XBP09-DMDK
XBP09-DMDK
    DIGIINTERNATIONAL
    KIT STARTER PROMESH XBEE PRO
XBP09-DMDK 数据手册
XBee-PRO® 900 Point-to-Multipoint Embedded RF Modules for OEMs XBee-PRO 900 modules deliver device connectivity with exceptional RF range performance using a fast point-to-multipoint protocol. Overview XBee-PRO 900 embedded RF modules provide extended-range wireless connectivity to end-point devices. These modules use a proprietary 900 MHz point-to-multipoint protocol that balances overall RF performance with a fast 156 Kbps data rate to the end node. Supporting RF line-of-sight distances of up to 6 miles (with high gain antennas), they are ideal for extended-range wireless applications requiring low latency and increased data throughput. Application Highlight As a part of Digi’s XBee® family of RF products, these modules are easy to use, share a common hardware footprint, and are fully interoperable with other XBee products utilizing the same technology. They are available in a variety of different protocols to suit different applications, enabling users to substitute one XBee module for another with minimal development time and risk. Digi’s unsurpassed offering of Drop-in Networking products provides users with seamless communication between devices. XBee adapters provide wireless connectivity to electronic devices in wired networks. ConnectPort™ X gateways enable users to access and configure remote devices in a network. Features/Benefits Related Products • No configuration needed for out-of-the-box RF communications • Common XBee footprint for a variety of RF modules • 900 MHz for extended-range operation • Outdoor RF line-of-sight range up to 6 miles (10 km) Gateways Modules Adapters • Fast 156 Kbps RF data rate • Sleep modes supported for increased battery life • Multiple antenna options • Capable of deploying the DigiMesh™ protocol with a simple firmware change Development Kits Network Extenders Accessories www.digi.com Platform XBee-PRO® 900 Performance RF Data Rate 156 Kbps Indoor/Urban Range 450 ft (140 m) Outdoor/RF Line-of-Sight Range Up to 1.8 miles (3 km) Outdoor/RF Line-of-Sight Range w/ High-Gain Antenna Up to 6 miles (10 km) Transmit Power 50 mW (+17 dBm) Receiver Sensitivity (10% PER) -100 dBm Features Serial Data Interface 3.3V CMOS Serial UART (5V tolerant inputs) Configuration Method API orATAT&commands, API, local or local over-the-air or over-the-air Frequency Band 900 MHz ISM Interference Immunity FHSS Serial Data Rate Up to 230 Kbps ADC Inputs Coming in future firmware revisions Digital I/O Coming in future firmware revisions Antenna Options Wired Whip, U.FL connector, RPSMA connector Networking & Security Encryption 128-bit AES Reliable Packet Delivery Retries/Acknowledgments Addressing Options PAN ID, channel, 64-bit address Channels 8 hopping patterns on 12 channels or single channel Power Requirements Supply Voltage 3.0 – 3.6 VDC Transmit Current 210 mA Receive Current 80 mA Power-Down Current 60 uA @ 3.3V Regulatory Approvals FCC (USA) Yes IC (Canada) Yes C-TICK (Australia) No (top view) (side views) Star PIN 20 PIN 1 1.297” (32.94mm) PIN 10 shield-to-PCB 0.080” ±0.020 (2.03mm ±0.51) 0.020” (0.51mm) 0.031” 0.110” (0.79mm) (2.79mm) 0.050” (1.27mm) PIN 11 0.866” (22.00mm) 0.960” 0.160” (4.06mm) 0.079” (2.00mm) Visit www.digi.com for part numbers. DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 877-912-3444 952-912-3444 info@digi.com Digi International France Digi International KK Digi International (HK) Limited +33-1-55-61-98-98 www.digi.fr +81-3-5428-0261 www.digi-intl.co.jp +852-2833-1008 www.digi.cn © 2008-2009 Digi International Inc. All rights reserved. Digi, Digi International, the Digi logo, the Making Wireless M2M Easy logo, ConnectPort, DigiMesh, XBee and XBee-PRO are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. 91001475 B1/309 Buy online • www.digi.com
XBP09-DMDK 价格&库存
很抱歉,暂时无法提供与“XBP09-DMDK”相匹配的价格&库存,您可以联系我们找货
