CZ500-040S
CZ500-040S
    LAIRD(莱尔德)
    COOLZORB5004X4X0.04"
CZ500-040S 数据手册
Hybrid Thermal/EMI Absorber CoolZorb 500 Series HYBRID THERMAL/EMI ABSORBER CoolZorb 500 is a 2nd generation hybrid absorber/thermal management material that is used for EMI mitigation. Product is used like a traditional thermal interface material between heat source such as an IC and heat sink or other heat transfer device or metal chassis. CoolZorb 500 also functions to suppress unwanted energy coupling, resonances or surface currents causing board level EMI issues. FEATURES AND BENEFITS  Designed using silicone gel binder that imparts inherent tack typical of standard thermal gap fillers  Filler particle composition imparts both excellent thermal conductivity and good EMI suppression in the microwave frequency range with best attenuation performance at or above 5 GHz.  CoolZorb 500 passes UL94V0 requirements  Product does not require peel and stick adhesive when used like a traditional thermal interface material VALUE  Dual functional properties of thermal conductivity and EMI reduction provide two in one solution for easier design and assembly and lower cost of ownership  Improved reliability performance of electronics o Better signal integrity due to reduction of EMI o Consistent performance of electronics due to temperature stability and low outgassing properties of product  Improved EMC performance and resultant lower cost to meet compliance requirements  Environmentally friendly solution that meets regulatory requirements including RoHS and REACH Americas: +1.866.928.8181 Europe: +49.(0).8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com TYPICAL PROPERTIES DATA TEST METHOD Color Thermal conductivity Density Hardness Tensile strength Temperature Range UL Flammability Volume resistivity Outgassing (TML) Outgassing (CVCM) Coefficient of Thermal Expansion (CTE) EMI Attenuation @ 5 GHz EMI Attenuation @ 15 GHz Standard Thickness range Thickness Tolerance Dark gray 4.0W/m-K 3.4 g/cc 55 Shore 00 45 psi -40°C to 175°C UL94V0 11 1 x 10 Ω*cm 0.093% 0.011% 118 μm/mC 9.4 dB/cm 17.3 dB/cm .020”-.125” (0.5-3.1mm) +/- .005” (+/-.127mm) Visual ASTM D5470 ASTM D792 ASTM D2240 ASTM D638 NA UL ASTM D257 ASTM E595-07 ASTM E595-07 IPC-TM-650 2.4.41 Hybrid Thermal/EMI Absorber CoolZorb 500 Thermal resistance at 100C (ASTM D5470) CoolZorb 500 Percent Deflection (ASTM D575) 50.0 45.0 0.100" (2.54 mm) % Deflection 40.0 35.0 30.0 0.040" (1.02 mm) 25.0 20.0 15.0 0.020" (0.51 mm) 10.0 5.0 0.0 0 10 20 30 40 50 60 70 80 90 100 110 Pressure (psi) Attenuation (dB/cm) CoolZorb 500 Attenuation (dB/cm) 90 80 70 60 50 40 30 20 10 0 0 10 20 30 40 50 60 70 Frequency (GHz) AVAILABILITY  Standard sheet size is 12” X 12”  Thickness availability range is .020” - .125” (0.5mm- 3.1mm)  Common standards for thickness are .020”, .040”, .060”, .080” , .100” and .125” thickness (0.5mm, 1.0mm, 1.5mm, 2.0mm, 2.5mm and 3.1mm)  No charge samples are available in 4” X 4” size for each of the above common thicknesses PART NUMBER SYSTEM RFP-DS-COOLZORB 500 110915  CoolZorb 500 series absorber sheets (12”X12”) use the following designation when ordering: CZ500-XXX where XXX is thickness of absorber in thousands of an inch  CoolZorb 500 series no charge absorber samples (4”X4”) use the following designation when ordering: CZ500S-XXX where XXX is thickness of absorber in thousands of an inch Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. Hybrid Thermal/EMI Absorber  Example: CZ500-020 = CoolZorb 500, .020”X12”X12” sheet size; Example: CZ500S-040 = CoolZorb 500, .040”X4”X4 no charge sample size RFP-DS-COOLZORB 500 110915 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
CZ500-040S 价格&库存
很抱歉,暂时无法提供与“CZ500-040S”相匹配的价格&库存,您可以联系我们找货
