JN3-B3EV-LT
JN3-B3EV-LT
    TELITWIRELESSSOLUTIONS(泰利特)
    BOARD EVAL FOR JUPITER JN3
JN3-B3EV-LT 数据手册
JUPITER JN3 GPS Embedded JUPITER SE880 GPS 12.2 mm JUPITER SL8 GNSS Embedded Embedded 2.4 mm 16 mm Product Description The JN3 is the companion module to JF2. It employs LCC packaging and a 3 V power supply and is interoperable with Telit cellular modules providing ready-to-use solution bundles at no additional integration effort or cost. This feature is particularly evident when integrating with the GL865 family of sub-compact LCC cellular modules. The JN3 is also designed to be a low-cost, drop-in replacement for the SL869 when multi-constellation support is not required. It supports A-GPS injection as well as A-GPS onboard generation. The A-GPS integration effort is negligible when JN3 is bundled with a Telit module. Key Features • Based on the SiRFstarIVTMcore JUPITER SL871 • GNSS supported: GPS L1 • 16 x 12.2 x 2.4 mm LCC package • Flash, EEPROM or ROM based versions • Supply voltage range: 2.9 - 3.6 VDC • GNSS Very lowEmbedded power consumption • Assisted GPS • High RF sensitivity with jamming detection and removal • Ports: 1PPS, UART • Compatible with the SL869 and popular 12 x 16 mm footprint industry standard Key Benefits • Supports A-GPS using Extended Ephemeris injection as well as Extended Ephemeris on-board generation for fastest TTFF • Easy integration in cellular/GNSS bundle solutions combined with Telit cellular modules • LCC package allows manual soldering/rework ENABLING THE IOT IS WHAT WE DO. • Pin-to-pin compatibility with SL869 allows customers to dial in their desired GNSS capabilities with low-end (GPS only) and high-end (GPS+Glonass+Galileo +QZSS) vari ants using the same motherboard Family Concept Our positioning product portfolio is the result of over twenty years of experience in GNSS applications. Telit has developed a range of products compatible with the wellknown GNSS constellation as well as its Russian counterpart GLONASS. Moreover, our portfolio is fully aligned with the upcoming service launch of Europe’s Galileo constellation. Valuable features such as Dead Reckoning, Precision Timing, as well as speed and reliability assured by multiconstellation coverage, provide additional benefits for your application. Your application development effort can also benefit significantly from the seamless integration between Telit’s cellular and positioning modules. This bundling of cellular and positioning modules significantly reduces development complexity without adding costs. Multi-constellation positioning products applied together with our eCall/ERAEmbedded GNSScompliant GLONASS cellular modules bring you readyto-use emergency automotive tracking solutions for the European and Russian markets. JUPITER SE873 Typical applications include fleet management systems, European GPS-assisted road tolling systems, cellular base stations, in-car navigation systems, automotive telematics systems, and GPS-based personal sports training monitors. Combine your GNSS module with Cellular modules Short Range modules www.telit.com JUPITER SC8 GNSS Embedded JUPITER JN3 Product Features Interfaces • Frequency Band: GPS L1 Band, C/A Code • UART, I2C (only for MEMS) interfaces • Standards: NMEA and OSP • PPS for precise timing • 48 Channel GPS architecture • EGNOS, WAAS, GAGAN and MSAS capability embedded with correction of positional errors due to ionospheric and orbital disturbances • Positional Accuracy (CEP50): Autonomous Positional Error ‹ 2.5 m • Accuracy - Speed: ‹ 0.01 m/s - Heading: ‹ 0.01 deg • RTC for efficient power management • Time To First Fix (90% @ -130 dBm) - Hot Start: 1 s - Cold Start: ‹ 35 s Electrical & Sensitivity • A-GPS: server predicted ephemeris file injection • Current consumption - Hibernate mode: 40 uA - Low power mode (Tracking 1Hz): 10 mA - Full power Tracking: 32 mA Environmental • Flexible power supply - Range from 2.85 up to 3.6 V • Dimensions: 16 x 12.2 x 2.4 mm • Sensitivity - Acquisition: -147 dBm - Navigation: -160 dBm - Tracking: -163 dBm • A-GPS: local ephemeris prediction • Weight: 1.8 g • 24-pad LCC package, requiring only 2 Layer PCB [07.2015] • Temperature Range - Operating temperature: -40 to +85°C - Storage temperature: -40 to +85°C Telit reserves all rights to this document and the information contained herein. Products, names, logos and designs described herein may in whole or in part be subject to intellectual property rights. The information contained herein is provided “as is”. No warranty of any kind, either express or implied, is made in relation to the accuracy, reliability, fitness for a particular purpose or content of this document. This document may be revised by Telit at any time. For most recent documents, please visit www.telit.com Copyright © 2015, Telit * Copyright © 1990-2015, Python Software Foundation Telit Communications S.p.A. Via Stazione di Prosecco, 5/B I-34010 Sgonico (Trieste), Italy Phone +39 040 4192 200 Fax +39 040 4192 383 E-Mail EMEA @ telit.com Telit Wireless Solutions Inc. 3131 RDU Center Drive, Suite 135 Morrisville, NC 27560, USA Phone +1 888 846 9773 or +1 919 439 7977 Fax +1 888 846 9774 or +1 919 840 0337 E-Mail NORTHAMERICA @ telit.com Telit Wireless Solutions Inc. Rua Paes Leme, 524, Conj, 126 05424-101, Pinheiros São Paulo-SP-Brazil Phone +55 11 3031 5051 Fax +55 11 3031 5051 E-Mail LATINAMERICA @ telit.com Join the Telit Technical Forum For a quicker and more rewarding integration experience join the Telit Technical Forum. There you can browse the first open forum covering all IoT topics, get direct support by region (EMEA, North America, Latin America, APAC), take part in this quickly growing IoT community and exchange experiences. Telit Wireless Solutions Co., Ltd. 8th Fl., Shinyoung Securities Bld. 6, Gukjegeumyung-ro8-gil, Yeongdeungpo-gu Seoul, 150-884, Korea Phone +82 2 368 4600 Fax +82 2 368 4606 E-Mail APAC @ telit.com www.telit.com www.telit.com/techforum www.telit.com/facebook www.telit.com/twitter
JN3-B3EV-LT 价格&库存
很抱歉,暂时无法提供与“JN3-B3EV-LT”相匹配的价格&库存,您可以联系我们找货
