18150092
18150092
    LAIRD(莱尔德)
    ABSORBSHEETDSF-9.5/SS6M12X36
18150092 数据手册
Eccosorb® DSF Thin, Flexible, Weatherproof, Resonant Microwave Absorber CORROSION-RESISTANT RESONANT MICROWAVE ABSORBER Eccosorb DSF is a thin, flexible, narrow band absorber that reflects -20 dB or less of normal incident microwave energy at the design frequency in the range of 3 to 22 GHz. Eccosorb DSF is a dielectrically loaded, silicone rubber sheet. Unlike typical iron-filled silicone absorbers, no oxidation is possible due to the chemical nature of the patented dielectric pigmentation system. The material is impervious to moisture and can be used outdoors. FEATURES AND BENEFITS MARKETS • High power performance • Narrow band performance • Oxidation-resistant • Commercial Telecom • Security and Defense • Automotive SPECIFICATIONS TYPICAL PROPERTIES ECCOSORB DSF Max Service Temperature °C (°F) 163 ( 325) Water Absorption after 14 days Hardness (Shore A) Density Range (g/cm³) 0.001 % 80 1.9 - 2.2 Tensile Strength (MPa) Elongation at break (%) 3.2 - 3.5 39 - 51 Tear Strength (N/mm) 1.1 - 2.2 Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. APPLICATIONS • Eccosorb DSF is ideally suited for applications requiring absorption at a specific frequency or in a narrow frequency band, including: -lining radar nacelles, particularly where high power is present -attaching to masts of ships, walls, etc. to reduce reflections and echoes to nearby antennas -attaching to vehicles to reduce overall radar signature. • Eccosorb DSF is especially recommended for use in saline environment where oxidation may be considered a problem. The materials are impervious to salt water and can be used in marine applications. AVAILABILITY • • • • • Americas: +1.866.928.8181 Europe: +49.(0)8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com Standard sheets are 305 x 305mm (12”x12”). Thickness depends on resonant frequency desired. Grades are designated by their suffix corresponding to the resonant frequency desired. Other resonant frequencies can be supplied on special order. The material can also be supplied in customized shapes. Eccosorb® DSF INSTRUCTIONS FOR USE • Eccosorb DSF is designed to function directly in front of a metallic surface. If this is not the case, a metallic foil should first be bonded to the object. • To obtain a strong bond of the absorber to the object, clean the surface with a degreasing solvent, apply a thin coat of primer to the dried surface and apply an RTV silicone adhesive. • Eccosorb DSF can be readily cut with a sharp knife and template. It is a very flexible material and will conform to mild curvatures Typical Reflectivity Performance The performance of ECCOSORB® DSF is defined by reflectivity at a single frequency. A generalized performance curve is shown above. The design frequency f0, has a ±5% bandwidth, designated as f1 and f2. RFP-DS-DSF 092315 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. 2
18150092
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考芯片手册。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM,工作电压2.0V-3.6V,工作温度-40℃至+85℃。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(UART、SPI、I2C)等模块的详细介绍。
6. 应用信息:适用于工业控制、医疗设备、智能家居等多种应用场景。
18150092 价格&库存
很抱歉,暂时无法提供与“18150092”相匹配的价格&库存,您可以联系我们找货
