MB-16
MB-16
    TWIN
    RF EVAL FOR SP4E TUNABLE FILTERS
MB-16 数据手册
MicroAmp MB-16 Circuit Board For Hittite Tunable Filters in SP4E Packages FEATURES • Fits Hittite Microwave tunable filters with LP4E packages • Usable with HMC895-898 tunable bandpass filters • Uses standard SMD passive parts • RO-4350 board material • Fits MicroAmp MH-series housings The MicroAmp MB-16 circuit board is designed for rapid prototyping of tunable bandpass filters using Hittite Microwave devices in LP4E packages with RF inputs on pin 3, RF outputs on pin 16, and control connections on pins 8-10. Filter MMICs are available at various frequencies throughout the 6.8 to 21 GHz range. This board will fit the MicroAmp MH series of connectorized housings that allow it to be used as a stand-alone multiplier or cascaded with other MicroAmp boards for added versatility. Boards are fabricated from a high-performance 13 mil thick RO-4350 laminate with RoHS compatible ENIG plating (electroless nickel/immersion gold) on both the component side and the solid bottom ground plane. The board measures 0.490" x 0.590" and mounts into the housing with four or eight #1-72 screws for optimal high frequency grounding. Filter circuits can be easily assembled with standard surface-mount passive components. The MB-16 includes provisions for control bias bypassing. Pads for the input/output RF connectors allow the SMA center pins to be easily soldered to the board after it is installed into the housing, as well as large pads to connect the control voltages to feed-throughs. Check the specific data sheet for the filter being used. Many of the pins are unused and need not be soldered to the ground plane. TUNABLE FILTER SCHEMATIC REF SIZE FUNCTION C1 0402 Bias bypass (not labeled) C2 0402 Bias bypass (not labeled) C3 0402 Bias bypass (not labeled) U1 LP4E Tunable Filter J1 RF input (pin 3) J2 RF output (pin 16) J3 Control bias (pin 8) J4 Control bias (pins 9,10) ASSEMBLY For additional product information, please visit www.twinind.com Contact information: 925-866-8946 (phone) 925-866-8937 (fax) Sales@twinind.com
MB-16 价格&库存
很抱歉,暂时无法提供与“MB-16”相匹配的价格&库存,您可以联系我们找货
MB-16
    • 5+161.041665+20.86053
