford Surrey, GU2 7YG UNITED KINGDOM Tel: +44 (0) 1428 653 335 Fax: +44 (0) 1483 683 481 e-mail: enquiries@limemicro.com http://www.limemicro.com
MYRIADRF-1
PDF文档中包含了关于LMS6002D这款多频段多标准收发器的详细信息,包括其物料型号是LMS6002D,是一款集成了双DACs和ADCs的收发器。
器件简介指出它是一个单芯片收发器,覆盖了0.3-3.8GHz的频率范围,并且具有数字基带接口和集成的12位D/A及A/D转换器。
引脚分配功能详解在文档中有详细的框图和说明,例如TXINI和TXINQ是发射IQ数据输入,RXIN1、RXIN2和RXIN3是接收信号输入,而TXOUT1和TXOUT2是发射信号输出。
参数特性表列出了诸如RF频率范围、基带带宽、电源电压、功耗等关键参数。
功能详解部分描述了其零中频架构、发射和接收路径的增益控制、PLL架构等。
应用信息显示它适用于3GPP (WCDMA/HSPA, LTE)、3GPP2 (CDMA2000)、4G LTE应用以及GSM皮基站。
封装信息表明它使用120引脚DQFN封装。
此外,文档还提供了典型应用电路图,以帮助设计者进行PCB布局和设计。
MYRIADRF-1 价格&库存
很抱歉,暂时无法提供与“MYRIADRF-1”相匹配的价格&库存,您可以联系我们找货
