SRC5G027-U1
SRC5G027-U1
    ANTENOVA(安诺亚)
    SHARPIEVALUATIONBOARD
SRC5G027-U1 数据手册
Sharpi Wi-Fi Antenna Part No. SRC5G027 1. ceriiANT ® Product Specification Features      2. Antenna for 4.9 – 5.9 GHz applications: Wi-Fi 802.11a/h//j/n/p/ac® including vehicle to vehicle (V2X) applications Maintains high performance on device: DFI (Designed For Integration) Ultra-compact ceramic solution SMD mounting Supplied on Tape and Reel Description Sharpi is intended for use with 5G Wi-Fi applications. Only requires a small ground plane. Ideal for single and MIMO antenna systems. This product specification shows the performance of the antenna over the frequency range 4.9-5.9GHz. 3. Applications          Access Points Portable Devices PC-cards Set-Top-Box Network Devices Wearable devices V2X networks MIMO Systems IP Cameras Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 1 Sharpi Part No. SRC5G027 4. Part Number Sharpi: SRC5G027 5. General Data Product name Sharpi Part Number SRC5G027 Frequency 4.9-6.0GHz Polarization Linear Operating temperature -40°C to125°C Impedance with matching 50 Ω Weight < 0.015 g Antenna type SMD Dimensions 1.0 x 0.5 x 0.5 (mm) Footprint area 5.0 x 3.0 (mm) 6. RF Characteristics Peak gain Average gain Typical performance 3.50dBi Conditions -2.50dBi 4.9 – 5.9 GHz frequency range All data measured on Antenova’s evaluation PCB Part No. SRC5G027-U1 Average efficiency >60% Maximum return loss -6.0dB Maximum VSWR 3.0:1 Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 2 Sharpi Part No. SRC5G027 7. RF Performance 7.1 Return Loss 5 [dB] Atyune 0 -5 1 2 -10 -15 -20 -25 -30 -35 4000 [MHz] 4200 4400 4600 4800 5000 5200 5400 5600 5800 6000 6200 6400 6600 6800 7000 7.2 VSWR 12 [] Atyune 11 10 9 8 7 6 5 4 1 3 2 2 1 4000 [MHz] 4200 4400 4600 4800 5000 5200 5400 5600 5800 6000 6200 6400 6600 6800 7000 Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 3 Sharpi Part No. SRC5G027 7.3 Antenna patterns 7.3.1 4900 MHz – 5900 MHz 3D pattern at 5.46GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 4 Sharpi Part No. SRC5G027 8. Antenna Dimensions H L W L W H Length Width Height 1.0 ±0.1 0.5 ±0.1 0.5 ±0.1 All dimensions in mm 9.0 Antenna footprint The recommended host PCB footprint is below. L W P Length Width Height 0.6 0.5 1.0 All dimensions in mm Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 5 Sharpi Part No. SRC5G027 10.0 Schematic The circuit for the antenna and the matching components is below. The RF feed connection and GND connections are critical to the function of the antenna, and must be followed as shown. This circuit can be used for the circuit capture of the host PCB. A1 R1 Pi Network To RF front end A1 Antenna (SRC5G027) R1 Tuning Component Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 6 Sharpi Part No. SRC5G027 11. Electrical Interface 11.1 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the feed. 11.2 Matching Circuit The antenna requires a matching circuit that must be optimized for each product. The matching circuit will require up to three components and the following pad layout should be designed into the device so the correct circuit can be installed. The Pi matching network must be placed close to the antenna feed to ensure it is more effective in tuning the antenna. An additional tuning component is designed in to aid the tuning of the antenna. This is default not fitted. A1 R1 A1 R1 Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 7 Sharpi Part No. SRC5G027 11.3 Host PCB Layout The host PCB must ensure the footprint and clearance meets the antenna specification. The layout shown forms an integral part of the antenna, and any deviation from this will result in sub optimal performance. It is best that the copper trace layout is imported from the CAD files which are available from the Antenova website. SRC5G027 PCB layout Below shows the PCB layout without solder mask for illustration purposes only. Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 8 Sharpi Part No. SRC5G027 12.0 Antenna Placement The antenna should be placed close along the PCB edge. This is best near to the corner of the host for optimal performance. Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 9 Sharpi Part No. SRC5G027 13.0 Reference Board The reference board has been designed for evaluation purposes of SRC5G027 includes a SMA female connector. SRC5G027 Evaluation Board 25mm 30mm To order a reference board contact sales@antenova-m2m.com Please state if single or two antenna EVB is required. Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 10 Sharpi Part No. SRC5G027 14. Soldering This antenna is suitable for lead free soldering. The reflow profile should be adjusted to suit the device, oven and solder paste, while observing the following conditions:    The maximum temperature should not exceed 240 ºC However for lead free soldering, a maximum temperature of 255 ºC for no more than 20 seconds is permitted. The antenna should not be exposed to temperatures exceeding 120 ºC more than 3 times during the soldering process. 15. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. 16. Packaging 16.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 24 Months Storage place Away from corrosive gas and direct sunlight Reels should be stored in unopened sealed manufacturer’s plastic packaging. Packaging Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on antennas. If short term storage is necessary, then it is highly recommended that the bag containing the antenna reel is re-sealed and stored in like storage conditions as in above table. Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 11 Sharpi Part No. SRC5G027 16.2 Tape Characteristics Do Ao Bo 1.50 +0.1 See note See note E1 1.75 ± 0.1 E2 6.25 ± 0.1 W 8.00 ± 0.3 P0 P1 4.00 ± 0.1 K0 4.00 ± 0.1 F 1.40 ± 0.1 3.50 ± 0.05 P2 2.00 ± 0.05 G 0.75 min Notes: The cavity defined by Ao, Bo and T shall be configured to provide sufficient clearance surrounding the antenna so that: a) The component does not protrude beyond either surface of the carrier b) The component can be removed from the cavity in a vertical direction without mechanical restriction after the top cover tape has been removed c) Rotation of the component is limited to 20 degrees maximum. d) Lateral movement of the component is restricted to 0.5mm maximum. Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 12 Sharpi Part No. SRC5G027 16.3 Reel Dimensions A 330.0 ± 2.0 C 13.0 ± 0.5 N W1 60.0 8.4.0 All dimensions in mm Quantity 10,000 pcs / reel Leading Space 16 blank holders Trailing Space 24 blank holders Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 13 Sharpi Part No. SRC5G027 16.4 Box Dimensions s Width (W) 340mm Breadth Thickness (B) (H) 350mm 47mm 16.5 Bag Properties Reels are supplied in protective plastic packaging. 16.6 Reel Label Information Antenova Limited Antenova Asia Ltd 4F, No 324, Sec 1, Nei-Hu Road Nei-Hu District, Taipei 11493, Taiwan, ROC 60.00mm info@antenova-m2m.com / www.antenova-m2m.com Description: Sharpi Part number: SRC5G027 Quantity: 10,000 Date Code: YYWW Manufacturer’s code number: ceriiANT ® 90.00m m Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Page 14 Sharpi Part No. SRC5G027 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Limited nd 2 Floor Titan Court 3 Bishop Square Hatfield AL10 9NA UK Antenova Limited 100 Brush Creek Road, Suite 103 Santa Rosa California 95404 USA Antenova Asia Limited 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Tel: +44 1223 810600 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ®, the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications Product Specification Sharpi SRC5G027-PS-1.1 Release date June 2016 Page 15
SRC5G027-U1 价格&库存
很抱歉,暂时无法提供与“SRC5G027-U1”相匹配的价格&库存,您可以联系我们找货
