Page 1 of 2
Export Restrictions
This product has some level of export control/restriction, so may be delayed by
2-3 business days when shipping outside the United States. Contact us with
questions, or we will contact you after you place your order.
RedBearLab BLE Nano Kit - nRF51822
W R L- 137 30
2
images are CC BY-NC-SA 3.0
Description: The BLE Nano from RedBearLab is the smallest Bluetooth 4.1 Low
Energy (BLE) development board in the market and with the included MK20 USB in
this kit you’ll be able to deploy firmware to BLE Nano even easier. At each BLE
Nano’s core is a Nordic nRF51822, an ARM Cortex-M0 SoC plus BLE capable of
running at 16MHz with ultra low power consumption. The RedBearLab BLE Nano also
supports numerous different wireless devices running iOS 7/8, Android 4.3 or higher,
and Windows Phone 8.1.
The MK20 board functions as a USB dongle, accepting 5V from the USB port and
regulating it to 3.3V via the onboard LDO which can be used to power RedBearLab
BLE Nano. When plugged into your computer the USB Board will appear as both a
serial port and a removable mass storage disk. Please refer to the Getting Started
guide in the Documents section below to learn how to deploy firmware using MK20
USB board.
Developing a Bluetooth Smart enabled ‘appcessory’ (accessory device + companion
application) is easier than ever. You can quickly produce prototypes and demos
targeted for Internet of Things (IoT) and other interesting projects. The RedBearLab
BLE Nano can operate under 1.8V to 3.3V, making it able to work in conjunction with
a wide variety of electronic components. It should be noted that the RedBearLab BLE
Nano can accept 3.3V to 13V from the VIN pin, however voltage will be regulated to
Page 2 of 2
3.3V via the on-board LDO regulator due in part to the nRF51822 IC. Since the
RedBearLab BLE Nano can work as low as 1.8V, the MK20 USB board has been
designed to run at 1.8V as well. All you need to do to get the USB board to run at
1.8V as well is just short the switch S, then the regulator will output 1.8V instead,
allowing your Nano to work with applicable components.
Note: The RedBearLab BLE Nano Kit includes two 1x6 male and female headers that
can be soldered on after purchase for easy interface. Additionally, you can find a
complete pin-out for these boards on the Product Page link found in the Documents
section below.
Includes:
1x RedBearLab BLE Nano
1x MK20 USB Board
2x Header - 1x6 (Male, 0.1")
2x Header - 1x6 (Female, 0.1")
Features:
• Smallest BLE development board, only 18.5mm x 21.0mm
• Nordic nRF51822 ARM Cortex-M0 SoC supports both BLE Central and BLE
Peripheral roles
• 2.4 GHz transceiver
• Ultra low power consumption
• Support voltage from 1.8V to 3.3V
• Software development using mbed.org, GCC, Keil or Arduino
• Lots of libraries and examples available
• Easy firmware deployment with the MK20 USB board
• Work with our free Android App and iOS App
https://www.sparkfun.com/products/13730
11/16/2015
很抱歉,暂时无法提供与“WRL-13730”相匹配的价格&库存,您可以联系我们找货
