109990071
109990071
    SEEED(矽递科技)
    LONETMINIGSM/GPRSBREAKOUT
109990071 数据手册
          LoNet ‐ Mini GSM&GPRS Breakout SKU 109990071   Description Please consider LoNet 800L ‐ Mini GSM/GPRS Breakout as alternative product This is not the replacement for the LoNet ‐ Mini GSM/GPRS/GPS Breakout, but a simplified version without GPS function. It is based on SIM800L module, supports quad‐band GSM/GPRS network, available for GPRS and SMS message data remote transmission. The board features compact size and low current consumption. The size is only two times as large as a coin. With power saving technique, the current consumption is as low as 1mA in sleep mode. It communicates with microcontroller via UART port, supports command including 3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands. It also has built‐in level translation, so it can work with microcontrollor of higher voltage than 2.8V default. Beside, the board also supports A‐GPS technique which is called mobile positioning and gets position by mobile network. This features make it can also be a tracker module. This board is specially designed for project in a small box and powered by 3.7 li‐po battery. If you want an Arduino shield, we are suggesting you pick up the SeeedStduio GPRS Shield. Features:            Quad‐band 850/900/1800/1900MHz GPRS multi‐slot class12 connectivity: max. 85.6kbps (down‐load/up‐load) GPRS mobile station class B Controlled by AT Command (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands) Supports Real Time Clock Supply voltage range 3.4V ~ 4.4V Supports A‐GPS Supports 2.8V to 5.0V logic level Low power consumption, 1mA in sleep mode Compact size 23mm x 35mm x 5.6mm Standard SIM Card Packing List:   1 x LoNet ‐ Mini GSM/GPRS Breakout 1 x GSM Antenna ‐ 3dB Gain Technical Details Dimensions 0mm x 0mm x 0mm  Weight  G.W 7g      Battery  Exclude  ECCN/HTS ECCN Not Available  HSCODE  8517709000                                        https://www.seeedstudio.com/LoNet‐Mini‐GSM‐GPRS‐Breakout‐p‐2366.html 9‐25‐18
109990071 价格&库存
很抱歉,暂时无法提供与“109990071”相匹配的价格&库存,您可以联系我们找货
    • 2+219.836802+28.40120
