Wireless Development Kits
Proprietary RF Modules
Innovative Technology
for a Connected World
THE FASTEST WAY TO WIRELESS
Size, speed, range, power consumption, and cost are all important issues to engineers
integrating RF connectivity. Laird Technologies addresses these issues with compact
2.4GHz, 900MHz, and 868MHz modules. Designed for fast OEM integration, our
radios suit applications where both high reliability and long range are essential.
Laird Technologies’ Development Kits provide a complete design environment to help
engineers get up and running with our solutions in a matter of minutes. Each system
includes the radio modules and accessories required to install and test RF, allowing for
reduced R&D costs, quick agency certification, and fast time to market.
Development Kits are not just for engineers working with tight resources, limited time
or varying experience. All OEMs can benefit from our comprehensive tools and highly
technical expertise in the complex field of RF.
SOFTWARE
ANTENNAS
In an easy menu-driven format, our
Windows-compatible software provides
several helpful development utilities,
allowing OEMs to quickly begin
performing tests for configuration
modes, range measurements, antenna
evaluations, power management, and
data throughput. Designers can easily
program the radio modules to any
desired configuration with the EEPROM
Viewer/Editor feature.
Antenna type, gain, and location are
among the most critical elements of a
wireless system. Laird Technologies’
kit allows OEMs to connect different
antennas and evaluate their performance
in various situations. In addition, our
engineers can provide a comprehensive
antenna review during the design
process to determine the best antenna
and location for the application.
CONFIGURATION
COMPLIANCE
All Laird Technologies’ radio modules
have configuration parameters stored
in EEPROM that are used to customize
the serial interface mode and provide
for general system set-up. The modules
ship with default parameters already
configured to enable plug-and-play
(these can be changed using our
development tools or with custom
interfaces developed by the OEM.)
RF products are required to meet
regulatory compliance such as FCC
(USA), IC (Canada), and CE(Europe). Our
radio module approvals help eliminate
significant costs and time, even when
regulatory compliance is still required for
the final product. Laird Technologies’
experts can help guide OEMs through
the approval process.
FEATURES
• Testing and tuning antennas
• Optimizing system timing
• Hardware and software integration
• Finding best configuration
for application
• Increasing transmission range
• Finding best mode for data
rate and network
global solutions: local support
• Lowest Cost
TM
USA: +1.800.492.2320
Europe: +44.1628.858.940
Asia: +852.2268.6567
wirelessinfo@lairdtech.com
www.lairdtech.com/wireless
Wireless development kits are also available for our range of standards based wireless
modules, covering Bluetooth, 802.11 and ZigBee. Please contact Laird Technologies
for further information or visit www.lairdtech.com/wireless.
2.4GHz Systems:
What’s Included:
Two (2) RF Modules
PRM110 RF modules, -40º to +80ºC, 3.3V, serial interface,
u.fl antenna connector, +4dBm to +21dBm power output
PRM111 RF module, -40º to +80ºC, 3.3V, serial interface,
integral antenna, +4dBm to +21dBm power output
AC4424 RF Modules, -40º to +80ºC, 5V, TTL serial interface,
MMCX antenna connector, 200mW power output
MMCX antenna connector, 100mW power output
MMCX antenna connector, 10mW power output
integral antenna, 10mW power output
Choose from Laird Technologies’ 2.4GHz,
900MHz or 868MHz RF Modules
Two (2) Adapter Boards
RS232, RS485, 5V/3.3V serial TTL, and USB
interfaces are supported. Features include:
1) loop-back for distance-testing using
one computer
2) status/communications LED indicators
3) switches for easy configuration & reset
4) test points for troubleshooting
One (1) Utilities CD
Script-driven utilities include:
DVK-PRM110
DVK-PRM111
SDK-AC4424-200
SDK-AC4424-100
SDK-AC4424-9
SDK-AC4424-9A
1) transmit/receive emulator
2) single-line command interface
900MHz Systems:
3) EEPROM viewer/editor; configuration
AC4790 RF Modules, -40º to +80ºC, 3.3V, TTL serial interface,
MMCX antenna connector, 5mW–1000mW variable power output
AC4790 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface,
MMCX antenna connector, 5mW–200mW variable power output
integral antenna, 5mW–200mW variable power output
AC4790-1x1 tiny RF Modules, -40º to +80ºC, 3.3V, TTL serial interface,
10mW variable power output
AC4490 RF Modules, -40º to +80ºC, 3.3V, TTL serial interface,
AC4490 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface,
AC4490-1x1 tiny RF Modules, -40º to +80ºC, 3.3V, TTL serial interface,
information storage file
4) “What’s This?” Help File format provides
descriptions of each configuration option
5) Error checker prevents configuration errors
Two (2) AC Power Adapters Power for adapter board and radio module; USB
and battery power optional
Two (2) DB9 Serial Cables
Connect the adapter boards to a PC via DB9
Two (2) USB Cables
Connect the adapter boards to a PC via USB
Two (2) Antennas
Convenient, small antennas plug directly into the
radio module’s connector. Longer range antennas
are also available for external antenna modules.
SDK-AC4790-1000M
SDK-AC4790-200M
SDK-AC4790-200A
SDK-AC4790-1x1
SDK-AC4490-1000M
SDK-AC4490-200M
SDK-AC4490-200A
SDK-AC4490-1x1
868MHz Systems:
2.4 GHz Models
AC4868 RF Modules, -40º to +80ºC, 3.3V, TTL serial interface,
MMCX antenna connector, 5–250mW power output
AC4486 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface,
integral antenna, 5mW power output
MMCX antenna, 5mW power output
SDK-AC4868-250M
SDK-AC4486-5A
SDK-AC4486-5M
The details contained within the document are subject to change. Download the product
specification from www.lairdtech.com/wireless for the most current specification.
900/863 GHz Model
LT2510 Model
1X1-inch Model
LWS-SPEC-LDKit 0109
Contact information:
USA: +1 800 492 2320
EUROPE: +44 1628 858 940
ASIA: +852 2268 6567
Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies
materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness,
merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy
of which will be furnished upon request. For further information please visit our website at www.lairdtech.com. Alternatively contact: wirelessinfo@lairdtech.com. Bluetooth®
is a trademark owned by Bluetooth SIG, Inc., USA and licensed to Laird Technologies.
© 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc.
EMAIL: wireless.systems@lairdtech.com
