4053AB51S04800
4053AB51S04800
    LAIRD(莱尔德)
    GSKT FAB/FOAM 2.3MMX120CM DSHAPE
4053AB51S04800 数据手册
51S EMI Gaskets Fabric-over-Foam UL 94V0 RATED SN/CU NYLON RIPSTOP (NRS) FABRIC-OVER-FOAM Laird’s Fabric-over-Foam (FoF) 51S EMI gaskets provide excellent EMI shielding performance for customers where EMI issues occur. The 51S Series EMI gaskets are composed of electrically conductive fabric wrapped around a soft urethane foam core. They are supplied with either a conductive or non-conductive pressure sensitive adhesive (PSA), and can be equipped with an Extended Release Liner (ERL) on the adhesive. The 51S is a UL 94V0 rated product that can be created with cross-section profiles such as rectangle, D, C, P, T, knife, bell shapes, and others. The 51S EMI gaskets can be further customized to an application by die-cutting, hole punching, notching, etc. FEATURES MARKETS • Fabric-over-Foam gaskets are RoHS compliant • UL 94V0 • Low surface resistivity of < 0.07 Ω / □ provides excellent conductivity • Shielding effectiveness of >85 dB across a wide spectrum of frequencies • Extremely low compression forces allow for use of lighter materials • Fabric is highly conductive to provide good EMI shielding and grounding • Laird’s proprietary coating prevents fabric fraying and fingerprinting, and increases abrasion resistance • Available with conductive or non-conductive PSA • Many cross-section profiles available such as rectangle, D, C, P, T, knife, bell and more • Profile gaskets can be cut to specified lengths, kiss-cut on release liner, or mitered to form frame configurations • Cabinet applications • LCD and Plasma TV • Medical equipment • Servers • Printers • Laptop computers • Networking equipment • Desktop computers • Telecommunications cabinets FORCE/DISPLACEMENT/RESISTANCE (FDR) SHIELDING EFFECTIVENESS (dB) USA: +1.866.928.8181 Europe: +49.0.8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com 51S EMI Gaskets Fabric-over-Foam Item Unit Value Test Method 30MHz-300MHz dB 95 300MHz-3GHz dB 102 3GHz-18GHz dB 89 Ω /□ < 0.07 ASTM F390 Shielding Effectiveness MIL-DTL-83528C(Mod.)* Surface Resistivity Compression Set % < 20 ASTM D3574 Operation Temperature °C -40 to 70 - Flame Retardant UL 94V0 (UL file No.E170327) Hazardous Substance Compliant with RoHS (Directive 2002/95/EC) Compliant with SONY SS-00259 Antimony-free * Part tested: 5 mm H x 10 mm W, rectangle shape COMPOSITION OF PRODUCT W Conductive fabric H Polyurethane foam PSA tape (option) PRESSURE SENSITIVE ADHESIVE (PSA TAPE) OPTIONS Name Type Thickness (mm) Peel strength on stainless steel (JIS Z 0237) Z-axis Resistance LT-301 Conductive PSA 0.09 > 1.3 kgf/25 mm < 0.05 Ω LT-350 PSA 0.12 > 2 kgf/25 mm - *Other PSA can be provided. Contact Laird Technologies engineering. ORDERING INFORMATION PART NUMBER EXAMPLE Digits: 1 4 2 2 3 1 4 6 5 A Profile S hape & Details 6 A - 7 5 8 1 Product Name 9 S - 10 0 11 1 12 4 13 0 14 0 Part Length (inches to two decimal points) EMI-DS-FOF-51S 0613 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user, since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2013 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trade marks or registered trade marks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
4053AB51S04800 价格&库存
很抱歉,暂时无法提供与“4053AB51S04800”相匹配的价格&库存,您可以联系我们找货
