33016000
33016000
    LAIRD(莱尔德)
    ECCOSTOCK PT. SQUEEZE BOTTLE
33016000 数据手册
Eccostock®FFP One Part Free Flowing Syntactic Foam Powder FREE FLOWING SYNTACTIC FOAM POWDER Eccostock FFP is a one-part, epoxy-based, free-flowing powder. It cures at elevated temperatures to a rigid, non-burning syntactic foam. It is extremely light weight and provides physical support as well as thermal insulation without increasing the weight or dielectric constant. Eccostock FFP exhibits minimum shrinkage during cure, exerting minimum stress on delicate components. Cured material can be easily removed with tools enabling access to repair or replace components.Since cured Eccostock FFP is porous, application of an epoxy coating will reduce moisture absorption. FEATURES AND BENEFITS MARKETS • Low cost • Low shrinkage during cure • No mixing required and easy to use as it is a one part curing system • Commercial Telecom • Security and Defense SPECIFICATIONS TYPICAL PROPERTIES ECCOSTOCK FFP Temperature Range °C (°F) Density, g/cc Compression Strength kPa (psi) -65 to 175 (-85 to 347) 0.24 1000 (150) Dielectric Constant @ 8.6 GHz Loss Tangent @ 8.6 GHz Dielectric Strength, volts/mil 1.25 0.005 64 Thermal Conductivity W/mK Volume Resistivity, ohm-cm 0.051 11 3.49 x 10 Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. APPLICATIONS • Eccostock FFP is designed to infiltrate densely populated electronic packages, readily filling available volumes around components. It been used to stabilize crystal oscillators as well as other delicate components that need to be held in place or thermally protected. • Eccostock FFP has also found its way into machinery operating in high vibration environments to keep electrical components from shaking apart. • Low shrinkage during cure makes • Eccostock FFP excellent for encapsulation applications. AVAILABILITY • Eccostock FFP is readily available in pints, quarts, gallons, and 5 gallon containers. Pint and quart containers are also available in squeeze bottles for ease of application. Americas: +1.866.928.8181 Europe: +49.(0)8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com Eccostock® FFP INSTRUCTIONS FOR USE • Refer to the MSDS for full safety information before opening the container. Measures should be taken to avoid any contact with the skin and eyes, and a dust mask or respirator should be used to avoid inhaling the product. • Mix the Eccostock FFP in the shipping container by lightly tumbling or shaking before use, as some components may separate during shipping and storage. • In a well ventilated area, carefully pour the Eccostock FFP from a small paper cup or dispense from a squeeze bottle into the device being filled. • Light to moderate vibration is recommended to maximize packing of the material. • Eccostock FFP bonds well to itself and most other substrates. Mold release wax is recommended in applications where removal from a mold is necessary. • Shelf life is 6 months if stored in a cool dry place out of direct sunlight at 21 °C (70 °F). • Elevated temperature curing is required. Select one of the following recommended curing times and temperatures: Cure Times and Temperatures 24 hours at 100°C (212°F) 4 hours at 120°C (248°F) 2 hours at 150°C (302°F) RFP-DS-FFP 112515 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
33016000 价格&库存
很抱歉,暂时无法提供与“33016000”相匹配的价格&库存,您可以联系我们找货
