GS-AEK-VIDEOGEO1080P
    GAINSPAN
    KITAEK1080PH264MAX64380W/HW
GS-AEK-VIDEOGEO1080P 数据手册
T BRIEF PR O D UCT B RI E F - P RE LIM IN AR Y GS2011M Full HD Video Battery Powered Application Development Kit PRODUCT OVERVIEW GainSpan Full HD Video ADK is a development platform enabling customers to build Wi-Fi IP video streaming applications with excellent video quality. By integrating the major hardware and software components for Wi-Fi IP camera solution, this platform facilitates fast time to market for customer projects. Targeted applications for this platform include Wi-Fi IP cloud cameras, baby monitors, toy cameras, automotive backup / drive recorder cameras and variety of other systems where customer would like to add IP video streaming functionality. This platform also integrates key functionality for battery powered operation for the camera. GEOSEMI FULL HD IP CAMERA ADK FEATURES The following Full HD ADK ADK features include the following:  GS2011MIZ module with extremely low power IEEE 802.11b/g/n compliant module meeting worldwide regulatory and Wi-Fi Alliance certification requirements. APPLICATIONS:  Battery powered IP cloud cameras  Line powered IP cloud cameras  Baby monitors  Toy cameras  Automotive backup/drive recorder cameras WIFI CONNECTIVITY:  GS2011MIZ module IEEE 802.11b/g/n connectivity with PHY rates up to 72Mbps  Full HD (1920 x 1080 pixels) resolution with Geo Semiconductor H.264 encoder  In-home streaming via access point  Limited AP, Wi-Fi Direct with concurrent mode, WPS2.0  Mobile applications from Geo Semiconductor  SPI interface to H.264 encoder  Battery powered reference design with charging circuit   Security: 802.11i, WPA/2-Personal and Enterprise, legacy WEP, TLS Planned support for:  Fast boot up, low power operation and low standby current  Streaming to the cloud through an access point or a custom gateway  Uploading to cloud and storage in the cloud STREAMING PROTOCOLS:  Power saving mode implementation for long battery life designs  UDP/TCP streaming  2-way audio for communication with a smartphone  RTP/RTSP streaming for Audio/Video ADDITIONAL GEO SEMI ENCODERS:  Raptor 2 (with geometric correction) APPLE AUTHENTICATION COPROCESSOR:  Apple authentication co-processor for Wi-Fi config HOSTED SYSTEMS:  For addition of video functionality to existing embedded systems, GainSpan ADK implements simple AT commands and Serial-to-Wi-Fi connectivity over UART . PR O D UCT B RI E F - P RE LIM IN AR Y USE CASES GainSpan Full HD ADK enables multiple use cases over Wi-Fi technology. EMBEDDED SOFTWARE:  WLAN o MCS 0 – 7 data rates; STBC o 802.11 Security: WPA / WPA2 enterprise and personal security modes IN-HOME STREAMING  Full implementation of TCP / IP networking stack STREAMING TO THE CLOUD (PLANNED SUPPORT) o IPv4 / IPv6 support o HTTP1.1 Web Server or Client o HTTP POST / GET / Response codes o Application security (TLS 1.0, TLS 1.2) o mDNS Discovery o RTP / RTSP streaming o UDP streaming  Multiple Wi-Fi modes o Limited AP o Station o Limited AP concurrent o Wi-Fi Direct  Multiple Provisioning Methods DEVELOPMENT KIT SYSTEM COMPONENTS GainSpan Full HD Video ADK comprises of the following components: WPS Provisioning o Wireless AP Provisioning o QR Code Provisioning o Group Provisioning on Android devices  Over-the-Air Firmware Update o  GS2011MIZ: GainSpan GS2011MIZ features low power battery applications  MAX64380: Geo Semi H.264 encoder (Raptor) and AACLC encoder supporting Full HD 1080 pixels 30 resolution video  o MAX9860: Low-power, voice band, mono audio codec; ADC and DAC supporting sample rates of 8kHz to 48kHz  MAX9300: Mono 2.6W Class D amplifier  Apple authentication co-processor Wireless update of the host code  Video Encoding o H.264 encoding up to 1080p30 resolution MOBILE APPLICATION:  iOS and Android application from Geo Semiconductor  Notification from cloud on doorbell press  mDNS Discovery for local cameras CLOUD CONNECTIVITY (PLANNED SUPPORT)  Cloud streaming services  Cloud storage Copyright © 2014 GainSpan Corporation. All Rights Reserved. info@gainspan.com www.gainspan.com GS2011M-VID-ADK-PB-00108 Release 0.1 PR O D UCT B RI E F - P RE LIM IN AR Y GAINSPAN FULL HD ADK BLOCK DIAGRAM GAINSPAN GS2011MIZ/MIE MODULE SPECIFICATIONS Components Description Radio Protocol IEEE 802.11b/g/n Pin Count 49 pins RF Output Power (Typical) +15dBm (802.11b), +11dBm (802.11n) Rx Sensitivity -95dBM Wake from Standby Time 1ms (1 millisecond) RF Operating Frequency 2.4 – 2.495GHz Supported Data Rates 72, 65,58,43,29,22,14,7 Mbps (802.11n), 54, 48, 36, 24, 18, 12, 9, 6 Mbps (802.11g) 11, 5.5, 2, 1 Mbps (802.11b) Antenna Options External antenna (u.FL connector) or Internal PCB trace antenna Operating Temperature -40 to +85 C Security Protocols WPA/WPA2-Personal, WPA/WPA2-Enterprise (PEAP, EAP-FAST, EAP-TLS, EAPTTLS), WEP, TLS/SSL Client and Server, HTTPs Networking Protocols TCP, UDP, IPv4, IPv6, TLS Client/Server, SNTP client, DHCP Client/Server v4, DHCP Client/Server v6, DNS Client and Server, mDNS, DNS-SD, HTTP Client/Server, and XML Parser Certifications and Compliance FCC, IC, TELEC, ETSI, RoHS, Wi-Fi Certified, Wi-Fi Direct, WPS 2.0, SEP 2.0 I/O Interfaces SPI, UART, SDIO, I C, I S, GPIO, ADC (12.bit), JTAG Host Connections SPI, UART, SDIO (typically to an external microcontroller) Internal Flash 4MB Outline Dimensions 22.8mm x 32.5mm x 3.63mm (shield) I/O Voltage 2.7-3.6V Operating Voltage 2.7-3.6V VBAT 1.6-3.6V o o 2 2 Copyright © 2014 GainSpan Corporation. All Rights Reserved. info@gainspan.com www.gainspan.com GS2011M-VID-ADK-PB-00108 Release 0.1 PR O D UCT B RI E F - P RE LIM IN AR Y GAINSPAN / GEO FULL HD VIDEO ADK ORDERING INFORMATION ITEM GainSpan Full HD Video ADK GainSpan Full HD Video AEK PART NUMBER GS-ADK-VideoGeo1080p GS-AEK-VideoGeo1080p Description GainSpan / Geo Full HD Video Application Development Kit GainSpan / Geo Full HD Video Application Evaluation Kit GAINSPAN / GEO HD VIDEO ADK ORDERING INFORMATION ITEM GainSpan HD Video ADK GainSpan HD Video AEK PART NUMBER GS-ADK-VideoGeo720p GS-AEK-VideoGeo720p Description GainSpan / Geo HD Video Application Development Kit GainSpan / Geo HD Video Application Evaluation Kit Copyright © 2014 GainSpan Corporation. All Rights Reserved. info@gainspan.com www.gainspan.com GS2011M-VID-ADK-PB-00108 Release 0.1
GS-AEK-VIDEOGEO1080P 价格&库存
很抱歉,暂时无法提供与“GS-AEK-VIDEOGEO1080P”相匹配的价格&库存,您可以联系我们找货
