XB24-BPDK
XB24-BPDK
    DIGIINTERNATIONAL
    KIT DEVELOPMENT XBEE SERIES 2
XB24-BPDK 数据手册
XBee® & XBee-PRO® ZB ZigBee® Embedded RF Module Family for OEMs Embedded RF modules provide low-cost, low-power wireless connectivity using the ZigBee PRO Feature Set. Overview XBee and XBee-PRO ZB embedded RF modules provide cost-effective wireless connectivity to devices in ZigBee mesh networks. Utilizing the ZigBee PRO Feature Set, these modules are interoperable with other ZigBee devices, including devices from other vendors*. Application Highlight Products in the XBee family are easy to use. They require no configuration or additional development; users can have their network up and running in a matter of minutes. Programmable versions of the XBee-PRO ZB module make customizing ZigBee applications easy. Programming directly on the module eliminates the need for a separate processor. Because the wireless software is isolated, applications can be developed with no risk to RF performance or security. XBee modules are available in a variety of protocols and frequencies. The common hardware footprint shared by Digi’s XBee modules means users can substitute one XBee for another with minimal development time and risk. *Interoperability requires the ZigBee Feature Set or ZigBee PRO Feature Set to be deployed on all devices. Contact Digi Support for details. Features/Benefits Related Products • Interoperability with ZigBee compliant devices* • No configuration needed for out-of-the-box RF communications • Common XBee footprint for a variety of RF modules Gateways Development Kits Modules Network Extenders Adapters Sensors • ZigBee mesh networking protocol - Improved data traffic management - Remote firmware updates - Self-healing and discovery for network stability • Programmable versions of the XBee-PRO ZB enable custom ZigBee application development - 8-bit Freescale™ S08 microprocessor brings intelligence to devices - CodeWarrior® development tools for easy customization www.digi.com Platform XBee® ZB XBee-PRO® ZB Programmable XBee-PRO® ZB Performance RF Data Rate 250 Kbps Indoor/Urban Range 133 ft (40 m) Outdoor/RF Line-of-Sight Range Transmit Power 300 ft (90 m) 400 ft (120 m) 2 miles (3200 m) / Int’l 5000 ft (1500 m) 1.25 mW (+1 dBm) / 2 mW (+3 dBm) boost mode 63 mW (+18 dBm) / Int’l 10 mW (+10 dBm) -96 dBm in boost mode -102 dBm Receiver Sensitivity (1% PER) Features Adjustable Power Yes I/O Interface 3.3V CMOS UART, ADC, DIO Configuration Method 3.3V CMOS UART, SPI, I2C, PWM, DIO, ADC API or AT commands, local or over-the-air Frequency Band 2.4 GHz Interference Immunity DSSS (Direct Sequence Spread Spectrum) Serial Data Rate 1200 bps - 1 Mbps ADC Inputs (4) 10-bit ADC inputs Digital I/O 10 Antenna Options Chip, Wire Whip, U.FL, RPSMA PCB Embedded Antenna, Wire Whip, U.FL, RPSMA Operating Temperature -40º C to +85º C, 0-95% humidity non-condensing Programmability Memory N/A 32 KB Flash / 2 KB RAM CPU/Clock Speed N/A HCS08 / Up to 50.33 MHz Networking & Security Encryption 128-bit AES Reliable Packet Delivery Retries/Acknowledgments IDs and Channels PAN ID, 64-bit IEEE MAC, 16 channels PAN ID, 64-bit IEEE MAC, 15 channels 2.1 - 3.6VDC 2.7 - 3.6VDC Power Requirements Supply Voltage Transmit Current 35 mA / 45 mA boost mode @ 3.3VDC 205 mA 220 mA Receive Current 38 mA / 40 mA boost mode @ 3.3VDC 47 mA 62 mA
XB24-BPDK 价格&库存
很抱歉,暂时无法提供与“XB24-BPDK”相匹配的价格&库存,您可以联系我们找货
