DA14585-00ATDB-P
DA14585-00ATDB-P
    DIALOGSEMICONDUCTOR(戴乐格)
    BT5.0PRODBQFN40
DA14585-00ATDB-P 数据手册
SmartBond™ DA14585 Smallest, lowest power and most integrated Bluetooth 5 SoC Connected devices are constantly evolving. New generations appear that are smarter, more full featured and have longer battery lifetimes. To enable this, SmartBond has evolved too. The DA14585 offers designers all the benefits of the industry-leading DA14580 but with even greater flexibility to create more advanced applications from the smallest footprints and power budgets. As part of the Dialog SmartBond family, the DA14585 is the smallest, lowest power and most integrated Bluetooth® solution available. This versatile SoC is ideal for adding Bluetooth low energy to products like remote controls, proximity tags, beacons, connected medical devices and smart home nodes. It supports all Bluetooth developments up to and including Bluetooth 5 and Bluetooth low energy Mesh. Plus, with 96 kB of RAM, the DA14585 has double the memory for user applications of its predecessor to take full advantage of the standard’s features. It also includes an integrated microphone interface for voice support at low additional cost. The wide supply voltage range (0.9 –3.6 V) covering a larger choice of energy sources and gives full design flexibility. Like all SmartBond solutions, the DA14585 is easy to design-in and supports standalone as well as hosted applications. It is supported by a complete development environment and Dialog’s SmartSnippets™ software that helps you optimize your software for power consumption. SWD RC32KHz UARTx2 SPI 12C OTP 64 kB ADC RAM 32 kB RAM 32 kB QDEC Applications ■ ■ ■ ■ ■ ■ ■ ■ ■ DCDC BUCK SRC TIMERS RADIO RAM 16 kB 4-CH DMA Digital PHY RAM 16 kB WAKEUP PDM RC16MHz RCX KEYBOARD PCM/12S XTAL32K CPU BLE 5.0 MAC Ready ARM M0™ XTAL16M DA14585 ROM 128 kB DCDC BOOST LDOs GPIO matrix www.dialog-semiconductor.com/bluetoothlowenergy Remote controls Proximity tags and trackers Beacons Connected medical devices Smart home Human Interface Devices VR controllers Connected sensors Wireless charging SoC Features • Complies with Bluetooth 5.0, ETSI EN 300 328 and EN 300 440 Class 2 (Europe), FCC CFR47 Part 15 (US) and ARIB STD-T66 (Japan) • Supports up to 8 Bluetooth LE connections • Fast cold boot in less than 50 ms • Processing units - - - 16 MHz 32 bit ARM Cortex-M0 with SWD interface Dedicated Link Layer Processor AES-128 bit encryption Processor • Memories - 64 kB One-Time-Programmable (OTP) memory - 96 kB Data/Retention SRAM - 128 kB ROM Operating System and protocol stack • Power management - Integrated Buck/Boost DCDC converter - P0, P1, P2 and P3 ports with 3.3 V tolerance - Easy decoupling of only 4 supply pins - Supports coin (typ. 3.0 V) and alkaline (typ. 1.5 V) battery cells - 1.8 V cold boot support-buck mode - 0.9 V cold boot support-boost mode - 10-bit ADC for battery voltage measurement • Digital controlled oscillators - 16 MHz crystal (±20 ppm max) and RC oscillator - 32 kHz crystal (±50 ppm) - RCX oscillator(±500 ppm max) • Flexible Reset Circuitry - System & Power On Reset in a single pin • General purpose, Capture and Sleep timers - Digital interfaces - Gen. purpose I/Os: 14 (WL-CSP34), 25 (QFN40), 32 (QFN48) - 2 UARTs with hardware flow control up to 1 MBd - SPI+™ interface - I²C bus at 100 kHz, 400 kHz - 3-axes capable Quadrature Decoder • Analog interfaces - 4-channel 10-bit ADC www.dialog-semiconductor.com/bluetoothlowenergy • Radio transceiver - Fully integrated 2.4 GHz CMOS transceiver - Single wire antenna: no RF matching or RX/TX switching required - Current consumption with supply voltage equal 3 V: ▪ TX: 3.4 mA, RX: 3.7 mA (with ideal DC-DC) - +0 dBm transmit output power - -20 dBm output power in ‘Near Field Mode’ - -93 dBm receiver sensitivity • Packages - QFN 40 pins, 5 mm x 5 mm x 0.9 mm - WLCSP 34 pins, 2.40 mm x 2.66 mm x 0.39 mm Bluetooth 5.0 Supporting the Bluetooth 5.0 core specification, DA14585 enables new enhanced Bluetooth low energy functionality ideal for applications such as remote controls, beacons, connected sensors and innovative medical devices. Among the new features, DA14585 supports Data Packet Length Extension, Link Layer Privacy v1.2, Secure Connections, Bluetooth low energy Mesh and Efficient connectable Advertising. Audio Unit The integrated Audio Unit (AU) is equipped with a Pulse-Density Modulation (PDM) interface that can be connected to up to 2 input devices (e.g. MEMS microphones) or output devices, a PulseCode modulation (PCM) controller which provides an up to 192 kHz synchronous interface to external audio devices, ISDN circuits and serial data interfaces (I2S) and a 24-bit Sample Rate Converting unit (SRC) used to convert the sampling rate of audio samples between the various interfaces. PDM and PCM functionality can be mapped to any GPIO through the user programmable pin logic. An integrated DMA controller handles all data transfers between the AU and the RAM providing the CPU with the freedom to cope with other tasks. Enhanced Memory The DA14585 has a large memory capacity for user applications: 96 kB of Data RAM with retention capability, 128 kB of ROM and 64 kB of One-Time-Programmable (OTP) memory. The granularity of the RAM cells (32 kB/16 kB/16 kB/32 kB) allows retaining only the RAM needed and achieves the minimum power consumption during sleep time. www.dialog-semiconductor.com/bluetoothlowenergy Wide Input Voltage The DA14585 can be configured in buck or boost mode to support a multitude of power sources from zinc-air batteries to alkaline or coin cells. Furthermore, in order to maximize the available power from zinc air or coin cell and build products with long battery lifetimes, the DA14585 is able to cold boot at 0.9 or 1.8 V respectively exploiting the full capacity of the connected battery. Compatibility As part of the SmartBond family and successor of the DA1458x product family, DA14585 is fully pin-compatible with DA14580, DA14581 and DA14583 existing designs may be quickly upgraded. DA14585 is suitable for fully hosted applications without an external MCU. Software and Tools The DA14585 is also supported by Dialog SmartSnippets Studio, a royalty-free software development platform for all SmartBond devices, which contains: ■ S  martSnippets Toolbox: A tool suite covering all software developer needs, including power profiling, FLASH or OTP programming and testing ■ SmartSnippets DA1458x Software Development Kit and documentation Ordering Information Part number Package Pitch(mm) Size (mm) Shipment Pack Quantity DA14585-00000AT2 QFN40 0.4 5 x 5 x 0.9 Reel 100/1000/5000 DA14585-00000VV2 WL-CSP34 0.4 2.40 x 2.66 x 0.39 Reel 100/1000/7500 Dialog Semiconductor Worldwide Sales Offices - www.dialog-semiconductor.com email: info@diasemi.com United Kingdom Phone: +44 1793 757700 The Netherlands Phone: +31 73 640 88 22 Japan Phone: +81 3 5425 4567 Singapore Phone: +65 648 499 29 Korea Phone: +82 2 3469 8200 Germany Phone: +49 7021 805-0 North America Phone: +1 408 845 8500 Taiwan Phone: +886 281 786 222 Hong Kong Phone: +852 3769 5200 China (Shenzhen) Phone: +86 755 2981 3669 This publication is issued to provide outline information only, which unless agreed by Dialog Semiconductor may not be used, applied, or reproduced for any purpose or be regarded as a representation relating to products. All use of Dialog Semiconductor products, software and applications referred to in this document are subject to Dialog Semiconductor’s Standard Terms and Conditions of Sale, available on the company website (www.dialog-semiconductor.com) unless otherwise stated. Dialog and the Dialog logo are trademarks of Dialog Semiconductor plc or its subsidiaries. All other product or service names are the property of their respective owners. © Copyright 2016 Dialog Semiconductor. All rights reserved. 1216CREA China (Shanghai) Phone: +86 21 5424 9058
DA14585-00ATDB-P 价格&库存
很抱歉,暂时无法提供与“DA14585-00ATDB-P”相匹配的价格&库存,您可以联系我们找货
