MB-7
MB-7
    TWIN
    SMD
    RF EVAL FOR PASSIVE NETWORK
MB-7 数据手册
MicroAmp MB-7 Circuit Board For Passive Networks FEATURES • Generic layout for passive networks • Easily create lumped element filters, equalizers, bias networks, attenuators, etc. • Up to three series elements • Up to eight parallel elements • Accommodates 0603/0805 parts • RO-4350 board material • Fits MicroAmp MH-series housings The MicroAmp MB-7 circuit board is designed for rapid prototyping of passive networks such as filters, attenuators, equalizers, bias tees, etc. Passive elements such as resistors, capacitors, and inductors can be combined in a variety of series and shunt configurations. Networks can be easily designed and assembled with standard surface-mount passive components. It includes provisions for three series elements and up to eight shunt elements in either 0603 or 0805 packages. This board will fit the MicroAmp MH series of connectorized housings that allow it to be used as a single passive network or cascaded with other MicroAmp boards for added versatility. Boards are fabricated from a high-performance 13 mil thick RO-4350 laminate with RoHS compatible ENIG plating (electroless nickel/immersion gold) on both the component side and the solid bottom ground plane. The board measures 0.490" x 0.590" and mounts into the housing with four #1-72 screws. Pads for the RF connectors allow the SMA center pins to be easily soldered to the board after it is installed into the housing. REF SIZE S1-S3 0603/0805 P1-P8 0603/0805 J1 J2 FUNCTION Series element Parallel element Input Output ASSEMBLY NETWORK SCHEMATIC For additional product information, please visit www.twinind.com Contact information: 925-866-8946 (phone) 925-866-8937 (fax) Sales@twinind.com
很抱歉,暂时无法提供与“MB-7”相匹配的价格&库存,您可以联系我们找货
