ISM43341-L77-EVB
ISM43341-L77-EVB
    INVENTEKSYSTEMS
    EVALBOARDFORISM43341-L77
ISM43341-L77-EVB 数据手册
ISM4334x-L77-EVB User’s Guide ISM43341-L77 EVB Wi-Fi, Bluetooth and NFC Radio Only Evaluation Board User’s Manual DOC-DS-20095 www.Inventeksys.com Page 1 Inventek Systems ISM4334x-L77-EVB User’s Guide 1 General Description The Inventek ISM43341-L77 is a single-chip quad-radio device that provides the highest level of integration for a wireless system, with integrated dual band (2.4 GHz/ 5 GHz) IEEE 802.11 a/b/g/n /baseband/radio. In addition to Wi-Fi, the chip also provides Bluetooth 4.0, and a low power NFC controller. The ISM43341-L77-EVB is a radio only solution that is ideal for integration with a single board computer running Linux. The evaluation board plugs directly into an SDIO/MicroSD slot and can be used with an ARM or x86 host processor running Linux Kernel 3.10 or later. Inventek Systems provides Wi-Fi and Bluetooth drivers for several different platforms. Hardware Features:         Uses Broadcom BCM43341/0 802.11 a/b/g/n Wi-Fi Radio Bluetooth 4.0 including BLE support. Near Field Communication (NFC option) 2.4 & 5 GHz chip antenna for Wi-Fi and Bluetooth . o U.FL Connector for external antenna Host interfaces: o SDIO: WiFi o UART: Bluetooth o I2C/UART/SPI: NFC Input Power: 3.3 V Dual port FTDI for NFC and Bluetooth HCI over USB FCC and CE approval 2 Part Number Detail Description ISM43341-L77-EVB Wi-Fi, Bluetooth, and NFC On board Antenna ISM43341-L77-EVB Wi-Fi, Bluetooth, NFC On board Antenna 3 Additional Documentation   ISM43340/1-L77 Functional Specification ISM4334x-L77_EVB_iMX6_Quick_Start_Guide_R3_AN20093 DOC-DS-20095 www.Inventeksys.com Page 2 Inventek Systems ISM4334x-L77-EVB User’s Guide 4 ISM4334x-L77-EVB Architecture 4.1 Powering the Board Two power connections are necessary to power the module:   VBAT VIO VBAT must be 3.3V, while VIO can range from 1.8 V to 3.3V. When using the ISM43341-L77-EVB, Inventek recommends connecting VIO and VBAT. DOC-DS-20095 www.Inventeksys.com Page 3 Inventek Systems ISM4334x-L77-EVB User’s Guide 4.1.1 Power Though SDIO   Place a jumper on J25, to connect VBAT and VIO. Place a jumper between pins 2 and 3 on J20, to tie VBAT to SDIO voltage supply. 4.1.2 External Power   Place a jumper on J25, to connect VBAT and VIO. Connect and external 3.3V Supply. Pin 2 on J20, is power. Pin 2 on J18 is GND. 5 Schematic 5.1 Radio, Power, & RF DOC-DS-20095 www.Inventeksys.com Page 4 Inventek Systems ISM4334x-L77-EVB User’s Guide 5.2 Host Interface Headers, Regulator and Config Switches 5.3 FTDI & NFC EEPROM DOC-DS-20095 www.Inventeksys.com Page 5 Inventek Systems ISM4334x-L77-EVB User’s Guide 6 Revision Control Document : ISM4334xC-Shield External Release Date 2/24/2016 Author KMT Wi-Fi module DOC-DS-20095 Revision 1.0 Comment Preliminary Release 7 CONTACT INFORMATION Inventek Systems 2 Republic Road Billerica MA, 01862 Tel: 978-667-1962 Sales@inventeksys.com www.inventeksys.com Inventek Systems reserves the right to make changes without further notice to any products or data herein to improve reliability, function, or design. The information contained within is believed to be accurate and reliable. However Inventek Systems does not assume any liability arising out of the application or use of this information, nor the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. DOC-DS-20095 www.Inventeksys.com Page 6 Inventek Systems
ISM43341-L77-EVB 价格&库存
很抱歉,暂时无法提供与“ISM43341-L77-EVB”相匹配的价格&库存,您可以联系我们找货
