SR4C033-EVB-1
SR4C033-EVB-1
    ANTENOVA(安诺亚)
    LATONARIGHTEVALUATIONBOARD
SR4C033-EVB-1 数据手册
Latona Antenna for LP-WAN applications Part No. SR4C033-L SR4C033-R 1. lamiiANT ® Product Specification Features         2. Antenna for LP-WAN applications. Including NB-IOT, LoRa, SigFox, ISM and Weightless-P Frequency bands from 791- 960MHz Maintains high performance on device: DFI (Designed for Integration) Corner placement to save space Low profile innovative design. SMD mounting Supplied on Tape and Reel Automotive temperature rating. Description Latona uses a ground plane on the host PCB to radiate effectively. The antenna itself requires a clearance underneath. An external matching circuit is used to optimise the antenna within a device to the required bands. Designed specifically for LP-WAN applications that require a small robust solution. Latona comes in Left and Right hand versions to optimise placement. 3. Applications        Remote monitoring/ Smart meters Network Devices Smart Buildings Smart cities Manufacturing automation Agriculture/Environment Consumer tracking Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 1 Latona Part No. SR4C033 4. Part Number Latona Left: SR4C033-L Latona Right: SR4C033-R 5. General Data Product name Latona Part Number SR4C033 Frequency 791 – 960MHz Polarization Linear Operating temperature -40°C to140°C Environmental Condition Test ISO16750-4 5.1.1.1/5.1.2.1/5.3.2 Impedance with matching 50 Ω Weight < 2g Antenna type SMD Dimensions 20.0 x 11.0 x 1.6 (mm) 6. RF Characteristics 791 – 862 MHz 0.5dBi 824 – 960 MHz 0.8dBi -1.50dBi -1.50dBi Average efficiency >60% >65% Maximum return loss -9dB -7dB Maximum VSWR 2.1:1 2.6:1 Peak gain Average gain (Linear) All data measured on Antenova’s evaluation PCB Part No. SR4C033-EVB-1 Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 2 Latona Part No. SR4C033 7. RF Performance The performance is shown for two tuned variants (Tuning dependant on required band). Matching circuit is used for band selection. B20: 791 – 862MHz B5 and B8: 824-894MHz; 880- 960MHz 7.1 Return Loss 7.2 VSWR Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 3 Latona Part No. SR4C033 7.3 Antenna pattern 7.3.1 791 – 862 MHz 3D pattern at 830 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 4 Latona Part No. SR4C033 7.3.2 824 – 960 MHz 3D pattern at 880 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 5 Latona Part No. SR4C033 8. Antenna Dimensions Latona Left: SR4C033-L Latona Right: SR4C033-R Top side L W H Length Width Height 20.0 ±0.1 11.0 ±0.1 1.6 ±0.1 All Dimensions in (mm) Bottom Side 9 8 7 6 6 6 3 4 1 2 6 5 6 5 7 8 9 6 6 6 4 3 2 1 All Dimensions in (mm) Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 6 Latona Part No. SR4C033 9.0 Schematic symbol and Pin definition The circuit symbol for the antenna is shown below. The antenna has 9 pins with only two as functional. All other pins are for mechanical strength. Pin Description 2 Feed 1 Band Select (B.SEL) 3,4,5,6,7,8,9 Not used (Mechanical only) 10.0 Antenna footprint The recommended host PCB footprint is below. 9 copper pads all 1.8 x 1.3 (mm) All Dimensions in mm Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 7 Latona Part No. SR4C033 11. Electrical Interface 11.1 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum. • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω. Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the track so the characteristic impedance of the co-planar transmission is 50 Ω. 11.2 Matching Circuit The antenna requires a matching circuit that must be optimized for each product. The matching circuit will require up to five components and the following circuit should be designed into the host PCB. Not all components may be required but should be included as a precaution. The matching network must be placed close to the antenna feed to ensure it is more effective in tuning the antenna. Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 8 Latona Part No. SR4C033 12.0 Antenna Integration Guide 12.1 Antenna Placement Whatever the size of the host PCB, the antenna should ideally be placed on the host PCB’s shortest side, in the corner. The left / right antennas are placed in the corresponding corner of the PCB: SR4C033-L (Left Corner) and SR4C033-R (Right Corner). 12.2 Host PCB Layout The footprint and clearance on the host PCB must meet the antenna specification. An example of the PCB layout shows the antenna footprint with clearance. The feed (Pin 2) connects to the matching circuit close to the antenna. For Pin 1 (B.SEL) the component should be close to this pin. Example host layout 1 Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 9 Latona Part No. SR4C033 12.3 Host PCB Clearance Below shows the antenna footprint and clearance through all layers on the PCB. Only the antenna pads and connections to feed and GND are present within this clearance area. The clearance area required is 20.0 x 11.0 (mm). The clear-out area is simply defined as the same size as the antenna. No additional clearance is required. Clearance area Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 10 Latona Part No. SR4C033 13.0 Reference Board The reference board has been designed for evaluation purposes of SR4C033 antenna and includes a SMA female connector. SR4C033-EVB-1 Evaluation Board (For SR4C033-R) SR4C033-EVB-2 Evaluation Board (For SR4C033-L) To order a reference board contact sales@antenova-m2m.com. Please state if Left or Right version. SR4C033-EVB-1 = SR4C033-R (Right) SR4C033-EVB-2 = SR4C033-L (Left) Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 11 Latona Part No. SR4C033 13.1 Reference Board Matching Circuit The reference board has been designed for evaluation purposes of SR4C033-L and SR4C033-R and includes a SMA female connector. Designator Type L1 Inductor L2 Not Fitted Value 33nH Description Murata LQG15HN series Not Fitted Not Fitted C1 Not Fitted Not Fitted Not Fitted C2 Capacitor 0.5pF Murata GRM15 series B.SEL (Band Selection pin component) Frequency band B20 Designator Type Inductor Value 6.8nH Description Murata LQG15 series L3 B5, B8 L3 Inductor 3.3nH Murata LQG15 series Band 20 = 791-862MHz Band 5 = 880-960MHz Band 8 = 824-894MHz Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 12 Latona Part No. SR4C033 14. Soldering This antenna is suitable for lead free soldering. The reflow profile should be adjusted to suit the device, oven and solder paste, while observing the following conditions:    The maximum temperature should not exceed 240 ºC However for lead free soldering, a maximum temperature of 255 ºC for no more than 20 seconds is permitted. The antenna should not be exposed to temperatures exceeding 120 ºC more than 3 times during the soldering process. 15. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. 16. Packaging 16.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 24 Months Storage place Away from corrosive gas and direct sunlight Reels should be stored in unopened sealed manufacturer’s plastic packaging. Packaging Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on antennas. If short term storage is necessary, then it is highly recommended that the bag containing the antenna reel is re-sealed and stored in like storage conditions as in above table. Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 13 Latona Part No. SR4C033 16.2 Tape Characteristics Ko Ao Bo 2.80 11.40 ± 0.1 P0 20.40 ± 0.1 P1 4.00 ± 0.1 16.00 ± 0.1 E1 F W 1.75 ± 0.1 14.2 ± 0.15 32.00 ± 0.3 P2 2.00 ± 0.1 Dimensions in mm Notes: 1) 10 sprocket hole pitch cumulative tolerance ±0.2mm. 2) Camber not to exceed 1mm in 100mm. 3) Ao and Bo measured on a plane 0.1mm above the bottom of the packet. 4) Ko measured from a plane on the inside bottom of the packet to the top surface carrier. Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 14 Latona Part No. SR4C033 16.3 Reel Dimensions A 330.0 ± 2.0 C 13.0 ± 0.5 N W1 80.0 ± 0.2 44.4 ± 0.3 All dimensions in mm Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 15 Latona Part No. SR4C033 16.4 Box Dimensions Width (W) 350mm Breadth Thickness (B) (H) 355mm 70mm 16.5 Bag Properties Reels are supplied in protective plastic packaging. 16.6 Reel Label Information Antenova Limited 4F, No 324, Sec 1, Nei-Hu Road Nei-Hu District, Taipei 11493, Taiwan, ROC 60mm info@antenova-m2m.com / www.antenova-m2m.com Description: Latona Part number: SR4C033-R Quantity: 1,000 Date Code: YYWW Manufacturer’s code number: lamiiANT ® 90mm Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Page 16 Latona Part No. SR4C033 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Limited nd 2 Floor Titan Court 3 Bishop Square Hatfield AL10 9NA UK Antenova Limited 100 Brush Creek Road Suite 103, Santa Rosa California 95404, USA Antenova Asia Limited 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +44 1223 810600 Email: sales@antenova-m2m.com Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ® , the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications Product Specification SR4C033-PS-1.0 Released March 2017 Page 17
SR4C033-EVB-1 价格&库存
很抱歉,暂时无法提供与“SR4C033-EVB-1”相匹配的价格&库存,您可以联系我们找货
SR4C033-EVB-1
    • 1+1245.47760
    • 200+496.95120
    SR4C033-EVB-1
    • 1+578.680791+72.37971
    库存:5
