Hybrid Thermal Transfer/EMI Absorber
CoolZorb 400 Series
HYBRID THERMAL/EMI ABSORBER
CoolZorb 400 is a hybrid absorber/thermal management material that is used for EMI
mitigation. Product is used like a traditional thermal interface material between heat source
such as an IC and heat sink or other heat transfer device or metal chassis. CoolZorb 400 also
functions to suppress unwanted energy coupling, resonances or surface currents causing board
level EMI issues.
FEATURES AND BENEFITS
Good thermal conductivity with great EMI suppression within 1‐18GHz
Inherent surface tack typical of standard thermal gap fillers
Compliant with minimal component stress during assembly
Meets UL 94 V‐0 flame requirements
VALUE
Performance advantage comes from dual functional properties of elevated thermal
conductivity and EMI reduction
Improved reliability performance of electronics
– Better signal integrity due to reduction of EMI
– Consistent performance of electronics due to temperature stability and low
outgassing properties of product
Improved EMC performance and resultant lower cost to meet compliance requirements
Environmentally friendly solution that meets regulatory requirements including RoHS
and REACH
TYPICAL PROPERTIES
TYPICAL DATA
TEST METHOD
Color
Thermal conductivity
Density
Hardness
Tensile strength
Temperature Range
UL Flammability
Volume resistivity
Outgassing (TML)
Outgassing (CVCM)
Coefficient of Thermal Expansion (CTE)
Standard Thickness range
Thickness Tolerance
Dark gray
2.0W/m‐K
4.6 g/cc
60 Shore 00
20.4 psi
‐40°C to 175°C
94 V0
1.6 x 1014 Ω
0.34%
0.04%
139.4 μm/m°C
.040”‐.200” (1.0‐5.1mm)
+/‐ 10%
Visual
ASTM D5470
ASTM D792
ASTM D2240
ASTM D638
NA
UL
ASTM D257
ASTM E595‐07
ASTM E595‐07
IPC‐TM‐650 2.4.41
Americas: +1.866.928.8181
Europe: +49.(0).8031.2460.0
Asia: +86.755.2714.1166
www.lairdtech.com
Hybrid Thermal/EMI Absorber
CoolZorb 400 Series
AVAILABILITY
Standard sheet size is 18” X 18”
Thickness availability range is 0.040” ‐ 0.200” (1.0mm‐ 5.1mm)
Common standards for thickness are 0.040”, 0.060” and 0.080” (1.0, 1.5 and 2.0mm)
No charge samples are available in 4” X 4” size for each of the above common thicknesses
PART NUMBER SYSTEM
PRODUCTION sheets (18”X18”) use the following designation when ordering: A17553‐XXX where
XXX is thickness of absorber in thousands of an inch, example A17533‐040 for 0.040”x18”x18”
SAMPLE sizes of 0.040”, 0.060” and 0.080” thicknesses are available without charge. 4” x 4”
pieces are ordered with the part numbers CZ400‐040S, CZ400‐060S and CZ400‐080S. Other sizes
may be available with NRE charge.
RFP‐DS‐COOLZORB 400 050119
A
ny information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end
user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non‐ infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies,
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“98100328”相匹配的价格&库存,您可以联系我们找货
