CF720AB01001778
CF720AB01001778
    LAIRD(莱尔德)
    GK NICU CF PROF V0
CF720AB01001778 数据手册
CF-700 Series EcoFoam™ UL V0 Rated Grey Conductive Foam UL V0 RATED ECOFOAM™ GREY CONDUCTIVE FOAM Laird’s CF700 Grey offers an innovative approach to traditional shielding and grounding by providing X, Y, and Z-axis conductivity, enhancing the shielding effectiveness required to meet the increasing microprocessor speeds of today’s computer, telecommunications, and other electronic equipment. Ecofoam™ can be customized to your application by die-cutting, hole-punching, notching, and so on and is especially useful for odd-shaped applications which are difficult to shield with typical profile gaskets. Ecofoam™ is designed for low-cycling applications such as input/output (I/O) shielding and other non-shear standard connectors. FEATURES MARKETS • RoHS compliant • Halogen-free per IEC-61249-2-21 standard • Excellent z-axis conductivity to provide effective EMI shielding and grounding • Low compression forces allow for use of lighter materials • Available with or without conductive PSA • UL94 V0 Flammability Rating • • • • • • • • • ECOFOAM™ 700-SERIES USA: +1.866.928.8181 Europe: +49.0.8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com THICKNESS DESIGNATION 0.5 mm CF705 1.0 mm CF710 1.5 mm CF715 2.0 mm CF720 Servers Cabinet Application Network and Telecommunication Equipment LCD and Plasma TV Medical Equipment Desktop Computers Printers Laptop Computers Tablets and Smartphones CF-700 Series EcoFoam™ UL V0 Rated Grey Conductive Foam SHIELDING EFFECTIVENESS PHYSICAL PROPERTIES UNIT VALUE TEST METHOD mm (±0.2 mm) mm (±0.5 mm) 0.5 1.0, 1.5, 2.0 -
CF720AB01001778
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有高隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管阳极,2脚为发光二极管阴极,3脚为输出晶体管集电极,4脚为输出晶体管发射极,5脚为输出晶体管基极,6脚为Vcc。 4. 参数特性:主要参数包括输入电流IFmax为50mA,输出电流Io为50mA,隔离电压VISO为5000Vrms。 5. 功能详解:EL817通过内部发光二极管和光敏晶体管实现电信号的光电隔离,适用于需要电气隔离的数字信号传输。 6. 应用信息:EL817广泛应用于数字信号隔离、开关电源、工业控制系统等领域。 7. 封装信息:EL817采用DIP-6封装形式。
CF720AB01001778 价格&库存
很抱歉,暂时无法提供与“CF720AB01001778”相匹配的价格&库存,您可以联系我们找货
