Eccosorb® FGM
Thin, Flexible, Broadband Microwave Absorber
THIN FLEXIBLE BROADBAND ABSORBER
Eccosorb FGM is a thin, flexible, magnetically loaded, silicone absorber. Silicone absorbers
have high service temperature capabilities and offer advantages for high power and low outgassing applications. They can be subjected to high altitudes, including space, with no adverse
effects.
FEATURES AND BENEFITS
MARKETS
• High power performance
• High magnetic loss
• Low outgassing properties
• Commercial Telecom
• Security and Defense
SPECIFICATIONS
TYPICAL PROPERTIES
ECCOSORB FGM-40
ECCOSORB FGM-125
Frequency Range (GHz)
4 - 18
2 - 12
Max Service Temperature °C (°F)
Hardness (Shore A)
170 (338)
94
170 (338)
85
Weight kg/m² (lb/ft²)
Outgassing
(%TML) (%CVCM)*
5.0 (1.0)
10.8 (2.2)
0.16/0.06
0.31/0.10
Data for design engineer guidance only. Observed performance varies in application.
Engineers are reminded to test the material in application.
* Outgassing data per ASTM E595-07; criteria for acceptability is 1.00% TML and 0.10% CVCM.
APPLICATIONS
• Eccosorb FGM is used to line cavities in which antennas operate. It may be applied to
surfaces to improve radar performance, reduce radar cross section or backscattering.
• Eccosorb FGM is effective even at high power in reducing specular reflections as well as
surface currents due to the high magnetic loss properties.
• When bonded to a metal surface Eccosorb FGM will significantly reduce the reflectivity of
metal objects or structures due to the flow of microwave currents on that surface.
• It can be applied to antenna elements, microwave dishes, the inner or outer surfaces of
waveguides for isolation, attenuation or modification of radiating patterns.
• Applications include power amplifiers, oscillators, down/up converters and LNB’s. It is also
utilized to modify antenna patterns, cover antenna feed supports, line antenna caps to
reduce reflections and improve the isolation of sensitive RF devices.
AVAILABILITY
Americas: +1.866.928.8181
Europe: +49.(0)8031.2460.0
Asia: +86.755.2714.1166
www.lairdtech.com
Standard sheets are 305 x 305mm (12”x12”).
Standard thicknesses are 1.0mm (.040”) and 3.2mm (.125”).
On request Eccosorb FGM can be supplied with a Pressure Sensitive Adhesive.
The product is also available in other sizes, thicknesses and customer specified
configurations upon request.
Eccosorb® FGM
INSTRUCTIONS FOR USE
• To obtain low reflectivity, the absorber must be mounted on a metal surface.
• The material can be bonded by use of an RTV silicone based adhesive in conjunction with a
suitable primer. To obtain a strong bond, the metallic surface should be thoroughly cleaned
with a degreasing solvent.
• Eccosorb FGM can be readily cut with a sharp knife and template.
It is a very flexible material and conforms to contoured surfaces.
Typical Reflectivity
Reflectivity (dB)
-10
-15
-20
2
4
6
8
10
12
14
16
18
Frequency (GHz)
FGM-40
FGM-125
RFP-DS-FGM 092515
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the
end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird
Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be
the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
2
很抱歉,暂时无法提供与“21191167”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3581.629781+463.94632
- 10+3102.8628610+401.92926
- 25+3062.4597525+396.69565
