113990107
113990107
    SEEED(矽递科技)
    LONET 808 - MINI GSM/GPRS + GPS
113990107 数据手册
Page 1 of 2 LoNet 808 - Mini GSM/GPRS + GPS Breakout SKU: 113990107 (images/product/113990107 0_03.jpg) Description This board based on the latest SIMCOM SIM808 GSM/GPS module, it offers cellular GSM and GPRS data along with GPS technology for satellite navigation.  The board features ultra-low power consumption in sleep mode, giving the project incredibly long standby times. Furthermore there's an onboard battery charging circuit that can be used with LiPo batteries. The GPS receiver is incredibly sensitive with 22 tracking and 66 acquisition channels, and also supports assisted-GPS (A-GPS) for indoor localisation.  The board is controlled by AT command via UART and supports 3.3V and 5V logical level. It comes with a mini GPS and GSM antenna, however a battery is optional.The board uses the 2G (not 3G or LTE) GSM networks. Features: • • • • • • • • • • • • • Quad-band 850/900/1800/1900MHz GPRS multi-slot class12 connectivity: max. 85.6kbps(down-load/up-load) GPRS mobile station class B Controlled by AT Command (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands) Supports charging control for Li-Ion battery Supports Real Time Clock Supply voltage range 3.4V ~ 4.4V Integrated GPS/CNSS and supports A-GPS Supports 3.0V to 5.0V logic level Low power consumption, 1mA in sleep mode Supports GPS NMEA protocol Compact size 27mm x 46mm x 7mm Standard SIM Card GPS Specifications: • • • • • • • l Receiver channels: 22 tracking / 66 acquisition l Coarse/Acquisition code: GPS L1 l Tracking sensitivity: -165dBm l Cold start time: 30s (typ.) l Hot start time: 1s (typ.) l Warm start time: 28s (typ.) l Horizontal position accuracy:
113990107 价格&库存
很抱歉,暂时无法提供与“113990107”相匹配的价格&库存,您可以联系我们找货
  • 1+385.131011+49.75520
