ISM43362-L36-EVB-U
ISM43362-L36-EVB-U
    INVENTEKSYSTEMS
    EVAL BOARD FOR ISM43362-L36-U
ISM43362-L36-EVB-U 数据手册
Product Brief Inventek eS-WiFi Family Embedding Connectivity Everywhere ISM43362-L36 Wi-Fi 802.11b/g/n Module SDIO Interface…Linux...Android...Virtual WICED The Inventek ISM43362-L36 is an 802.11 b/g/n WiFi Radio SiP with on board antenna or optional external antenna with a U.FL connector, which is designed for embedded wireless solutions and offers a cost-effective high performance Broadcom radio device (BCM43362) packaged in an 36 pin LGA (24.4mm x 15.3 mm). It includes standards-based wired and wireless technologies to enable IP infrastructures for smart grid, smart home, security, building automation, toys, robots, remote health and wellness monitoring and other IoT and M2M applications. The module is based on IEEE802.11 b/g/n antenna single-stream align technology. The solution is FCC/IC/CE certified and helps to reduce development time, lower manufacturing costs, save board space, and ease certification Main Features  802.11 b, g ,n compliant based on Broadcom MAC/Baseband/Radio device  FCC and Ce certified in process  IEEE 802.11 b/g/n complaint  Soft Access Point for up to 7 clients for  Host interface: SDIO  Network features ICMP ( Ping), ARP, DHCP,TCP, UDP  Low power operation (3.3V supply)  Secure Wi-Fi authentication WEP-128, WPA-PSK (TKIP), WPA2-PSK configuration and ad-hoc networks Www.Inventeksys.com Embedding Connectivity Everywhere Product Brief Inventek eS-WiFi Family Embedding Connectivity Everywhere Application Examples  Warehousing, logistics and freight management  PDA, Pocket PC, computing devices  Building automation and smart energy  PC and gaming peripherals control  Printers, scanners, alarm and video  systems Industrial sensing and remote equip ment monitoring Medical applications including patient monitoring and remote diagnostics Network Standard RF Frequency Configuration Supply Voltage Package Operating Temperature IEEE 802.11b/g/n 2.400 GHz ~ 2.497 GHz 802.11n: 6.5, 13, 19.5, 26, 39, 52, 58.5, 65 Mbps 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11b: 1, 2, 5.5, 11 Mbps 802.11g/n: OFDM /64-QAM,16-QAM, QPSK, BPSK 802.11b: CCK, DQPSK, DBPSK WEP (64/128-bit),WPA™ (PSK, TKIP) / WPA2™ (AES, CCMP, 802.1x Authentication) SDIO TCP, UDP, IPv4, ARP, ICMP, DHCP Client Power save modes, automatic roaming, auto-rate Ad-hoc and Infrastructure modes WICED, Linux, Android 3.3V ± 5% 36-pin LGA, 14.5mm x 30 mm -35°C to +80°C Certifications FCC and CE Data Rates Modulation Techniques Wireless Security Host Interface Network Protocols WLAN Functions Device ISM43362-L36-E ISM43362-L36-U ISM43362-L36-EVB Contact Inventek Systems 2 Republic Road Billerica Ma 01862 978-667-1962 Www.Inventeksys.com Description 802.11 SiP Module based on Broadcom BCM43362 with on board etch antenna 802.11 SiP Module based on Broadcom BCM43362 with U.FL connector for external antenna SDIO Evaluation Board E-mail Sales@Inventeksys.com Engineering@Inventeksys.com www.Inventeksys.com Embedding Connectivity Everywhere Ordering Number ISM43362-L36-E ISM43362-L36-U ISM43362-L36-EVB
ISM43362-L36-EVB-U 价格&库存
很抱歉,暂时无法提供与“ISM43362-L36-EVB-U”相匹配的价格&库存,您可以联系我们找货
