CC-WMX53-ANDRD
CC-WMX53-ANDRD
    DIGIINTERNATIONAL
    RF EVAL CONNECTCORE FOR IMX53
CC-WMX53-ANDRD 数据手册
Feature Spec Digi® Application Development Kit for Android™ Integrated Android Application Development for Embedded Systems Overview Android is an ideal software platform to create professional and feature-complete products with significantly reduced software development effort and improved overall time-to-market. The Digi Application Development Kit for Android builds on the strong Android software foundation and its rich eco-system by providing a complete and easy-to-use Android application development solution that is designed to meet the specific needs of embedded developers. About the App Kit Ready to use right out of the box, the kit includes the Android development tools, Android platform, Digi software and API extensions, the Eclipse-based Digi ESP™ IDE, development board with ConnectCore® for i.MX module, 7” WVGA LCD panel with touch screen, and documentation. The Digi software and API extensions also provide abstracted access to embedded peripherals and interfaces that are typically not available as part of the standard Android framework, including interfaces such as I2C and SPI. In addition, the Digi Application Development Kit for Android also implements fully transparent support for Ethernet and Wi-Fi network connectivity as well as seamless Digi Device Cloud support for Android applications. The software support for the hardware capabilities of Digi’s ConnectCore for i.MX module family combined with the Digi extensions for Android enable customers to design Android based products without the typically complex and often difficult low-level system development effort. Whether you want to evaluate Android as a software platform or have already decided to build an Android based product solution, the Digi Application Development Kit for Android provides a unique and true turnkey solution enabling you to immediately start your embedded Android software development. Features/Benefits Ready-to-use embedded Android application development solution • Complete set of integrated Android tools, platform software components and hardware • Highly accelerated and efficient application development can begin immediately Fully integrated and optimized support for Digi embedded hardware platforms • • Customer focus on core product competency No low-level system development effort unless custom hardware component support required Digi is the single point of contact for hardware and software support • Eliminates time-consuming and inefficient interaction with multiple vendors Optional software and hardware design services available • Professional custom software and hardware design services offered through Digi and Embedded Development Partners for reduced design risk and improved time-to-market As part of the solution, Digi offers complete expert hardware and software technical support, effectively eliminating the typically time-consuming and inefficient interaction with multiple vendors. Working with a single source reduces your design risk and keeps your projects on track. Digi and its Embedded Development Partners also provide professional hardware and software services for any of your project specific custom design needs. www.digi.com General Supported Capabilities Boot Loader • Android Platform - Gingerbread 2.3.4 • Android Development Tools - Version 14.0 • Digi ESP Eclipse Environment - Version 3.5.1 • Supported Development Platforms - Microsoft Windows XP/Vista/7 - Linux • Standard Emulator support • Kernel and rootfs customization option - Available on Linux hosts • Ethernet (single) • 802.11a/b/g/n Wi-Fi • VPU/GPU (2D/3D) - With hardware video codec integration • IPU - Single screen support • Camera - Single camera support • Monitor - VGA/HDMI HDMI: Up to 1920x1080 on CC for i.MX53 HDMI: Up to 1366x768 on CC for i.MX51 • TFT Panels (Parallel/LVDS) - Sharp® LQ070Y3DG3B, LQ121K1LG52 - Hannstar HSD101PFW2 - Fusion™ 10 Touch Display - Customer-specific displays • Touch screen - On-module controller • USB Host - Keyboard, mouse • USB OTG • SD/Micro SD • UART • SPI • I2C • Audio - Playback and Recording • User Buttons and LEDs • Accelerometer - Freescale MMA7455L • Power Management - Suspend/Resume/Power Off • Battery power support • Serial console (system logging) • Custom splash screens • Automatic user app launch • U-Boot - Dual-boot capabilities - Boot via on-module flash, SD, USB, Ethernet - Robust NVRAM system configuration storage with redundant image option - Fusebox (eFuse) configuration - Flash partitioning command option - Digi command extensions - Fully integrated in build environment - Graphical configuration tool Digi ESP™ • • • • • • Based on Eclipse 3.5.1 and ADT 14.0 Digi sample code and API extensions CVS source code management support Visual source code debugging via Ethernet Online help and cheat sheets Digi Package Manager for online updates and software/documentation distribution Digi Cloud Connector • Fully integrated and seamless Digi Device Cloud support for Android applications. File Systems User Documentation • Getting Started Guide - How to build your first Android application • Digi API Extensions - Documentation of Digi API Extensions • Digi ESP Users Guide • Hardware reference manuals - Technical reference information • U-Boot reference manual Target Platforms • ConnectCore® for i.MX51 • ConnectCore® for i.MX53 • NAND Flash (On-Module) - UBIFS High-performance large volume journaling flash file system with compression • External SD Card - Ext3/Ext4 High-performance large volume journaling flash file systems with low fragmentation Digi Sample Code • GPIO • I2C • SPI • Serial Port • OpenGL • Audio Player • Video Player • Camera • Device Cloud © 2012-2014 Digi International Inc. Digi, Digi International, the Digi logo, ConnectCore, Digi ESP and Digi Device Cloud are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. ARM and NET+ARM are trademarks or registered trademarks of ARM Limited. All other trademarks are property of their respective owners. All information provided is subject to change without notice. 91001904 A3/315
CC-WMX53-ANDRD 价格&库存
很抱歉,暂时无法提供与“CC-WMX53-ANDRD”相匹配的价格&库存,您可以联系我们找货
