NL-AB-ST-NCL
NL-AB-ST-NCL
    NIMBELINK
    DEV KIT CELL CAPE STMICRO NUCLEO
NL-AB-ST-NCL 数据手册
Page 1 of 2 Getting Started Guide • Set the JP5 jumper to E5V on the Nucleo • Place the Skywire Shield onto the Nucleo as pictured • Place the Skywire modem onto the Shield as picture and attach the antenna U.FL coax cable as pictured • Plug the 12V wall supply into the Skywire Shield • Go to https://freeboard.io/ (https://freeboard.io/) and create a user account • Once you are logged into your Freeboard account, go to https://freeboard.io/board/jqlneI (https://freeboard.io/board/jqlneI) and clone the dashboard by clicking the CLONE link in the lower right corner Page 2 of 2 • The new dashboard will show up on you account list under My Freeboards, you can then edit the name to whatever you like • Under the Datasources tab on the dashboard, click the skywire link • Change the THING NAME field to a unique string, we recommended using the MEID on the Skywire Modem, but it could be anything you want. • Next Import the Skywire_Demo program into the online compiler • Open main.cpp and go to Line 26, change the DeviceID to the THING NAME you entered into your Freeboard main.cpp 1 /* --CHANGE THIS FOR YOUR SETUP" -- */ 2 #define DeviceID "DweetIODeviceName" //Freeboard DweetIO unique ID • Compile and upload to the Nucleo, cycle power to the shield and the sensor data should start to upload to your new Freeboard. http://developer.mbed.org/teams/Nimbelink/code/Skywire_Demo/ 4/22/2015
NL-AB-ST-NCL 价格&库存
很抱歉,暂时无法提供与“NL-AB-ST-NCL”相匹配的价格&库存,您可以联系我们找货
