98100325
98100325
    LAIRD(莱尔德)
    COOLZORB4004X4X0.05"
98100325 数据手册
Hybrid Thermal Transfer/EMI Absorber   CoolZorb 400 Series             HYBRID THERMAL/EMI ABSORBER  CoolZorb 400 is a hybrid absorber/thermal management material that is used for EMI  mitigation. Product is used like a traditional thermal interface material between heat source  such as an IC and heat sink or other heat transfer device or metal chassis. CoolZorb 400 also  functions to suppress unwanted energy coupling, resonances or surface currents causing board  level EMI issues.        FEATURES AND BENEFITS            Good thermal conductivity with great EMI suppression within 1‐18GHz  Inherent surface tack typical of standard thermal gap fillers  Compliant with minimal component stress during assembly      Meets UL 94 V‐0 flame requirements    VALUE    Performance advantage comes from dual functional properties of elevated thermal  conductivity and EMI reduction   Improved reliability performance of electronics    – Better signal integrity due to reduction of EMI  – Consistent performance of electronics due to temperature stability and low  outgassing properties of product   Improved EMC performance and resultant lower cost to meet compliance requirements   Environmentally friendly solution that meets regulatory requirements including RoHS   and REACH               TYPICAL PROPERTIES  TYPICAL DATA  TEST METHOD  Color  Thermal conductivity     Density   Hardness   Tensile strength   Temperature Range   UL Flammability  Volume resistivity   Outgassing (TML)  Outgassing (CVCM)    Coefficient of Thermal Expansion (CTE)   Standard Thickness range   Thickness Tolerance    Dark gray  2.0W/m‐K  4.6 g/cc  60 Shore 00   20.4 psi  ‐40°C to 175°C   94 V0  1.6 x 1014 Ω  0.34%  0.04%  139.4 μm/m°C   .040”‐.200” (1.0‐5.1mm)  +/‐ 10%  Visual  ASTM D5470  ASTM D792  ASTM D2240  ASTM D638  NA  UL  ASTM D257  ASTM E595‐07  ASTM E595‐07  IPC‐TM‐650 2.4.41          Americas: +1.866.928.8181    Europe: +49.(0).8031.2460.0  Asia: +86.755.2714.1166     www.lairdtech.com    Hybrid Thermal/EMI Absorber  CoolZorb 400 Series                                                 AVAILABILITY      Standard sheet size is 18” X 18”  Thickness availability range is 0.040” ‐ 0.200” (1.0mm‐ 5.1mm)  Common standards for thickness are 0.040”, 0.060” and 0.080” (1.0, 1.5 and 2.0mm)  No charge samples are available in 4” X 4” size for each of the above common thicknesses    PART NUMBER SYSTEM   PRODUCTION sheets (18”X18”) use the following designation when ordering:  A17553‐XXX where  XXX is thickness of absorber in thousands of an inch, example A17533‐040 for 0.040”x18”x18”   SAMPLE sizes of 0.040”, 0.060” and 0.080” thicknesses are available without charge.  4” x 4”  pieces are ordered with the part numbers CZ400‐040S, CZ400‐060S and CZ400‐080S.  Other sizes  may be available with NRE charge.  RFP‐DS‐COOLZORB 400 050119  A ny information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end  user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non‐ infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or  consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies,  Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third  parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
98100325 价格&库存
很抱歉,暂时无法提供与“98100325”相匹配的价格&库存,您可以联系我们找货
