113990017
113990017
    SEEED(矽递科技)
    315MHZ RF LINK KIT
113990017 数据手册
    315Mhz RF link kit  SKU 113990017    Description  The kit is consisted of transmitter and receiver, popular used for remote control.     Usage  The popular link is like this: MCU ‐> Encoder ‐> Transmitter ‐‐‐‐‐‐ Receiver ‐> Decoder ‐> MCU,   PT2262(Encoder) and PT2272(Decoder) are optional, their existence is to 1)avoid confusing when  multiple RF links in range 2) isolate disturbance. You can integrate the encoding and decoding  work to the MCUs on both side. Whenever there is no 315Mhz devices around, you may use it as  direct cable connection.  Excuse  for  the  documentation,  we  will  work  on  them.  Before  that,  please  consult  us  for  any  details, we are happy to find the answer for you .We tried them using the guide from Sparkfun,  it's compatible. The only difference is in package, of some excess GND pins.    Technical Details  Dimensions 60mm x 40mm x 7.50mm  Weight  G.W 5g      Battery  Exclude  Frequency  315Mhz  Modulation  ASK  Receiver data output  High ‐ 1/2 Vcc, Low ‐ 0.7v  Transmitter input voltage  3‐12V (high voltage = more transmitting power)  Transmitting range (work at 5V)  40m indoor, and 100m in open air    Part List  Receiver Module 1  Transmitter Module  1    ECCN/HTS    ECCN 5A991.b  HSCODE  8517709000                                         https://www.seeedstudio.com/315Mhz‐RF‐link‐kit‐p‐76.html/12‐6‐18
113990017 价格&库存
很抱歉,暂时无法提供与“113990017”相匹配的价格&库存,您可以联系我们找货
  • 10000+43.0773010000+5.58002
