MicroAmp MB-14 Circuit Board
Straight-Through Transmission Line
FEATURES
• Use for traight-through connections
• Can also be used for
custom passive networks
• RO-4350 board material
• Fits MicroAmp MH-series housings
The MicroAmp MB-14 circuit board is used for a straight-through connection with the MicroAmp MH series of connectorized
housings. It can be used as an extension when designing multiple board circuits with the MH-2 housing, thereby allowing a single
board to be tested before adding a second one in cascade. The MB-14 can also be used to create custom passive networks by cutting
the center trace and soldering components in series or shunt. Boards are fabricated from a high-performance 13 mil thick RO-4350
laminate with RoHS compatible ENIG plating (electroless nickel/immersion gold) on both the component side and the solid bottom
ground plane. The board measures 0.490" x 0.590" and mounts into the housing with four or eight #1-72 screws for optimal high
frequency grounding. Pads for the input/output RF connectors allow the SMA center pins to be easily soldered to the board after it is
installed into the housing.
THROUGH-LINE SCHEMATIC
REF
SIZE
FUNCTION
J1
J2
N/A
N/A
RF port
RF port
ASSEMBLY
For additional product information, please visit www.twinind.com
Contact information: 925-866-8946 (phone) 925-866-8937 (fax) Sales@twinind.com
很抱歉,暂时无法提供与“MB-14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+135.664411+17.54329
