ISM480-EVB
ISM480-EVB
    INVENTEKSYSTEMS
    EVALBOARDFORISM480F1-C4.1
ISM480-EVB 数据手册
INVENTEK SYSTEMS, LLC. ISM420/480 Evaluation Board Users Guide Revision 0.3 Stephen Profit 5/26/2011 This document describes the Inventek Systems ISM420/480 Evaluation Board. DOC-UG-20009-0.2 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 1 Table of Contents 1 Table of Contents .................................................................................................................................. 2 2 Revision History .................................................................................................................................... 3 3 Introduction .......................................................................................................................................... 4 3.1 Block Diagram ............................................................................................................................... 4 3.2 Diagrams ....................................................................................................................................... 5 4 Features ................................................................................................................................................ 6 5 Switches, Connectors, and Jumpers ..................................................................................................... 7 6 Operating Modes .................................................................................................................................. 9 6.1 Normal Operation ......................................................................................................................... 9 6.2 ISM480 GPS Module Firmware Update ........................................................................................ 9 6.3 EVB Board Firmware Update ........................................................................................................ 9 6.4 SiRFLive Mode ............................................................................................................................. 10 Inventek Systems, LLC. Page 2 of 11 DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 2 Revision History Date 1/10/2011 1/26/2011 5/3/2011 5/26/2011 Inventek Systems, LLC. Author Stephen Profit Stephen Profit Stephen Profit Stephen Profit Version 0.0 0.1 0.2 0.3 Page 3 of 11 Comments 1st Draft Corrections and added SiRFLive mode Updates Updates and Diagrams DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 3 Introduction The Inventek Systems ISM420/480 Evaluation Board (EVB) allows the user to evaluate the either of the ISM420 GPS module using the ISM420 Breakout Board or the ISM480 GPS module. The Evaluation board can be configured for:   NMEA Messages For direct connection to the GPS module for use with SiRFLive software 3.1 Block Diagram LCD 2 x16 Buttons ISM420 Socket STM32 TX RX DB-9 Inventek Systems, LLC. IPEX 1x12 Page 4 of 11 DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 3.2 Diagrams LCD 2 x16 LCD 2 x16 J3106 J3106 1 1 SW3100 J3100 SW3101 SW3102 SW3103 SW3100 J3100 J3202 J3203 1 IPEX 1x12 SW3103 1 Inventek Systems ISM420-EVB 1 IPEX 1x12 DB-9 Flex Cable DB-9 SW3102 J3202 J3203 1 Inventek Systems ISM480-EVB SW3101 ISM480F1 ISM480EVB TOP VIEW 1 1 1 ISM420EVB TOP VIEW J3104 1 J3105 1 J3201 ISM420-INT 1 1 J3104 J3105 J3201 ISM420 DB-9 Flex Cable DB-9 IPEX 1x12 ISM480EVB BOTTOM VIEW Inventek Systems, LLC. ISM420EVB BOTTOM VIEW Page 5 of 11 DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 4 Features    Supports both the ISM420R (ROM Version) and the ISM480F (Flash version) GPS modules. Display o Lat/Lon o UTC, Satellites, HDOP o Altitude, GeoID o Speed, Distance (for future use, currently always displays zero) Supports SiRF Flash utility for use on the ISM480F module for upgrading to the latest firmware. Inventek Systems, LLC. Page 6 of 11 DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 5 Switches, Connectors, and Jumpers SW3100 Switch Function Power ON/OFF Comments Not used due to errata SW3101 Event Switch Use to switch display SW3102 MCU Reset SW3103 GPS ON/OFF Use only if the MCU is not responding Use when updating ISM480TM module firmware Jumper J3101: Power button bypass Function Open: Normal operation Closed: Bypass button Open: No connect Closed: 32kHz to ISM420 Open: No connect Closed: 32kHz to ISM480TM Open: No connect Closed: 32kHz to ISM480TM Open: No connect Closed: Ext. 32kHz to ISM480TM Open: Normal operation Closed: Hold MCU in Reset Open: No connect Closed: Pull high Open: No connect Closed: Pull low Open: SPI mode Closed: UART mode J3104, 1-2: 32kHz Select J3104, 2-3: J3105, 1-2: 32kHz Select J3105, 2-3: J3106: MCU Reset J3201, 1-2: Flash Enable J3201, 2-3: J3203: GPS Mode Jumper J3202, 1-22: GPS On/Off J3202, 2-21: GPS RxD J3202, 3-20: SPI Clock J3202, 4-19: SPI CS J3202, 5-18: GPS TxD Inventek Systems, LLC. Function Open: Controlled by SW3103 Closed: Controlled by MCU Open: No connect Closed: Connect to MCU/DB9 Open: No Connect Closed: Connect to MCU Open: No connect Closed: Connect to MCU Open: No connect Closed: Connect to MCU/DB9 Page 7 of 11 State Default Default Default Default Default Default Default Default Default State Default Default Default Default Default DOC-UG-20009-0.3 Inventek Systems, LLC. J3202, 6-17: GPS Reset ISM420-480TM Evaluation Board Users Guide Revision 0.3 Open: No connect Closed: Connect to MCU Open: No connect Closed: Connect to MCU Open: No connect Closed: Connect to MCU Open: No connect Closed: Connect to MCU Open: No connect Closed: Connect to 32kHz Open: No connect Closed: Connected to GND Default J3100 Function External Power J3200 To ISM480TM J3204 Misc UART Comments Pin 1: 3.0VDC Pin 2: GND Note: fingers of flex cable face down Not used J3107 GPS UART Note: signals are 3.0V TTL J3108 MCU Debug J3109 MCU JTAG J3202, 7-16: Flash Enable J3202, 8-15: GPS Wakeup J3202, 9-14: GPS GPIO3 J3202, 10-13: Remote 32kHz J3202, 11-12: ISM480TM GND Connector Inventek Systems, LLC. Page 8 of 11 Default Default Default Default Default DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 6 Operating Modes 6.1 Normal Operation      Default settings Connect GND to J3100, pin 2 Connect 3.0V to J3100, pin 1 Apply power, after a few seconds the display will show “Inventek Systems” and once the broad has been completely setup the display will show “Waiting for fix NMEA” Once a fix is obtained the display will show the current Latitude and Longitude, press SW3101 to change the display. 6.2 ISM480 GPS Module Firmware Update          From default setting o Open J3202, 1-22 o Close J3106, 1-2 o CloseJ3201, 1-2 Attach the USB2DB9 adaptor to J3107 Attach the USB2DB9 Mini-USB to a PC (Driver will install on 1st connection) Attach GND and 3.0V Press and release SW3103 to turn ON the GPS module Start SiRFflash utility version 4.02 or later. Select the COM port of the USB2DB9 adaptor Browse for the firmware file Press execute 6.3 EVB Board Firmware Update       Attached JTAG adaptor board Attached ST-Link to JTAG adaptor board Attached ST-Link to a PC Attach GND and 3.0V Open TA board IAR workspace Select Project > Download > Download file o Browse and select latest firmware file (.out) Inventek Systems, LLC. Page 9 of 11 DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 6.4 SiRFLive Mode      From default setting o Open J3202, 1-22 o Close J3106, 1-2 o CloseJ3201, 1-2 Attach the USB2DB9 adaptor to J3107 Attach the USB2DB9 Mini-USB to a PC (Driver will install on 1st conection) Attach GND and 3.0V Press and release SW3103 to turn on the GPS module Inventek Systems, LLC. Page 10 of 11 DOC-UG-20009-0.3 Inventek Systems, LLC. ISM420-480TM Evaluation Board Users Guide Revision 0.3 Inventek Systems, LLC. 2 Republic Road Billerica Ma, 01862 978-667-1962 Email: sales@inventeksys.com www.inventeksys.com Inventek Systems reserves the right to make changes without further notice to any products or data herein to improve reliability, function, or design. The information contained within is believed to be accurate and reliable. However Inventek Systems does not assume any liability arising out of the application or use of this information, nor the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. Inventek Systems, LLC. Page 11 of 11 DOC-UG-20009-0.3
ISM480-EVB 价格&库存
很抱歉,暂时无法提供与“ISM480-EVB”相匹配的价格&库存,您可以联系我们找货
