3027-217-STD
3027-217-STD
    LAIRD(莱尔德)
    FAB,NICU,PNW,RL
3027-217-STD 数据手册
Product No.: 3027-217 Nickel/Copper Polyester Nonwoven Flectron® Nickel/Copper Polyester Nonwoven is a unique fabric, manufactured using a patented, proprietary technology. The base layer is highly conductive copper, with an outer layer of nickel for corrosion resistance. This technology combines the properties of these metals with the lightweight, permeability and flexibility of a nonwoven. Nickel/Copper Polyester Nonwoven offers excellent surface conductivity, shielding effectiveness, and corrosion resistance for a variety of applications. Physical Properties Property Units Substrate Polyester Nonwoven Metal Basis Weight Thickness, (nominal) (ASTM D1777) Metal Weight Max Short Duration Temperature Value Ni/Cu Advantage Flexible, Breathable Corrosion Resistant Highly Conductive oz./yd.2 g/m.2 Inches microns 2.8 – 4.5 95 – 152 0.016 432 Light Weight oz./yd.2 g/m.2 0.65 – 2.5 22 - 84 Excellent Electrical Properties Allows Thermal Processing 210C Provides excellent shielding Electrical Properties Units Valuefi Surface Resistivity (ASTM F390) ohms/square < 0.07 Far-field Shielding Effectiveness (typical) dB dB 105 90 Property At 100 MHz At 1 GHz Mechanical Properties Property Tensile Strength CMD/MD (ASTM D5035) Units Valuefi lb./in N/100mm 7.5/18.5 128/324 Elongation, MD (ASTM D5035) fi  9% Typical values for greige fabric. Cross Machine Direction/Machine Direction FLECTRON® Nickel/Copper Polyester Nonwoven can be used in many different configurations to protect against EMI/RFI and ESD for a variety of applications and environments. Typical applications include: architectural shielding, gaskets, tapes, shielding materials, and ribbon. NOTICE: Although the information and recommendations set forth herein (hereinafter "Information") are presented in good faith and believed to be correct as of the date hereof, Laird Technologies makes no representations as to the completeness or accuracy thereof. Information is supplied upon the condition that the persons receiving same will make their own determination as to its suitability for their purposes prior to use. In no event will Laird Technologies be responsible for damages of any nature whatsoever resulting from the use of or reliance upon information. Nothing contained herein is to be construed as a recommendation to use any product, process equipment or formulation in conflict with any patent, and Laird Technologies makes no representation or warranty, express or implied, that the use there-of will not infringe any patent. NO REPRESENTATIONS OR WARRANTIES, EITHER EXPRESS OR IMPLIED, OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR OF ANY OTHER NATURE ARE MADE HEREUNDER WITH RESPECT TO INFORMATION OR THE PRODUCT TO WHICH INFORMATION REFERS.
3027-217-STD 价格&库存
很抱歉,暂时无法提供与“3027-217-STD”相匹配的价格&库存,您可以联系我们找货
