NL-SWDK-LTE-TSVG
NL-SWDK-LTE-TSVG
    NIMBELINK
    KIT DEV VERIZON
NL-SWDK-LTE-TSVG 数据手册
  Skywire™ Development Kit User Manual  NimbeLink Corp  Updated: March 2016                                PN 30005 rev 10 ​© NimbeLink Corp. 2016. All rights reserved. 1          1. Introduction  1.1 Orderable Part Numbers  1.2 Product Overview  1.3 Block Diagram  2. Connect to Kit using a PC  2.1 Unpack Kit Contents  2.2 Skywire™ Placement  2.3 Attach Antenna to Baseboard  2.4 Ensure header J6 is shorted with 2 pin Jumper  2.5 Plug in 12V Power Supply to connector J15  2.6 Plug USB cable into connector J14 and PC  2.7 Press and hold button S1 to power on the modem  2.8 Open Tera Term or similar terminal emulator  2.9 Test Serial Communication  2.10 Test Signal Strength  2.11 Activate Modem (one­time step)  2.12 SIM Card Detection (GSM Only)  2.13 Send Modem Activation String (1xRTT and EVDO only)  2.14 Setup PDP Context (GSM and LTE Only)  2.14.1 For GSM Modems  2.14.2 For the Verizon CAT3 LTE Skywire™  2.14.3 For the Verizon CAT1 LTE Skywire™  2.15 Test Network Communication  3. Common Next Steps            PN 30005 rev 10   ​© NimbeLink Corp. 2016. All rights reserved. 2    1. Introduction  1.1 Orderable Part Numbers    Description  Carrier  Network  Type  Skywire Development Kit  Any  Any  NL­SW­1xRTT­A  2G 1xRTT  Aeris  CDMA  NL­SW­1xRTT­S  2G 1xRTT  Sprint  CDMA  NL­SW­1xRTT­V  2G 1xRTT  CDMA  NL­SW­GPRS  2G GPRS  Verizon  Any GSM (AT&T,  T­Mobile, etc.)  NL­SW­EVDO­A  3G EVDO, GPS, GLONASS  Aeris  CDMA  NL­SW­EVDO­V  3G EVDO, GPS, GLONASS  Verizon  Any GSM (AT&T,  T­Mobile, etc.)  Any GSM (AT&T,  T­Mobile, etc.)  CDMA  Any EU GSM  Any GSM (AT&T,  T­Mobile, etc.)  GSM  Verizon  Any GSM (AT&T,  T­Mobile, etc.)  CDMA  Any EU GSM  GSM  Verizon  CDMA  Orderable Device  NL­SWDK  NL­SW­HSPA  3G HSPA+, GPS, GLONASS, GLOBAL BANDS  NL­SW­HSPAP  3G HSPA+  NL­SW­HSPAPE  3G HSPA+, European Version  NL­SW­HSPAPG  3G HSPA+, GPS, GLONASS  NL­SW­LTE­TSVG  LTE without Fallback, GPS, GLONASS  NL­SW­LTE­TNAG  NL­SW­LTE­TEUG  LTE with HSPA+ Fallback, GPS, GLONASS  LTE with HSPA+ Fallback, GPS, GLONASS,  EU  NL­SW­LTE­GELS3  LTE CAT1, Verizon  GSM  GSM  GSM  GSM  GSM    1.2 Product Overview  The  Skywire™  Development  Kit  includes  one  baseboard,  antenna,  power  supply,  SIM  cards,  and  debug  cables.  Skywire  modems must  be  purchased separately.  The kit enables you  to develop your  application directly on the Skywire™ modem with three different ways to connect:  ● Connect  your  PC  to  the  xE910  modem  UART  port  via onboard USB­to­UART  converter and  send  AT  commands  directly  to  the  modem  through  PC   terminal  applications. You  can  also  connect over USB for access to multiple COM ports.  ● The  kit  is  an  Arduino  shield,  so  you  can  plug  the  kit  directly  onto  an Arduino  microcontroller.  Please see Section 3: Common Next Steps for links to example documentation.    PN 30005 rev 10 ​© NimbeLink Corp. 2016. All rights reserved. 3    ● To connect the  kit  to  a  different  processor  or  development  kit, a  14­pin header breaks out the  necessary  signals  for  easy  connection  to  any  device.  The  modem  supports  I/O  levels  from  1.65­5.5V, simplifying connection to other systems.    1.3 Block Diagram       *X2 and X3 U.FL connectors not present on all modems.            PN 30005 rev 10 ​© NimbeLink Corp. 2016. All rights reserved. 4    2. Connect to Kit using a PC  This  section covers  how  to connect your development kit to a PC and provision the modem with your  cellular  plan.  It  also  covers how  to  communicate over the  serial  port to  the  Telit x910  modem which  only  requires  the  use  of  USB  port  and connector  marked  J14  or  USB2  in the diagram below. USB1  (connector J5) is used for Telit firmware updates to the modem and is not used in this section.                        2.1 Unpack Kit Contents            PN 30005 rev 10 ​© NimbeLink Corp. 2016. All rights reserved. 5    2.2 Skywire™ Placement   To mount your Skywire™ Cellular modem follow these steps:     1. Gather the following:   a. Skywire™ Development Kit board   b. Skywire™ Cellular Modem   c. U.FL  extractor  tool  (Always  use   a  U.FL  extractor  tool  when  placing  or  removing  U.FL  cables on the Skywire™ modem to avoid damaging the U.FL connectors).     2. Line  up  your  Skywire’s™  cellular  U.FL  connector(s)  on  the  side  of  the  board  closest  to  the  antenna connector. Depending  on the  type  of Skywire™ Modem  you have  there may  be one,  two, or three U.FL connections.     3. To  avoid  damage  to  the  U.FL  connector  and  maximize  connector  life,  a  U.FL  removal  tool  should  be  used  when  attaching/removing  the  U.FL  connector.  Always  insert  and  remove the  U.FL connector  with  a  force perpendicular to the board. If your Skywire™ is using GPS, attach  the  GPS  antenna  to  the  bottom  of  the  Skywire™  connector  X3.  If  you  are  not  using  your  Skywire’s™ GPS or if your Skywire™ does not support GPS, continue to step 4.     4. Attach  the  U.FL  cable  to  the  top  U.FL  connector  X1  on  the  Skywire™.  If  you  are  using  a  Skywire™ with the cellular diversity antenna option attach a second antenna to connector X2.    5. Carefully  seat  your  Skywire™  into the board’s Skywire™ socket (U1). Take care to ensure that  the pins are correctly aligned. Failure to properly align the pins may damage your Skywire™.         A properly mounted Skywire​  Modem with U.FL cable attached to top U.FL connector X1  TM​       A common  issue  is  accidentally  inserting the modem with pins  misaligned  by  one  row.  Check  pin  alignment  BEFORE  applying  power  to  prevent  modem damage.    PN 30005 rev 10 ​© NimbeLink Corp. 2016. All rights reserved. 6        2.3 Attach Antenna to Baseboard  Antenna screws onto SMA connector with a clockwise rotation    2.4 Ensure header J6 is shorted with 2 pin Jumper  This enables USB to UART communication between the PC and the modem.      PN 30005 rev 10 ​© NimbeLink Corp. 2016. All rights reserved. 7    2.5 Plug in 12V Power Supply to connector J15    2.6 Plug USB cable into connector J14 and PC        PN 30005 rev 10   ​© NimbeLink Corp. 2016. All rights reserved. 8    2.7 Press and hold button S1 to power on the modem  Please  see  the  table  below  for  the  length  of  time needed  to  hold down button  S1 for  your particular  modem.          Device  NL­SW­1xRTT­A  NL­SW­1xRTT­S  NL­SW­1xRTT­V  NL­SW­GPRS  NL­SW­EVDO­A  NL­SW­EVDO­V  NL­SW­HSPA  NL­SW­HSPAP  NL­SW­HSPAPE  NL­SW­HSPAPG  NL­SW­LTE­TSVG  NL­SW­LTE­TNAG  NL­SW­LTE­TEUG  NL­SW­LTE­GELS3  Hold Time (​t​h​) for Button  S1 To Reset the Modem  1 second  5 seconds  ​ t​w > 10 seconds  ​ 1 second  10 seconds  ​ t​h  > 5 seconds  ​ t​w​ > 10 seconds  1 second
NL-SWDK-LTE-TSVG 价格&库存
很抱歉,暂时无法提供与“NL-SWDK-LTE-TSVG”相匹配的价格&库存,您可以联系我们找货
