113990096
113990096
    SEEED(矽递科技)
    LONET MINI GSM/GPRS/GPS BREAKOUT
113990096 数据手册
      LoNet ‐ Mini GSM/GPRS/GPS Breakout SKU 113990096   Description We have an updated product: LoNet 808 - Mini GSM/GPRS + GPS Breakout For customers who had ordered the old version will get the new one for replace. LoNet is a GSM and GPS two-in-one function module. It is based on the latest GSM/GPS module SIM808 from SIMCOM, supports GSM/GPRS Quad-Band network and combines GPS technology for satellite navigation. It features ultra-low power consumption in sleep mode and integrated with charging circuit for Li-Ion batteries, that make it get a super long standby time and convenient for projects that use rechargeable Li-Ion battery. It has high GPS receive sensitivity with 22 tracking and 66 acquisition receiver charnels. Besides, it also supports A-GPS that available for indoor localization. The module is controlled by AT command via UART and supports 3.3V and 5V logical level. It comes with a mini GPS and GSM antenna, but not includes Li-Po battery. In addition, to use this module, you still need an unlock SIM-Card supporting GPRS service. FEATURES              • Quad-band 850/900/1800/1900MHz • GPRS multi-slot class12 connectivity: max. 85.6kbps(down-load/up-load) • GPRS mobile station class B • Controlled by AT Command (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands) • Supports charging control for Li-Ion battery • Supports Real Time Clock • Supply voltage range 3.4V ~ 4.4V • Integrated GPS/CNSS and supports A-GPS • Supports 3.0V to 5.0V logic level • Low power consumption, 1mA in sleep mode • Supports GPS NMEA protocol • Compact size 27mm x 46mm x 7mm • Standard SIM Card   SPECIFICATION           • Receiver channels: 22 tracking / 66 acquisition • Coarse/Acquisition code: GPS L1 • Tracking sensitivity: -165dBm • Cold start time: 30s (typ.) • Hot start time: 1s (typ.) • Warm start time: 28s (typ.) • Horizontal position accuracy: < 2.5m CEP • Power consumption - Acquisition: 42mA • Power consumption - Continuous tracking: 24mA • Update rate: 5Hz PART LIST     • 1 x LoNet - Mini GSM/GPRS/GPS Breakout • 1 x GPS Passive Antenna - 20dB Gain • 1 x GSM Antenna - 3dB Gain • 1 x 9Pin Male Header Technical Details Dimensions 0mm x 0mm x 0mm  Weight  G.W 13g      Battery  Exclude  ECCN/HTS ECCN Not Available  HSCODE  8473309000                                           https://www.seeedstudio.com/LoNet‐Mini‐GSM‐GPRS‐GPS‐Breakout‐p‐2183.html 9‐25‐18
113990096 价格&库存
很抱歉,暂时无法提供与“113990096”相匹配的价格&库存,您可以联系我们找货
