SR42W009-U1
SR42W009-U1
    ANTENOVA(安诺亚)
    TROGONAEVALUATIONBOARD
SR42W009-U1 数据手册
Trogona Dual-Band Wi-Fi Antenna SR42W009 1. lamiiANT® Product Specification Features       Antenna for 2.4 – 2.5 GHz and 5.17 – 5.84 GHz applications: Wi-Fi 802.11a/b/g/n/ac Works over a ground plane. No clearance required. Ideal for wearables. Maintains high performance on device: DFI (Designed For Integration) SMD mounting Supplied on Tape and Reel 2. Description Trogona is intended for use with all dual-band Wi-Fi applications. Only requires a small ground plane and integrates into the corner with minimal PCB clearance area. The design is centered on being part of the device and not designing the device around the antenna. Trogona is ideal for single and MIMO antenna systems. 3. Applications         Wearable devices Access Points Portable Devices PC-cards Game Consoles Set-Top-Box Network Devices MIMO Systems Antennas for Wireless Applications Product specification SR42W009-PS-1.6 page 1 Trogona Part No. SR42W009 4. Part Number Trogona: SR42W009 5. General Data Product name Trogona Part Number SR42W009 Frequency 2.4-2.5 GHz; 5.17-5.84 GHz Polarization Linear Operating temperature -40°C to140°C Environmental Condition Test ISO16750-4 5.1.1.1/5.1.2.1/5.3.2 Impedance with matching 50 Ω Weight < 0.5 g Antenna type SMD Dimensions 19.3 x 3.3 x 4.4 (mm) 6. RF Characteristics Typical performance Peak gain 5.03dBi Average gain -1.5dBi Average efficiency >70% Maximum return loss -7.0dB Maximum VSWR 2.7:1 2.4 – 2.5 GHz frequency range All data measured on Antenova’s evaluation PCB Part No. SR42W009U1 Typical performance Peak gain 5.32dBi Average gain -2.2dBi Average efficiency >60% Maximum return loss -7.0dB Maximum VSWR 2.70:1 Conditions Conditions 5.175 – 5.835 GHz frequency range All data measured on Antenova’s evaluation PCB Part No. SR42W009U1 Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 2 Trogona Part No. SR42W009 7. RF Performance 7.1 Return Loss 5 [dB] Attune 0 -5 2 -10 1 -15 -20 -25 2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 4200 4400 4600 4800 5000 5200 [MHz] 5400 5600 5800 6000 7.2 VSWR 10 [] Atyune 9 8 7 6 5 4 3 2 2 1 2000 1 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000 4200 4400 4600 4800 5000 5200 [MHz] 5400 5600 5800 6000 Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 3 Trogona Part No. SR42W009 7.3 Antenna patterns 7.3.1 2400 MHz – 2500 MHz 3D pattern at 2.45GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 4 Trogona Part No. SR42W009 7.3.2 4900 MHz – 5900 MHz 3D pattern at 5.5GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 5 Trogona Part No. SR42W009 8. Antenna Dimensions L W H Pin 1 L W H Length Width Height 19.3 3.3 4.4 All dimensions in mm Bottom side dimensions Pin 1 4 solder pads (3.2 x 1.2 mm) Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 6 Trogona Part No. SR42W009 9. Antenna footprint The recommended host PCB footprint is below. 1 2 4 3 4 copper pads all 3.2 x 1.2 (mm) 10. Schematic The circuit for the antenna and the matching components is below. The RF feed connection and GND connections are critical to the function of the antenna, and must be followed as shown. This circuit can be used for the circuit capture of the host PCB. Pin 2 the feed is connected to Pin 1 (GND) as shown below here and is essential to the antenna function. Pi Network Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 7 Trogona Part No. SR42W009 11. Electrical Interface 11.1 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the feed. 11.2 Matching Circuit The antenna requires a matching circuit that must be optimized for each product. The matching circuit will require up to three components and the following pad layout should be designed into the device so the correct circuit can be installed. The Pi matching network must be placed close to the antenna feed to ensure it is more effective in tuning the antenna. Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 8 Trogona Part No. SR42W009 12.0 Antenna Integration Guide 12.1 Antenna Placement Whichever the host PCB size used, the antenna should be placed into the PCB corner. Ideally Pin 1 should be closest to the PCB edge. Pin 1 marker to PCB edge Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 9 Trogona Part No. SR42W009 12.2 Host PCB Layout The host PCB must ensure the footprint meets the antenna specification. An example of the PCB layout shows the antenna footprint. The antenna uses solder mask defined pads. Example host layout Below the footprint is shown again but without the solder mask. Pin 2 (feed) must be connected to pin 1 (GND) as shown here. Pin 1 joined to Pin 2 1 2 3 4 Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 10 Trogona Part No. SR42W009 13.0 Reference Board The reference board has been designed for evaluation purposes of SR42W009 and includes a SMA female connector. SR42W009-U1 Evaluation Board 46mm 40mm To order a reference board, please see www.antenova.com Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 11 Trogona Part No. SR42W009 13.1 Reference Board Matching Circuit The reference board has been designed in order to evaluate the SR42W009 and is fitted with an SMA female connector. Designator Type Value Description C1 Capacitor 1.8pF Murata GJM15 series C2 Capacitor Not fitted Not fitted L1 Inductor 1.8nH Murata LQG15HN series Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 12 Trogona Part No. SR42W009 14. Soldering This antenna is suitable for lead free soldering. The reflow profile should be adjusted to suit the device, oven and solder paste, while observing the following conditions:    The maximum temperature should not exceed 240 ºC However for lead free soldering, a maximum temperature of 255 ºC for no more than 20 seconds is permitted. The antenna should not be exposed to temperatures exceeding 120 ºC more than 3 times during the soldering process. 15. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova’s website. 16. Packaging 16.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 24 Months Storage place Away from corrosive gas and direct sunlight Reels should be stored in unopened sealed manufacturer’s plastic packaging. Packaging Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on antennas. If short term storage is necessary, then it is highly recommended that the bag containing the antenna reel is re-sealed and stored in like storage conditions as in above table. Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 13 Trogona Part No. SR42W009 16.2 Tape Characteristics Do 1.50 +0.1 Ao 3.60 ± 0.1 Bo 19.70 ± 0.1 P0 4.00 ± 0.1 E F W 1.75 ± 0.1 14.20 ± 0.1 32.00 ± 0.3 P1 8.00 ± 0.1 P2 2.00 ± 0.1 K0 5.05 ± 0.1 Dimensions in mm Notes: a) Sprocket hole pitch cumulative tolerance = ±0.2 per 10 b) Chamber not to exceed 1mm in 100mm c) Ao and Bo measured on a plane 0.1mm above the bottom of the pocket. d) K0 measured from a plane on the inside bottom of the pocket to the top surface of the carrier. Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 14 Trogona Part No. SR42W009 16.3 Reel Dimensions A C N 178.0 ± 2.0 13.2 ± 0.5 60.0 W1 14.0 All dimensions in mm Quantity 1000 pcs / reel Leading Space 16 blank holders Trailing Space 24 blank holders Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 15 Trogona Part No. SR42W009 16.4 Box Dimensions Width (W) 203mm Breadth Thickness (B) (H) 188mm 40mm 16.5 Bag Properties Reels are supplied in protective plastic packaging. 16.6 Reel Label Information Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Page 16 Trogona Part No. SR42W009 Quality statements Antenova’s products conform to REACH and RoHS legislation. For our statements regarding these and other quality standards, please see www.antenova.com. Antenna design, integration and test resources Product designers – the details contained in this datasheet will help you to complete your embedded antenna design. Please follow our technical advice carefully to obtain optimum antenna performance. It is our goal that every customer will create a high performing wireless product using Antenova’s antennas. You will find a wealth of design resources, calculators and case studies to aid your design at our website. Antenova’s design laboratories are equipped with the latest antenna design tools and test chambers. We provide antenna design, test and technical integration services to help you complete your design and obtain certifications. If you cannot find the antenna you require in our product range, please contact us to discuss creating a bespoke antenna to meet your requirement exactly. Contacts Join our online antenna design community: ask.antenova.com Order antenna samples and evaluation boards at: www.antenova.com Request a quotation for antennas by volume: sales@antenova.com Global Headquarters: Antenova Ltd, 2nd Floor Titan Court, 3 Bishop Square, Hatfield, AL10 9NA +44 (0) 1223 810600 ® ® ® ® Copyright Antenova Ltd. All Rights Reserved. Antenova , gigaNOVA , RADIONOVA , the Antenova product family names and the Antenova logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless Applications Product Specification SR42W009-PS-1.6 Released June 2015 updated Feb 2019 Page 16
SR42W009-U1 价格&库存
很抱歉,暂时无法提供与“SR42W009-U1”相匹配的价格&库存,您可以联系我们找货
